Dr_Nick
40 -
About Dr_Nick
- Birthday 01/01/1
Gender
Male
Location
Germany
Dr_Nick's Achievements
Thank you for your fast reply! Actually I'm running the latest v2 firmware, so after reading the old v1-tutorials mentioning a value of 115 I was trying to figure out the right combination of clock rate in bpm and speed value in the "wtc"-menu. In the v2-manual for the lead engine there is a divider of 3 mentioned as an example in the sections describing arpeggiator and wavetable settings ("Spd (Speed): the wavetable speed derived from the global clock. If the global clock is synched to a MIDI clock master (slave mode), and the divider is 3, a speed value of 1 will step the wavetable on each 32th note. A value of 2 on each 16th note, a value of 8 on each beat."). Is the value for the divider anything you can or should change somewhere in the menus? Regard, Dr. Nick
I was trying to use the wavetable as described in the old v1 turorial (http://www.ucapps.de/howto_sid_wavetables_1.html), but I just can't quite get my head around the correct settings for clock speed and wavetable rate to achieve an 50Hz rate. Also, in the manual for the lead engine there is a divider of 3 mentioned for the clock, but I can't find a way to set that divider. Plus I don't really understand the difference between the +/-xx and absolute xx values in the wavetable: I am trying to get a short 3 octave arpeggio using a wavetable, starting at position $00 and looping to $01. Parameter is 37 (Transpose OSC#1). The sequence 40 +18 -0c -0c works as expected, but +00 +18 -0c -0c does not. But why? Regard, Dr. Nick
Count me in for one of the kits incl. 2 6582s!
Auf der Seite von Sequentix (http://www.sequentix.com), dem Hersteller vom P3, steht unter DIY, dass es den Sequenzer nicht mehr als Kit gibt, sondern nur noch als Fertiggerät. Bleibt also nur noch die MIDIbox Seq... Ist wahrscheinlich eh die flexiblere Variante.
Tach Matze! Ich habe vor ein paar Wochen eine SID-Umschaltplatine für meinen alten C64 gebastelt (ursprünglich 8580, jetzt umschaltbar auf 6581...) und habe da folgende Erfahrungen gemacht: -wenn man beim 8580 den Widerstand R8 in die Ausgangsschaltung einbaut, dann wird er leiser. Könnte mir vorstellen, das der 6581 mit seinen 12V Analog-Versorgungsspannung ein größeres Ausgangssignal liefert und das dieses reduziert wurde, um irgendwelchen Spezifikationen zu genügen. Wenn man beim 8580 den Widerstand rausläßt und beim 6581 nicht, dann ist das Ausgangssignal in etwa gleich laut. -für den SID 8580 sind in allen neuen C64 die 2,2nF Filterkondensatoren eingebaut. Thorsten hat in dem Originaldatenblatt des 8580 für die Caps einen Wert von 6,8nF gefunden und nach einigen Tests bei Verwendung in einer MIDIbox SID keinen größeren Unterschied gehört. Da die meisten hier wohl 6,8nF-Kondensatoren verwenden werden die veröffentlichten Patches auch mit diesen Kondensatoren am besten und bei allen sehr ähnlich klingen. Ich hatte zum Test im C64 auch mal Kurz 6,8nF für den 8580 eingebaut. Wenn man dort dann SID-Musikstücke hört, dann klingen die Filter sehr, sehr deutlich anders. Das stimmt dann hinten und vorne nicht mehr und klingt nur noch Schlimm. Bei meinem SID-Modul habe ich allerdings noch nicht ausprobiert, ob der Widerstand und die Kondensatoren einen merklichen Lautstärke- bzw. Klangunterschied machen...
You might want to check out the following threads as well: Topic: Any good ideas for implementing the following.....? LED array: http://www.midibox.org/forum/index.php?topic=5560.0 Topic: led's as touch sensors: http://www.midibox.org/forum/index.php?topic=5709.0
Maybe you can use the PCD5844 displays found in Nokia 3310 mobile phones, which is an 84x48 pixel graphic display. TK's driver allows for 8 of those displays to be connected to one core module, so that's one display per fader... I don't know if anybody has used those displays in an MIDIbox LC, but you might want to search the forum. Best regards, Dr. Nick
Als ich einige Vactrols brauchte, habe ich die bei www.smallbearelec.com betellt. Sind dort zwar teurer als bei Newark (von $5.50 für den VTL5C2 bis $7.00 für den VTL5C1), dafür waren die Versandkosten nach Deutschland sehr ok, gerade bei wenigen und leichten Bauteilen. Zumindest war das so, als ich dort zuletzt bestellt habe, ist jetzt auch schon ein wenig länger her...
Hi Artesia! Why don't you leave out the relay and use an multi-deck rotary switch instead? For example a switch with two layers of 4 poles. Those switches are easily limited to only 2 switching positions. Regards, Dr. Nick.
Hallo JR! Conrad hat den Preis bei den Fadern leider nicht gesenkt. Wenn mann im Business-Bereich des Conrad-Shops ist, werden die Preise ohne Mehrwertsteuer angezeigt: 19,78 + 16% MwSt. = 22,95 pro Stück. Schade, daß der Mengenrabatt erst bei 10 Stück beginnt, wo der Standard-Midiboxer doch meist nur 8 braucht... Vielleicht könnte man ja lieb bei Reichelt anfragen, ob die die Fader ins Sortiment aufnehmen und am besten noch Encoder dazu. Wären dort bestimmt günstiget als bei Conrad. Man müsste denen nur deutlich machen, das es einen Markt für diese Bauteile gibt. Und den nicht nur in Deutschland, sonder auch im europäischen Ausland. Obwohl... Wie viele Leute bauen sich eigentlich Midiboxen, insbesondere die recht aufwendigen und teuren mit Motorfadern? Gruß, Dr. Nick.
Hi! Is it posibble to add some LFOs to the midibox cv firmware? Or midi-triggered envelope generators? Personally, I don't have a clue how much processing power would be needed to implement some LFOs with a resolution higher than 7 bits. Any ideas? Regards, Dr. Nick
In his designs Thorsten just glued the LEDs to the frontpanel and wired them up without any PCB. It's supposed to be a lot easier that way.
Hi rambinator! Reichelt (www.reichelt.de) sells vectorboards in sizes of up to 500x100 mm for EUR 5.00 (copper pads) and EUR 3.95 (copper stripes). Reichelt is usually a lot cheaper than conrad. regards, Dr. Nick
Such mal bei www.conrad.de nach "multimec". Da gibt es eine Tasterserie von Deltron, die, soweit ich weiß, nicht im normalen, sondern nur im Businesskatalog drin ist. Man benötigt einen Tastengrundkörper (1,20; ab 10 St. 1,10) und eine Tastenkappe nach Wahl. In den Grundkörper kann man dann noch 3mm LEDs einbauen. Ich hatte die mal bei www.farnellinone.de gekauft, die sind allerdings bei Conrad etwas billiger. Die rechteckigen Tastkappen (zB 707864 - U0 für 0,31) finde ich ganz nett und die runden transparenten sehen mit 'ner LED bestimmt auch sehr gut aus... Ansonsten finde ich es auch echt schwer, richtig gute Taster zu finden...
Hallo Kay, ich habe beide Poti-Sorten mal beim circuit-bending verwendet: Die von Reichelt fühlen sich beim drehen schon sehr billig an, da sind die Radiohm Potis mit der geriffelten Achse von Conrad deutlich angenehmer zu bedienen. Langzeiterfahrungen habe ich aber keine, denke allerdings, die von Conrad werden länger halten... Richtig gut sind die Vishay 249 von Conrad, aber bei dem Preis lohnen die sich eigentlich nur für wertigere analoge Audioschaltungen.
