56 -
Everything posted by endernoumea
Hello, I have two questions about this command : 1 - Is it possible to precise the type of hw_id in the meta command SetBankOfHwId ? I need it to change some encoders bank but my Dout matrix is receiving the instruction as well (which is not needed) In example something like : meta=SetBankOfHwId:ENC:14 .. to change only the bank of the encoder 14 ..or.. meta=SetBankOfHwId:ENC:any .. to change the bank of all the encoder and nothing else 2 - Second question, is it possible to change the bank of an item defined by a matrix ? If i use... meta=SetBankOfHwId:1001 ...to change the bank of my RGB matrix led event i have an error in MIOS studio like : ERROR: expecting 1 values for meta type in EVENT_BUTTON ... meta=SetBankOfHwId In other words: Is it possible to have a new instruction called SetBankfwd_id where we can use the same events like fwd_id ? :p
I did what we supposed at the end : 1 - I setup the RGB matrix with driver connected to 5V permanentely. (so i only need 3 SR per matrix) i declare it like this : DOUT_MATRIX n= 2 rows=4 inverted_sel=1 inverted_row=1 sr_dout_sel1= 0 sr_dout_r1= 5 sr_dout_g1= 6 sr_dout_b1= 7 led_emu_id_offset=1501 DOUT_MATRIX n= 3 rows=4 inverted_sel=1 inverted_row=1 sr_dout_sel1= 0 sr_dout_r1= 8 sr_dout_g1= 9 sr_dout_b1= 10 led_emu_id_offset=1801 note : the sr_dout_sel=0 (i think this is the dummy SR because i read it in many settings) so for 2 RGB matrix i only need 6 SR. (5 to 10 in my case here.) The Blackscreen are now as brighter as they can and i can control them with the rgb=r:g:b command. Of course this means that my RGB matrix are only 1 row maximum.
I setup 3 radio buttons that represente 3 functions i can assign to my encoders. The objective is to change to color of the screen according these 3 buttons when i move an encoder. here is how i do that : EVENT_BUTTON id= 35 type=CC chn=1 cc=16 button_mode=OnOnly range= 0:0 radio_group=1 EVENT_BUTTON id= 39 type=CC chn=1 cc=16 button_mode=OnOnly range= 1:1 radio_group=1 EVENT_BUTTON id= 40 type=CC chn=1 cc=16 button_mode=OnOnly range= 2:2 radio_group=1 DOUT_MATRIX n= 2 rows=4 inverted_sel=1 inverted_row=1 sr_dout_sel1= 0 sr_dout_r1= 5 sr_dout_g1= 6 sr_dout_b1= 7 led_emu_id_offset=1501 EVENT_ENC id= 1 hw_id=1 bank= 1 fwd_id=LED_MATRIX:1 fwd_to_lcd=1 type=CC chn= 1 cc= 16 range= 0:127 offset= 0 ports=1000100000001000 lcd_pos=1:1:1 label="ENC #%3i %3d@(1:16:1)%B" EVENT_ENC id= 1001 hw_id=1 bank= 1 if_equal=Button:40:2 fwd_id=LED:100 EVENT_ENC id= 1002 hw_id=1 bank= 1 if_equal=Button:39:1 fwd_id=LED:102 EVENT_ENC id= 1003 hw_id=1 bank= 1 if_equal=Button:35:0 fwd_id=LED:101 EVENT_LED id=100 fwd_id=LED:1502 rgb=15:0:0 EVENT_LED id=101 fwd_id=LED:1502 rgb=0:0:15 EVENT_LED id=102 fwd_id=LED:1502 rgb=0:15:0 My problem here is that the led are activated only when the encoder value is > 63. I want it to be activated everytime i move the encoder. Can i force it ?
It's working :)
I think this is the answer. It might be ok for a led but it's not enought for a LCD blackscreen. (at least not those like mines) I was wondering something but I don't know if this can works: 1- Setup 3 differents dout matrix to separate my 3 rows on 3 differente boards. 2- the replace the driver by a constant 5V This should allow me to use the rgb=r:g:b instruction from the matrix function and avoid the scanning effect right ? (I have spare dout I could use for that)
No I have no OSC sorry :/ Is there any way to drive RGB led without matrix ? because it seems that it's not allowed to use rows=1 in the matrix definition.
The picture is from the original post of the protodeck project : http://julienbayle.net/works/creation/protodeck-midi-controller-for-ableton-live/ I use it as a model to describe what I am using here. I have 2 differences : - I use no resistance nor resistor array. - I will have 22 RGB at the end, so 3x8 (not 8x8) I just setup what you said on a breadboard and the led still not bright. I cannot test the rows=1 because it generate an error in mios : [839542.973] [MBNG_FILE_C:10] ERROR invalid row number for DOUT_MATRIX n=1 ... rows=1 (only 4 or n*8 allowed)
I actually setup only 16 screens but I will have 22 of them at the end so the 1 row matrix cannot fits my requirements. The LCD are common anode. The data sheet can be found here : http://www.ebay.com/itm/16x2-Character-LCD-5V-RGB-Backlight-Negative-Mode-RGB-on-Black-2x16-Row-USA-/150826420761 So i declare my matrix like this : DOUT_MATRIX n=1 rows=4 inverted_sel=1 inverted_row=1 sr_dout_sel1=1 sr_dout_r1=2 sr_dout_g1=3 sr_dout_b1=4 led_emu_id_offset=1001 The wiring is inspired from the "hacked dout" of the protodeck project but without any resistance nor resistance array.
yes exactly. On the picture they are ok but it was before i use the dout matrix. They were connected directly to 5V at this time to "test" the colors. The RGB matrix is working very well. I can change the color using the rgb=rr:gg:bb in my led event but it's definatlly not bright enought to be workable by day.
I just setup the dout Matrix to control the RGB screens. I take some time to understand how it works but now it's ok and it's amazing to watch all the colors available. I'm now facing a new issue. I think it's related to the "non-permanent" current going thru the matrix. I mean that my LCD are not glowing as expected. (on the picture the LCD glowing OK but they are directly connected to a power source and not to the matrix) I remove all the resistor from the dout and it's kinda better but not enought. I tried two circuits, on with ULN 2803 and one with 74HC541 which improve the result but not enought again. I'm am now wondering if I can use a capacitor to smooth the current drop but I'm not sure on the way to do it. If this kind of trick cannot works i guess I will have to use DOUT module without matrix but this will make the RGB control much more complicated. Any advises ? Thank you in advance, Ender
Tada !!!! Everyhting works ! Finally :)
Hi ! I had 2 crazy months at my job so I did not answer before... sorry about that. All the LCD are now working perfectly without using the above circuit. I just split the LCDs in 2 chains and plug half of them on J15a and the other half on J15b. It means 8 lcd screens per socket in my actual case (16 in total). In the final configuration i should have 22 LCD screens so I will keep in touch about this workaround. Regards, Ender
Hi ! I received the 74HC541 and make the circuit as illustrated before. I also added a 220r for D0 to D7 and powered the Dout with 5V from J4A. Actually none of this works but i believe i miss something with : "BL and V0 are replicated for every 4 to 8 LCD units. " because i didnt do anything about that... what does this comments means please ? Ender
I tried this and it drastically improve the result. I still have some glitche but they are rare. FYI: i did not have 100ohm resistor at my disposition so i use 2 x 220ohm in parrallele. I will be able to try with real 100ohm in a week.
I tried all the combinations and it seems the effect is reduced when it's the 4th of the chain. For you to know: the "bad" board alone : ok the "bad" board + any other board : ok the "bad" board + 2 others boards : first gliches appearing 4 boards : party time
I finally found the issue... to resume, this board was the first i made and i'm not proud of it. Probably my iron was too hot too... so the anode under the led 144 was burned and causing short cut. I isolate it and the board is working in standalone. It has generated a new issue. Now when i plug this board after the 3 others I have random change of values on the others board. I guess that I have another "burned" track around the RIOS chain. I'm gonna check that. Hopefully I have a spare board on its way just in case...
I ordered the components yesrterday. They should be here in a week. I'll keep you in touch :p Ender
Yes it is. We are talking about the LED 143 :) I'm not sure to know yet how to do that but that sounds interesting :)
I should have 22 LCD at the end so the circuit you attach is is probably my solution too :) Thank you very much for it !!! I will now search an online provider for those components. Regards, Ender
I tried the file you attach here with same result. 3 boards are 100% ok. The last one have the same issue.
I actually have 16 LCD screens connected to the MBNG. Declared as follow in bootloader : lcd_num_x 4 lcd_num_y 4 lcd_width 16 lcd height 2 Here the issue: if i plug all the 16 screens, they seems to be initialized correctly but none of them work. If i remove any of them and reset they all works 15/15. To check them i use the CLCD_16.ngc from the MBNG tool and according the LCDs i've disconected I'm able to say they all (16/16) working correctly and are addressed correctly as well. Any idea where it comes from ? Thank you in advance, Ender
Yes i'm using ULN2803 on these board. I tried to replace them with no effect. The dout matrix is here. Yes. I do not have any ghosting effect on the others encoders or board. Just on this encoder ring. Each time i move up an encoder i can "see" the ghost changing as well. If i light them all the ghost is glowing nearly as strong as the others. And its last led (last on right) is never lighting on whaterver I do. I double check all my solders and can't find where it comes from. Do you think i can use a cutter to isolate this encoder's led ring and patch it from the IC directly ?
