Quick question - will https://github.com/midibox/mios32 be updated with the latest LoopA revision?
Currently looks like v2.06.
In the meantime I'm just jotting down some ideas here...
Sleep/suspend/low-power mode
LoopA has no power switch. It would be nice to leave it unattended for days at a time, without unplugging.
Could be simple as turning off LEDs.
Multiple undo/redo
Especially for incremental note recording; up to memory limit.
Note cleanup
Bad note data can originate, for example, when a MIDI controller is sending on 2 channels at once and LoopA is listening on all channels.
Delete notes with 0 length (causes glitchy behavior).
De-duplicate overlapping notes.
Add missing note-off events to the end of a sequence.
Sustain pedal behavior/stuck notes
Reset sustain pedal when stopping the sequencer, or when loop restarts, to avoid stuck notes.
In general, I'm doing a lot of MIDI panic; would be nice if that could be slightly more ergonomic one-handed key shortcut than Scene+Live.
Repeat operation in Notes screen
It would be handy to repeat previous operation (i.e., all operations applied to the current note could be applied to a subsequent note). Inspired by the vim command.
