jzurd0
20 -
jzurd0 last won the day on April 26 2016
jzurd0 had the most liked content!
Recent Profile Visitors
jzurd0's Achievements
2
Thanks Peter! What I'm trying to do is to capture raw MIDI performances from the MidiBox for later playback and eventually record/mix the resultant audio on the fly when playing them (MIDI data) back to the hardware synths/drum machines and so on. Was thinking of DAW because not really sure that an ancient hardware sequencer has the ability to record a huge amount of midi data in realtime. Will try to go that way if I find one for cheap such as a QX3 or similar. Thanks again.
Hi Peter et al, Sorry to come back with this but I'm having a lot of issues trying to capture my live midi performance with an external DAW. Tried with Reaper and what I get is a lot of stutter and jitter when multritracking 6 midi devices at the same time. Please let me show you my current workflow: ----> SYNTHS VIA MIDI OUT (MIDI OUT 1...4) MIDIBOX ---> ------> DAW VIA FX DUPLICATE (USB 1...4) I assume usb midi is fast enough to multitrack as per TK's post from 2009. Any of you is capturing live midi data from the Midibox Seq? What I need is to capture the live midi data only but I'm struggling with timing and jitter. Any input/recommendation will be greatly appreciated!!!
Hi all, was this feature or LTC / SPP implemented? I'm struggling to sync it to a DAW! Thanks!
Sorry to rescue this ancient topic but I'm also facing this exact issue from time to time, is anyone impacted by it yet? Not really sure about my SD card, I'm pretty sure it was formatted under FAT32. Thanks all!
Thanks Peter, it is working that way, I will experiment with the MIDI ROUTING to avoid using an external midi interface. Thanks again!
Thanks for your response Peter, I was thinking about that; yesterday tried to install x64 midi drivers without success, but I have a spare x86 machine with drivers already installed to test it. Regarding FX Dupl., I was looking into the manual and it is not very clear to me, can I just duplicate a track to a single different destination channel or I need to set it up for >1 channels? Thanks in advance !
Hi all, I've been using MidiBox as my main sequencer for several years now and always thought of recording my live performances in midi format. Until now I was using all the 4 midi outs I have installed but since a couple of days I remapped all the tracks to OUT1 and set the midi channels accordingly. What I'm looking for is to record midi data live while it's being sent to my machines, on the fly, to record all the mutes and changes. I'm trying to do it using an ancient MOTU interface using the "merge all" mode capturing one of the outputs with Cubase but all I get is midi garbage, stucked notes and so on. Not sure if it has to be with the Midi interface not able to process all the midi data. MIDIBOX -> MOTU-> MIDI DEVICES/COMPUTER Any of you is recording live midi data with external outboard/DAW? Many thanks in advance, Jose
Thanks a lot @TK. !! Another suggestion for future releases that could be interesting but not sure about it's complexity: Auto-fill steps while in DRUM track mode, Let's say you press GP3 button (fill start) for two seconds, that would invoke FILL mode ( "FILL" flashing above the steps), without (or not?) releasing GP3 press GP11 (fill end) to set the end of the steps to be auto filled: steps 3 to 11. (3)xxxxxxx(11) I think this could be very useful, for instance, in HI HATS parts Hope you get the idea because my explanations are not the best!!! Anyway, thanks again, you are great!
Thanks a lot TK that works now. On the other hand I found out that if you use, under "About this midibox" the "SD Card" option then the sequencer stops and is no longer playing unless you restart the device again. Not sure if this has to do with my module only. By the way do you think a Restart/Reset option could be easily implemented to avoid having to disconnect the machine? Thanks a lot for your time and effort!!!
Same here, and can also confirm it is happening in seq_v4_095_pre4 also. "Glad" to hear it's not only mine which is failing,
Hi Peter, Thanks for your help. I'm on V4_090b, the only change was the TPD module, but that was added a week ago and had no issues so far. I'm planning to do an intensive test tomorrow, will report asap. Thanks again, Jose
Hi all, This evening mu Midibox Seq V4 (STM32F) crashed with the error you can see in the attached screenshot. Any clues on what's going on? I'm using Wilba's panel, 2 dual midi modules and Ilmenator's TPD module. Could this be caused due to a midi buffer overflow ? I was sending midi data quite fast (2 steps tracks looped randomly by hand) if that is of any help.. This never happened before and I would like to trace this fault in depth as currently Midibox is the heart of my studio. Thank you all!
Hi Peter, Tested a Sandisk Ultra 8Gb (Class 10) and it took 29 seconds to create a new session! That was measured starting to count at the very moment you press the 'create' button until it finishes the files creation process. Fast enough for me. Thanks !
Thanks Peter, Can I ask you to recommend a fast one? I'm currently using a Kingston x4 (4GB) but it is pretty slow, it takes around 2 minutes to create a new session. Is this normal? Thanks a lot!
Hi all, Do we have a "list of compatible/tested cards"? Sorry if that is already in place!
