Luigi65 Posted February 1, 2008 Report Share Posted February 1, 2008 Hi, I really hope this is the right forum for posting this question: I've purchased a cheap master keyboard (Fatar TMK88) which does not allow to set different velocity responses so that when connected to some sound modules (Motif Rack ES) I have to play hard. Moreover it seems to me that the sensitivity of the black keys is different with respect to the one of the white keys. I think it is possbile to build a realtime event processor that modify the "velocity" data in order to have different responses. The question is: how can I do that? What do I need?Thank you in advance,Luigi Quote Link to comment Share on other sites More sharing options...
stryd_one Posted February 1, 2008 Report Share Posted February 1, 2008 Welcome aboard Luigi.May I suggest that you use the search engine? I'm sure this has been discussed before ;) Anyhow, you can use the C language to write an application that will modify velocity data as it passes from midi in to midi out. The most basic implementation would take just a core module and a couple of hours to write the program, the most complex...well that is up to you ;) Quote Link to comment Share on other sites More sharing options...
Luigi65 Posted February 1, 2008 Author Report Share Posted February 1, 2008 Thank you very much stryd_one for your fast reply. Just a couple of more questions: once I have build the core module, what do I need to program the pic? Additional tools? I've seen that I can upload the program via sysex, but in this case will be it stored in EPROM or do I have to upload the program at every power on?Thank you in advance,Luigi Quote Link to comment Share on other sites More sharing options...
dj3nk Posted February 1, 2008 Report Share Posted February 1, 2008 try this :) http://www.softpedia.com/get/Multimedia/Audio/Other-AUDIO-Tools/MIDI-Velocity-Curve-Changer.shtmlyou haver to install a virtual midi port like "midi yoke".greetz Quote Link to comment Share on other sites More sharing options...
Luigi65 Posted February 1, 2008 Author Report Share Posted February 1, 2008 Thank you, greetz, for your reply. I need to do something like the SW tools you have proposed but in HW, to avoid the need for a PC. I don't think I'll have problem to program the PIC (I'm a C/C++ programmer), but I need to know what I need: it seems that the core module is enough, but how can I program the PIC? And what PIC is the most powerful considering that I'd like to add many features such as MIDI channel changer, splitter, etc...Thank you,Luigi Quote Link to comment Share on other sites More sharing options...
bill Posted February 1, 2008 Report Share Posted February 1, 2008 You should have a look here as well :http://www.midibox.org/dokuwiki/velocity_converter Quote Link to comment Share on other sites More sharing options...
Luigi65 Posted February 2, 2008 Author Report Share Posted February 2, 2008 Yes, bill, that's a good start point. thank you.Luigi Quote Link to comment Share on other sites More sharing options...
