marco@mp
    22
About marco@mp
  • Birthday 07/23/1983
Contact Methods
  • Website URL
    http://www.mplive.it
  • Gender
    Male
  • Location
    Italy, Roma
Recent Profile Visitors
1,708 profile views
marco@mp's Achievements
MIDIbox Newbie
  1. Thanks a lot for the answer, but could you have an example? Unfortunately, I'm not good at programming and i have problems with the english language too...
  2. Hi all, I'm looking for help programming MidiBox NG, I have problems with encoder management, I'll explain better, I need to send 2 notes, when I rotate to cw a note should flash when i rotate ccw a different note should flash the flashes must go according to the rotations. I don't know if I explained myself well, but I hope someone more experienced can help me. Thanks so much
  3. perfect, So far so good. I now there is a new problem, when bank change. all faders are at 0, it maintains the previous value and leading to 0 faders software. thanks
  4. thanks Guru, so it is almost perfect. just one last thing. with 2 keys, I have to change the value bb. from 00 to 7f surely you will know how to help me ...... thank you very much
  5. hi, is there anyone? please help me ... I do not know what to do ..... help me help me help me help me help me thanks
  6. Hello, I, already know ma4pc. I preferred DIN 8 for a simple reason, if you were to damage an IC lose only 8 bits, and 8x8. ilmio project is a GMA2. as commands from a PC HW is OK, I miss the feedback of the motor faders and LEDs. I just solved these two little things, the whole place. bye bye
  7. ok I think I have to convey this. EVENT_MF hw_id=1 type=SysEx stream="0xF0 0x7F ^Dev 0x70 0x02 0x7F 0x06 0x00 0x01 ^Val 0xFF ^Val_h 0xFF 0xF7" but nothing comes out from midi. the protocol of the lighting console is: F0 7F [device ID] 02 [Command Format] [Command] [Date] F7 therefore, F0 7F 70 02 7F 06 aa bb cc dd F7 aa= Fader bb= Fader Page cc= fine value dd= coarse value allegoil link protocol I need. http://help.malighting.com/view/concept/Conc_MSC.html thanks.
  8. Thank you very much Guru. following your advice I solved many problems, I just wanted to ask you one last thing, my consol Lights, uses a protocol called midi MSC, MIDI Show Control, you can use it with the motor fader? I enclose picture. hello thanks ...
  9. hello, maybe I can help, I'm doing the exact same thing. I used a core LPC17, 8 DIN, 2 MF_NG. encoders to simplify, I utilizato of Ic decoders, then I send you some pictures, for the moment, I'm working on motorfader. as soon as I have any news, I'll let you know. bye :rolleyes: :rofl: :rolleyes: :rofl: :rolleyes: :rofl:
  10. ok, problem solved, sequence the steps that I run. 1, loaded device_id_01.hex - or the one you want. 2, loaded the FW MF_NG - or true, setup_mbhp_mf_ng_standard.hex I now there is a new problem, from my USB1, if I press a button I get a note on / off, but if I move a fader does not give me a note but a CC. how do I let out a note from the faders? attach files default.ngc Thank you. DEFAULT.zip
  11. hello back with new info, in MakeFile.bat am, MIOS_PATH =. MIOS_BIN_PATH = ./bin export MIOS_PATH export MIOS_BIN_PATH It includes Makefile.orig the problem, I do not know what inpostare, and if you throw me the errors appear in the image. please help me :sad: :sad: :sad: :sad: :sad: :sad: :sad: :sad: :sad: :sad: :sad: thanks
  12. hi, I will start with the excuse of my English, but I'm chart using google translator. I have a core LPC17, 8 MBHP_DIN, 8 MBHP_DOUT, 2 MBHP_MF_NG. I have a problem with the ID of the core and 2 MF_NG, all devices hano ID 0. I tried using change_id_v1_9g but I can not make it work, and to find some explanation online. I hope to find help on this forum. thanks
  13. ciao, i bcf li ho programmati un po di tempo fa, ma non è stato difficile, puoi farlo o tramite il loro software tramite il pc, o direttamente sui bcf. il manuale spiega passo passo come fare, l'unica cosa da sapere sono i parametri da inserire...... ciao ciao
  14. marco@mp
    my MA
