All Activity
This stream auto-updates
  1. Last week
  2. If you still have the i2c quad midi board I’d be interested please.
  3. The way i am using this my functions are actually all in a list called MIOS_SYSEX_COMMAND_FUNCTIONS[ID] so in this example : MIOS_SYSEX_COMMAND_FUNCTIONS = { MyFunction = function(numbers) print(numbers[1] .. numbers[2]) end, }
  4. if you place this in your root script in TouchOSC, the text element will display the last messages from MIOS32. I included a little parser that can be used to trigger functions and transmit data - like "Start MyFunction 4 35 2334 4 End" that will call MyFunction({4,35,2334,4})
  5. -- Display MIOS32_MIDI_SendDebugMessage() messages and transmit data/trigger functions -- this prints to the Touchosc Log window, as well as to a text element called "text" local MIOS_MSG = root.children.text -- <- this text element must be in root, or simply change this adress function log(msg) print(msg) text = msg.. "\n" .. text --text = text .. "\n" .. msg local count = 0 MIOS_msg_lines = {} for line in text:gmatch("([^\n]*)\n?") do if line == "" then break end table.insert(MIOS_msg_lines, line) count = count + 1 if count >= maxLines then break end end text = table.concat(MIOS_msg_lines, "\n") MIOS_MSG.values.text = text end -- messages in the form of "Start .. ID .. list of numbers seperated by spaces .. End" can be used to transmit data to TouchOSC and call functions local MIOS_SYSEX_COMMAND_FUNCTIONS = { -- numbers from mios are 0 based! MyFunction = function(numbers) print(#numbers) end } function Do_MIOS_Sysex_Command(ID, numbers) local fn = MIOS_SYSEX_COMMAND_FUNCTIONS[ID] if fn then fn(numbers) end end -- sysex message handling local sysex_buffer = {} local last_sysex_time = 0 local sysex_timeout = 200 -- ms (adjust if needed) function flush_sysex_buffer() if #sysex_buffer > 0 then local msg = table.concat(sysex_buffer) sysex_buffer = {} log("MIOS32 (timeout flush): " .. msg) Log("[TIMEOUT] " .. msg) end end function onReceiveMIDI(sysExMessage) local now = os.clock() * 1000 -- ms resolution -- if too much time passed since last byte -> flush old buffer if now - last_sysex_time > sysex_timeout then flush_sysex_buffer() end last_sysex_time = now local headerLen = 8 for i = headerLen + 1, #sysExMessage do local b = sysExMessage[i] if b == 0xF7 then -- end of SysEx, flush buffer as a complete message local msg = table.concat(sysex_buffer) sysex_buffer = {} local ID = msg:match("^Start%s+(%a+).-%d+.-End$") if ID then local numbers = {} for num in msg:gmatch("(%d+)") do table.insert(numbers, tonumber(num)) end Do_MIOS_Sysex_Command(ID, numbers) else log("MIOS32: " .. msg) end else if b ~= 0 then table.insert(sysex_buffer, string.char(b)) end end end end
  6. hey, 2 years later again... i'll have a look, next week i got some holidays. should still have some of that stuff somewhere. sorry, i haven't had a functional diy space since the covid times, moving etc, got to dig through my boxes next week
  7. Earlier
  8. I have the same problem with Rosegarden (and midi files generated by it) sending simultaneous Bank and Patch Change commands to multiple cores on the MB6582. Right now the solution is that I send Bank and Patch changes only to cores 2-4, and only a Patch change command to core 1. That way the sounds to be played seem to be selected correctly, and if core 1 needs a bank change, I will have to remember to do that manually. If I add the Bank Change command to core 1 as well, the patches get messed up as described above. If there can be a solution to this problem, I'm willing to test different combinations, attach midi files which replicate this etc.
  9. Hi, seems ok to me... you have to go through all the voltage checks before inserting SID modules (look in the mb6582 wiki). Then test 1khz tone check and you may load the troubleshooting apps in the MIOS8 download section.
  10. I have a function that does some heavy floating point math (calibrating solenoids to a nice midi velocity response). It works, but is slow. The STM32 does seem to have an FPU. Is it enabled in MIOS32? If not, how can i enable it in my application and make the compiler use it? Thanks!
  11. Hello everyone. I'm new to the forum and I'm currently building an MB6582 for the first time. I have almost all the components in place, but I have a question for more experienced users: could you take a look and see if everything is OK before I connect the power supply and start testing? I decided to use the power supply option "E" from this thread: So, the changes are: - no B1 rectifier installed - no C14 and C13 installed - C3 is 10uF instead of 2200uF (and here I don't know what the voltage of this 10uF capacitor should be) - V4 is a Recom R78B5.0-1.5 - V1 is a 7809 - as I understand from the documentation, if I only use the 6582, I don't need to put a 9V switching regulator here (Recom R-78C9.0-1.0?) - pin 2 and pin 3 of J71 are connected by a jumper - pin 2 and pin 3 of J72 are connected by a jumper - pin 1 and pin 2 of J73 and pin 2 of J74 are connected by a cable under the board - jumpers installed at J1_SIDx and J2_SIDx in the 9V position Am I good to go further? Don't worry about the dirty board; this is before cleaning. Many thanks in advance!
  12. Hello Midibox-Forum, a long time ago in a galaxy not so far away I built a unit of the Midibox SEQ based on my own design for the user interface. It was the year 2005. A few years later the microchip was upgraded and replaced by the LPC17-based core module, thats why the backside of the housing was adapted but unfortunately I never finished the housing. The bottom side just has a plexiglass cover, so you can actually have a look inside the DIY electronics and all the boards and solderings :-) Now, as I own a "new" Midibox SEQ from Midiphy, it is time to give away the "old" Midibox SEQ to someone who wants to play around with it. The price is simply depending on your bid. It is currently fully working, just the behaviour of the encoders is not perfect, sometimes a encoder skipps a few steps and also some of the buttons need to be pressed with a bit more force. As already mentioned the case was never finished, so if you wand you can rework the case. The design was originally done by a company called Schaeffer, the company still exists today and so the housing "system" can be ordered if you like, here´s the link: https://www.schaeffer-ag.de/frontplatten-designer# You can find the Midibox on the Kleinanzeigen website - the text is in German but I will also ship the box in Europe if necessary. https://www.kleinanzeigen.de/s-anzeige/midibox-seq-v4-midi-step-sequencer-diy-fuer-einsteiger/3158249168-74-6800 If you have any questions just send me a message on Kleinanzeigen, as I will check this regularly.
  13. Glad you got it sorted! You even coaxed @nILS back to the forum! Welcome back!
  14. Thank you very much, Ronald! That was exactly the reason why the LED wasn't lighting up. Now it works!
  15. After some digging/debugging, it turns out we need to set the following variable to '1' to have this 5th LED working: DEFAULT_MB6582_CS I found this out by this table in src/cs_menu_leds.inc where the fifth bit (reading from right to left) is only set in the first 'if' routine: CS_MENU_LED_LFO_Wav_Pattern andlw 0x0f ; 16 entries JUMPTABLE_2BYTES_UNSECURE retlw b'00000001' ; Sine retlw b'00000010' ; Triangle retlw b'00000100' ; Saw retlw b'00001000' ; Pulse retlw b'00010000' ; Random #if DEFAULT_MB6582_CS retlw b'00100001' ; Positive Sine retlw b'00100010' ; Positive Triangle retlw b'00100100' ; Positive Saw retlw b'00101000' ; Positive Pulse #else retlw b'00010001' ; Positive Sine retlw b'00010010' ; Positive Triangle retlw b'00010100' ; Positive Saw retlw b'00011000' ; Positive Pulse #endif retlw b'00011111' ; reserved retlw b'00011111' ; reserved retlw b'00011111' ; reserved retlw b'00011111' ; reserved retlw b'00011111' ; reserved retlw b'00011111' ; reserved retlw b'00011111' ; reserved
  16. I have still exactly the same 'issue'... From another place in the manual ( LFO section ) http://ucapps.de/midibox_sid_manual_l.html Wav (Waveform): selects the shape of the LFO. Following waveforms are provided: Sine, Triangle, Pulse, Ramp (Sawtooth), Random (Sample&Hold), and positive Sine/Triangle/Pulse/Ramp So I would indeed expect the 'positive' LED to be lit (new style?), in stead of the multiple leds (old style?) when selecting the other waveforms in the active/selected LFO... Will be doing some more investigations in the ASM configuration file, as it seems to be another setting :-)
  17. I looked at exactly the same thing and thought the same thing. But since the firmware is relatively old and I couldn't find anyone else whose LED wasn't lighting up during my search, I thought it couldn't be the firmware. That's what I'm thinking too, but where do you turn this feature on? For me, for example, Sine+Random light up at the same time when I have a positive Sine LFO waveform. That's how it's explained in the manual. You should be able to turn off this display feature and turn on the separate LFO positive LED, right? It is installed in many MB 6582 models. (Picture attached) But when I compare the ASM files, I can't find any differences. And in this video, you can see at the beginning how the preset is changed and then LFO 1 has a positive triangle waveform. So there, the LFO positive LED lights up instead of the random LED. https://www.youtube.com/watch?v=FA0i5-bAfUQ
  18. From what I gather from the manual and changelog, this LED indicates whether you have selected a „positive values only“ waveform for the LFO (instead of applying the default workaround by showing waveform LED + Random LED). It does not indicate that the value of the LFO is currently positive.
  19. Hi @TK. A great alternative for this would be to have the active SID led 'flash/dim' whenever there is midi activity like this is done in the FM v1. (instrument 1/4 led flash/dim) Would that be a feasible option (both programming wise, as resource PIC wise)?
  20. my problem was a bad driver chip on the bhp_seq interface board....
  21. Hi Keeze, I am not sure how, but I missed your offer. Many, many thanks, but sorry again for missing your response. Currently I am running with 2 blue modules, and my problem was solved by replacing the driver IC on the mbhp_seq interface board. So many thanks for your offer, and unless your are going to scrap our lcd's, I am not in a need anymore.
  22. I just shared this thread in the Discord channel. Maybe that helps. At least there are knowledgable people there :-) Also tried to find some clues in the code, but this is hard for me. I did find something interesting (not sure if it is relatated at all), in src/cs_menu_leds.inc Searching for the word 'TMP5' shows in line 127: 127 ;; TMP5[5..0]: LFO waveform and in line 159: 159 ;; TMP5[6]: SID play state So in this file it looks like it's structured, but is the 'array' [5..0] correct? Should it be [4..0], and should there be a separate section for TMP5[5]?
  23. Hello acfnews, Thank you for your reply and your test. I suspect that the LED would indicate the positive range of the currently selected LFO. That would make the most sense to me. In some pictures and videos, I find SIDs that have this LED installed. But I have not seen it light up in any picture or video. Perhaps someone who has installed this LED and has it displaying something can say more about it. If you find out more or get the function to work, please let me know. :-) Best regards, Oli
  24. Hi Oli, I just stumbled upon your question, and I never considered this function, however, it might be interesting... My first question would also be, which of the LFO's would it indicate, as there are 6? Is it a sum? Not sure.... As a test I configured my ASM file, and added a line for the function (and removing a working function from the hardware position just like you did). In my case the first SR1,0 (normally used for SID1 LED indicator). DOUT_ENTRY TMP5, 4, 0, 0 ; LFO Random LED DOUT_ENTRY TMP5, 5, 1, 0 ; LFO positive LED ;; additional LED functions which could be added: However, on first test, no magic....` I will also have a look to see if I get thus going in a way...
  25. Many thanks for the quick reply. Yes, I sent another function to this LED as a test and it then worked without any problems. So I can actually rule out everything on the hardware side. Unfortunately, I can't find many SIDs where the LED is used. I also couldn't find any videos on YouTube where someone has installed this LED and you can see it in use. In my *.asm file, the DOUT line looks like this (Shift Register 6): DOUT_ENTRY TMP5, 5, 6, 7 ; LFO Positive LED Is that all I need to enter for the LED function to work?
  1. Load more activity
