lajos
    49
Everything posted by lajos
  1. lajos
    MIDIbox SEQ V3.4
    Hello! I'd still like to know whether you can stick on to the bank is ready to copy patterns and how? Thank you, Louis. Where can I download these patterns?
  2. lajos
    SEQV3
  3. lajos
    MIDIbox SEQV3
    From the album: SEQV3
    Final!!
  4. lajos
    SEQV3
  5. lajos
    SDC10336
  6. lajos
    SDC10327
  7. Develops a thing! SEQV3
  8. Even a few hours of work done!
  9. I set the control panel for it! I hope it will be good instead of the rotary push-button design is good I think it is?? Hello Louis!
  10. The panels are now finished! Start with the implant! I think they should add! Egy kép!
  11. I'm sorry now I see that seq V3 18F4620 core panel works! Instead of a five-18F4685 18F4620 Leht use? I do this at home. If yes then to collect the information. Thank you. It is suitable for display! If so you're likely to order! CTC LCD Display C240L02YBN00 2X40LINE x Char 1 STÜCK | eBay
  12. Thanks for your response! There are all the parts at home, I'd just like to know how it works. The v3 core to the panel is not good, to my knowledge. So if db50xg sound module can interface with V2? Thank you, Louis.
  13. Hello! I have a yamaha module db50xg it would be good to midiboxseqV2?? thank you
  14. It is suitable for display???CTC LCD Display C240L02YBN00 2X40LINE x Char 1 STÜCK | eBay
  15. Hello! A little information would be needed on the uCapps not is not entirely clear how and which software which links to be done in order to midibox64seq v2 can do it!! Someone feltehetné information, drawings, hex! 18F452 has to do with that at home. Thanks in advance! Luis
  16. lajos
    Sequencer?
    Thank you very much for the information! I would like to build a simple sequencer core panel, or some other solution I found on the net is a good simple sequencer, you could build! Luis. It would be nice if a panel would include everything! Thank you again!
  17. lajos
    Sequencer?
    Hello! It would be a question to which there is a panel that includes everything from the sequencer! Thank you, Louis.
  18. lajos
    TwinSid V1.2
  19. lajos
    SDC10110
    From the album: TwinSid V1.2
  20. lajos
    SDC10111
  21. lajos
    SDC10112
  22. lajos
    YAMAHA DB50XG
  23. Hello Thorsten! The PIC based core panels which have a hex midi input signal, the menu, as amended and / volume / and modified midi output signal is sent out? Or switching to this one should be constructed? Thank you for your help. Louis.
  24. Thorsten Hello! What is my connection would solve my problem? The HHC CORE panel would not be able to solve this? Of course, the right software? Anywhere on the Internet is not a piece of teláltam suitable switching either. If there is one you can share with me! Happy New Year! Lewis
