X11
    32
X11 last won the day on March 21 2025
X11 had the most liked content!
  • Gender
    Not Telling
Contact Methods
  • Yahoo
    alaktu@yahoo.com
Recent Profile Visitors
X11's Achievements
MIDIbox Newbie
  1. Well 15 years has past:) but just want to share a small note on troubleshooting rebooting,crackling noise and/or lcd problems. Regarding a sammichSID 2x 8580r5. The 7805 regulator: There are a few different regulator types. If !! the 7805 get’s her input voltage thru the 9v supply line (7809). So not the 12v option: From the output of the 7809 it goes to two(4001 ) diodes to protect and cause a voltage drop to the input of the 7805. My theory is that the input voltage gets dropped to low for some regulators to stay stable in certain configurations. I had issues with a 7805CV regulator it requires ~8v minimal to stay stable(specs). so when the current draw is increased due to using real sids/backlight etc it gets easily unstable. Crackling noise and reboots in my case. I changed it to a 7805CT regulator that stay’s stable till 7v input(specs). Everything runs perfect now. =>no crackling-no reboots. sharing is caring ❤️
  2. Arrived and kicking. Thank u for your service ❤️
  3. Hi sgw32, Would also like to buy one from u without sid’s. Preferable in a reflective yellow/gold enclosure?:) if still available i have two 6852 sidchips regarding the capacitor values Much love, Hans
  4. You are right! My mistake ill delete it.
  5. Similar discussion featuring dutch houses,better to connect the pc and adaptor to an "earthed" outlet: http://computertotaal.nl/forumarchief/1-moederborden--processors--overklokken--casemodding-en-koeling/73388-hoe-zit-dat-met-geaard-stopcontact Same deal in my house so very interesting stuff (dutch-site). Anyway good luck earthwise and congrats with your working MB6582:)
  6. nice! If you dont want to mess with main voltage use a earth free external outlet : https://www.google.nl/search?q=aarde+loos+stekkerdoos&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjxzPL9s5DMAhUKjCwKHUQ5A5sQ_AUIBygB&biw=1280&bih=631 Probably thats the best choice for now
  7. :) Yep agree:) if so a solution could be isolation(not connect) the earth pin in the 220v plug (stekker) or use a flat 220v plug(earth pin less en discard the 0v connection ), if i'm correct.. x
  8. Hi Dreamer, So u are shure that +15v is connected on the +site? where the bridge rectifier says + The switch interups/closes one ac channel sounds like u switch Ground on /off instead of +15v. then+15v is always there and so when another ground is introduced(other plugged gear) it will start up? just a thought. x
  9. Hi, Just looked at your pictures. Maybe there is a short where the yellow wire crosses the hole? Perhaps test the solderjoint and the hole with the multimeter. X
  10. X11
    Sammichsid sold
  11. X11
    Sammichsid sold
    as it turned out i had the green fillin one one stuffed with 8580' aswell. Bit bad painted engravings tho.
  12. X11
    Sammichsid sold
  13. X11
    Sammichsid sold
    Hi, Selling my sammichSID combo; 1- green fill in 6581 8580R5's 1-white fill in 8580's Sold ill need to open them up to take picture of the sid's. all working like supposed. Reason: finished 2 mb6582's and wanting to buy the 1u mb6582 supporter:) the one @strophlex sells €350,- including shipping €700,- including the pma5(without adaptor) if desired. located in the Netherlands shipping needs calculating but €700 will cover it all i guess. not for the money but for the gear! x
  14. X11
    thanks
    Psu getting bit hot shown cooled by a cold beer and need to add some knobs Frontplated was an cnc expiriment on lexan glass. Kept the leds and lcd under the plate and the engraving well just pressed stop on the cnc machine;) https://soundcloud.com/akkadian-records/p8bitch
