moloxbat
    10
Everything posted by moloxbat
  1. So a "Spannunsgwandler" that would be? Stepping up in Voltage... hm Cool, a new Project ;) thanks, I didn't realize the required voltage for old gear can be 5V, I didn't even realize it was 3V (Or 3.3V) Best Regards
  2. Midi Out: changed R21 to a 100Ohm resistor, didn't help, any other suggestiones?
  3. Hi Thorsten, C7 now works! (pressed = Key-Control on, released = Key-Control off) Midi Out: changed R21 to a 100Ohm resistor, didn't help, any other suggestions? Midi In (1+2) receive messages only from Midi Channel 1, right? Regards
  4. blingy your are on the same track than I! *
  5. Hi there! I will try and repost ... soon(ish) :] thanks and regards, ...
  6. I just dusted off my seq v4l and update firmware to 074 and it - doesn't get out of the Keyboard Control Mode with my Hardware Keys connected (C7 doesn't toggle) - do get out of the Keyboard Control Mode from my PC, but to toggle it back on from the PC doesn't work ANOTHER THING: it seems Midi Out doesn't work for my old Drum Machine, I verified pretty much everything, can it be the voltage doesn't match? Regards
  7. Thanks for shedding some light on the topic! (...and very thorough measurement) The GM5 seems to do a good job, special. not spreading so much. I am just wondering if my (not finished yet) SeqLiteV4 can act as a Midi interface with the same performance... Sonar is crap in that regard then, I am using FLSTUD and that needs to be checked For future measurem, how do you get to microseconds? what's the math behind that?
  8. I am running Windows 7 And playing/recording synths, like Roland Alpha Juno, Oberheim, etc. via Midi I have a MOTU micro Express which is USB1 I believe Also I got a RME Multiface with a Midi Port. Connected to PCI I measured IN and OUT midi latency and have 5ms in and 5ms out on the MOTU On the RME it's zero ms, from zero to 1ms adding IN+OUT I know this might not be related to Midiboxes (maybe also?) but here are the people with expertise. So, can anyone state what it is about? Am I beeing fussy? 5ms-10ms ain't that much, but it add's up with another 10ms audio latency. Would there be a good option to USB Midi Interfaces, like old-school serial? Or is only my MOTU effected from that problem? Is it the OS even? some insight on this topic would be greatly appreciated. moloxbat
  9. I just saw I can order from Farnell. It does say in the infopage! So I might order the AOUT_NG PCB then & thx for the detailed instructions! You mean the AOUT_LC?? I haven't even finished to make the SeqLite Frontpanel. I do not recommend using a breadbord/veroboard. It is a lot of work that way. So I only tried the Core Module and that works fine according to MIOS. I am going to try the functioning box tomorrow ftft! I also find the connector labeling a bit hard, once the sockets are soldered, the labels are disguised, luckily I made a photo. Are the "squares" ground? Also, one more thing. Is the "data" for the AOUT converted from midi messages to CV or is it in a "rawer", faster format before conversion to voltage? If that makes a difference speed wise!? m
  10. Hi! Is there a way to integrate the AOUT Module into the SEQLite yet? If yes, any idea where to get the chip for the AOUT_NG module, if not want to order the whole lot from the US for 50 bucks? If not, when will it be ready? I'd really like to get it to run analogue gear. Or should I make a Midi/CV converter, separately? Speed/tightness is in any case an (musical) issue for me! Thanqus!
