ukk1337
    2
ukk1337 last won the day on January 15 2021
ukk1337 had the most liked content!
Recent Profile Visitors
1,027 profile views
ukk1337's Achievements
MIDIbox Newbie
  1. Hey, thanks for your answer and clarification. It turned out that it was the perfect combination of misunderstanding/misinterpreting the manual (which I actually read) an a broken stereo cable -.- So everything is working fine now, thank you!
  2. Hi there, I recently bought a used sammichSID equipped with two 8580 SIDs, MIOS 1.9g, running MIDIbox SID V2.044. The problem I'm facing is that only one SID seems to be recognized. So within the ensemble-menu I can only choose SID 1. Also I get only audio-output by one SID. So I have the following questions: - does the Midibox software perfom any check to determine if the SID may be broken and "disables" it in the frontend-selection? - is there any way to perform a check or debug this issue? - if the SID is broken: would I be able to recognize it in the menue if I would swap both SIDs against each other to check if one is broken? So that the ensemble-screen would say *2** instead of 1***? - software issue? - am I completely missing something, like that the behaviour of the sammichSID differs from the "normal" MIDIbox SID? Any help or hint would be appreciated :-) Thanks, Chris
