    7
Recent Profile Visitors
Reubenclarke.jpg's Achievements
MIDIbox Newbie
  1. Hey Everyone. After following through the troubleshooting guide I think I'm having an issue with my midi->usb cable. I'm running windows 10, I tried both a no name cable and an M-Audio Uno. Does anyone have any recomendations on cables that work well with windows 10? Thanks
  2. Nothing seems to be out of the ordinary. Only Issue I have found is the clock only has 30mV between the two contacts. What voltage should the 10.000Mhz clock run at?
  3. Hey everybody. I'm having an issue that I'm hoping you will be able to help me with. I have got some weird connection issues when trying to connect and program my PIC18f452 The PIC runs at 4Mhz I have measured my Crystal Oscillator Mhz and its at 50hz (hz not Mhz!) I believe that this is throwing off my PIC and is causing me issues when trying to program it. (Roughly 4-20 times I click query I can get a response) What could cause this weird timing issue and how can I fix it. (Extra Notes) I can only get a response from the core, If I bridge the J11 contacts between the midi output and 5v with an LED I can only upload a .hex file with said LED removed I broke my 100nf Caps so im using 100nf 50v rating rather than 50-100v range that the original ones had. Would any of these give some clues to what is happening. (Sorry I'm very much a beginner)
  4. Modular Addict is Back Online. Just ordered some PCBs yesterday. 2ish week delay for international orders
  5. I am doing a 15 Fader project which would require 2 NG_MF boards. I have heard you can chain these together. Is it possible? If so, how do you chain these together?
  6. Hi, I need help. I want to make a lighting midi controller. I need 15 motorized faders and 60 backlit buttons. I looked at many systems on how I could make this. I came across Midi Box and I like it so far. But I don't know what I'm doing. What Parts do I need to control 15 motorized faders and 60 buttons using this system and how would I connect it all. Thanks in advance
