zephyrin
    68
    2
Everything posted by zephyrin
  1. Yes is that, i m testing now the MB9090 of Jozef and i think that we can control other drum box with this. The MB9090 app is based on MBSeq V4 and used midi port. I will try to see if the MB9090 works with my new yamaha RX5. For the the switch and the led i have found some information in the setup_808_default.asm file For exemple for the button and i m not shure that is the same i see also 27 button and not 33 :ermm: SEQ_IO_TABLE_DIN ;; Function name SR# Pin# ;; NOTE: the pins of the 16 general purpose buttons are assigned above, search for DEFAULT_GP_DIN_SR_L (and _R) DIN_ENTRY SEQ_BUTTON_Scrub, 0, 0 DIN_ENTRY SEQ_BUTTON_Metronome, 0, 0 DIN_ENTRY SEQ_BUTTON_Stop, 5, 5 DIN_ENTRY SEQ_BUTTON_Pause, 0, 0 DIN_ENTRY SEQ_BUTTON_Play, 5, 3 DIN_ENTRY SEQ_BUTTON_Rew, 5, 6 DIN_ENTRY SEQ_BUTTON_Fwd, 5, 2 DIN_ENTRY SEQ_BUTTON_Live, 5, 1 DIN_ENTRY SEQ_BUTTON_F1, 0, 0 DIN_ENTRY SEQ_BUTTON_F2, 0, 0 DIN_ENTRY SEQ_BUTTON_F3, 0, 0 DIN_ENTRY SEQ_BUTTON_F4, 0, 0 DIN_ENTRY SEQ_BUTTON_Shift, 2, 5 DIN_ENTRY SEQ_BUTTON_Alt, 2, 4 DIN_ENTRY SEQ_BUTTON_SectionA, 1, 0 DIN_ENTRY SEQ_BUTTON_SectionB, 1, 5 DIN_ENTRY SEQ_BUTTON_SectionC, 1, 3 DIN_ENTRY SEQ_BUTTON_SectionD, 1, 4 DIN_ENTRY SEQ_BUTTON_LayerGate, 2, 0 DIN_ENTRY SEQ_BUTTON_LayerAux, 2, 1 DIN_ENTRY SEQ_BUTTON_Edit, 6, 4 DIN_ENTRY SEQ_BUTTON_Mute, 5, 0 DIN_ENTRY SEQ_BUTTON_Pattern, 6, 7 DIN_ENTRY SEQ_BUTTON_Song, 6, 5 DIN_ENTRY SEQ_BUTTON_Solo, 0, 0 DIN_ENTRY SEQ_BUTTON_Fast, 0, 0 DIN_ENTRY SEQ_BUTTON_All, 0, 0 ;; OPTIONAL! see CHANGELOG.txt DIN_ENTRY SEQ_BUTTON_Group1, 0, 0 DIN_ENTRY SEQ_BUTTON_Group2, 0, 0 DIN_ENTRY SEQ_BUTTON_Group3, 0, 0 DIN_ENTRY SEQ_BUTTON_Group4, 0, 0 DIN_ENTRY_EOT
  2. MB808 seq for MB808 voice Hello i m trying to make th MB808 with the microlarge PCB. I have finish the 3 boards , i have also building power supply, and output from yoda design. Now i will building the sequencer part, for that i have 1 x MBHP_CORE, stuffed with PIC18F4620, 2 x MBHP_DINX4 amd 2 x MBHP_DOUTX4. I will also building the banksitck I know that TK and Kogz23 works on a new "combined" PCB I wanted to know this standalone MB808 seq have the same design as MB808 with the digitast switch and what is the difference between this MB808 seq and the MB9090 seq from jozef ? I need also some help for connecting switch and led to DIN and DOUT :) On the original MB808 there is a pot swing (10KB) and accent (10K) where there are connecting ?
  3. Shuriken, i have paid around 80 €, there are a lot of holes. I think it's not expensive becaus i will spend a lot of time if i will make it myself :rolleyes:
  4. From the album: MB808
    © Zephyrin
  5. From the album: MB808
    © Zephyrin
  6. zephyrin
    MB808 power suply
    © Zephyrin
  7. zephyrin
    MB808 power suply
    © Zephyrin
  8. zephyrin
    MB808 switch
    © Zephyrin
  9. zephyrin
    MB808 output 3
    © Zephyrin
  10. zephyrin
    MB808 output 2
    © Zephyrin
  11. zephyrin
    MB808 output 1
    © Zephyrin
  12. From the album: MB808
    © Zephyrin
  13. zephyrin
    MB808 core
    © Zephyrin
  14. you can see it here My link
  15. Hello I have bought from Mikes Elektronikseite a bankstick PCB (Bankstick - Pertinax) but i don't found any picture for explain how to solder it ?
  16. Hi Jojjelito i have the same with the switzerland post. Under 5 CHF there are no taxe. After the post add 12 or 16.5 CHF with 3% of the total price. 12 CHF is for near country... The solution for no have the tax that i found is that the seller say that the parcel is free commercial sample and the cost is 0 or under 30 CHF .
  17. For me 17" or 19 " with LPC17
  18. Hello I have understand that this case don't work LPC17core ? If it's true why you don't change the size for use the with the both core ?
  19. Merci pour l'info malheureusement c'est une version modulaire avec pas mal de PCB
  20. Bonjour Je me permet de relancer ce sujet :rolleyes: En dehors de Doug et de la MB 808 existe il un autre moyen de ce fabriquer un clone de TR 808 ? J'ai vu que sur le site de microlarge il y a des PDF de PCB Peux on ce procurer ces PCB à quelque part ou doit on les faire fabriquer ? Merci d'avance pour vos réponse David
