Xanboroon
44 -
Everything posted by Xanboroon
Another exemple on how you can do it. If you go carrefuly, with patience, waiting a little bit before soldering two IC leads (to avoid getting the device too hot and damage it). http://www.axoris.be/MissParkerPlus/pics/AL3201.jpg ... Ok, I agree, looks like a spider with such long legs, but anyway, it works.... :P Xanboroon
Hello All, Just to inform all the guys still interrested in our projects based on the AL3101/AL3201 DSPs that we now have an daughter board adding an AL3201 DSP to the system. Edit: And for the SID fans, here are some direct links to audio samples: SID Arpeggio without effect: http://www.axoris.be/MissParkerPlus/demo/Phaser_Hall2-SID-off.mp3 SID Arpegio with Phaser and Reverb:http://www.axoris.be/MissParkerPlus/demo/Phaser_Hall2-SID-on.mp3 To refresh your mind: Miss Parker: Open-hardware, open-source multi-effect pedal based on the AL3101 DSP with USB connectivity, Miss Parker +: Daughter board with an AL3201 onboard to add reverb/delays types of effect to Miss Parker, More info, pictures, sound samples here: http://www.axoris.be/MissParkerPlus.htm BTW, the tools are also updated, check the news section on the website... For the Axoris Team: Xanboroon
Hey Moebius, Thanks for the publicity for Miss Parker, at least one guy of the uCapps forum seems to have interrest in our "almost DIY" DSP stompbox... :-) Miss Parker is indeed a good exemple of the futur of what DIY can be. All specs, schematic and layout done by our team. PCB realised by an external professional company because of the complexity. But all components soldered by someone (I means not by a machine...:-) ). Ok, I must admit to be honest that in the team we are three Electronical Engineers and that the guy who has designed the layout and soldered the components on the PCB made use of the equipment of the company where he works and he is quite good at this... See the empty PCBs: http://www.axoris.be/MissParker/pics/PCB_empty.jpg See the same PCB but with component: http://www.axoris.be/MissParker/pics/PCB_populated.jpg Looks really profesional, no ? :-) But again, like lot of people, I think SMD is not impossible to solder if you have correct tools (not all the package but some of them) ... But it's true that DIY will evolve to someting much more "professional" where you will need to train you skills. I also believe that anyway, everywhere in the world there are a lot of people with so much imagination that solutions for DIY hobbyist will anyway pop-up whatever how the technology will evolve. Modular approach with premade small modules that you can interconnect with a lot of possibilities are indeed a good solution and a step to ease the DIY for people that don't have acces to expensive tools or are not expert in soldering SMD components... Xanboroon PS: BTW, SmashTV, you can see that I'm not again premade PCBs... For instance the Miss Parker PCB is something that I'm really not enough competent to realise it myself...
I still have one remark about all these DIY/non-DIY boundaries. It seems that the friends of Vercengetorex will not solder/wire the box, but still, they will have to customise source code to fit their "customized" CS... Lot of possible problems in perspective: burning the PIC (you all know what I mean..  ;)..), download code, hours spend to read the forum to find solution, etc... means lot of time spent on the project. So, they are in fact just skipping the HW part of the project... And, for me even if it's not fully DIY project in their case, it make no difference with people that are not etching their PCBs.... People that are buying premade PCBs are also skipping a interesting part of the HW DIY project... It's also a great fun to spent time trying to etch a PCB, miss a mirror option (Tu connais ca,hein, Lall ? :-) ...), forget the board in the chemical products, and not without forgetting a really boring part: drilling all these fu***** millions holes without destroying the board :-) , etc... So, yes, where are the boundaries ? I'm trying to build a midibox since 2 years know, and I'm far from the end point... I already spend twice the money of the equivalent price of a commercial product... If sometimes during these two years I felt discouraged by the amount of work and be tempted to buy premade PCBs, I always felt that when the project will be finished and that a friend will see the "beast" saying "Wow ! Where did you buy this wonderful box ?". I can only answer proudly: "I made it myself..." if I really tried to make the maximum myself in the project.... Including etching PCB, soldering parts, frontpanel, case, etc... If buying premade PCBs or asking a friend to solder the box can help theses guys to enter ("by the small door"- french expression...) the great community of the DIY, this is not a problem for me.... Xanboroon PS: Just that I will feel more confortable if Vercengetorex  ask something else than money to these guys: A good restaurant, a "beer" party or something else would be more appropriate to fit the DIY spirit...
Thanks Thorsten !, Ok, I understand now. And the reason for the fixed direction is that for these GP buttons/LEDs we only have to specify the SR used. It's clear now. But this should not be a to big problem for our cabling problem. Once we are sure of our design we will surely publish it on the portal. Xanboroon For Rowan: We already think to this possible solution, But on this PCB there are no ICs, only Encoders, LEDs and D6 Buttons. And the problem is to solder the D6 buttons where access to the pins of the buttons from the top side will be a nightmare.
Very nice idea, I'm also interrested !!! You can put me on the list....
Salut Gilles, Au fait, sorry je n'ais pas encore eu l'occasion de t'envoyer de mail pour te confirmer que j'avais bien recu les encodeurs et te remercier encore au passage pour cette commande groupee... Et comme je passais negligement sur le forum, voila c'est fait... A+ Xanboroon
Hi pay_c, The fact is that our initial plans for the MuFFin was to use a "big" DSP like a Motorola or SHARC from AD. The AL3101 alone is a little bit to small to allow big applications. We have foreseen the possibility to extend the Miss Parker with an AL3201B to have all those "delays" based effect. But again, even with the combination of the AL3101 + AL3201B you will not be able to achieve the power of the Chameleon. The fact is that we are also already short with the ez-usb: almost 100% of ressources are used (Lall, correct me if I'm wrong on this point). So, I'm not sure that It will be possible to extend the UI with an LCD...
100 encodeurs pour moi....
Ben, c parti alors... ;) 100 encodeurs pour moi... Tu me dis combien je te dois au total et quand tu veux que je te fasses un payement paypal... Et hop... Voila pour moi... :)
Ca depend de la taille de tes doigts aussi... ;D
Salut Gilles, Tu as une petite idee de quand tu passeras la commande ? Ted, pour Paypal, vas jeter un oeil sur www.paypal.com. Tout est bien explique dans l'help... En gros resume, tu t'inscris en filant un numero visa (ou autre...) et les renseignements d'usage (adresses, etc...), puis quand tu veux payer quelqu'un tu te loggue sur leur site, tu vas dans le menu 'send money' et tu files l'adresse eMail du gars a qui tu veux envoyer de l'argent, tu precises le montant, et voila... ta carte visa sera debitee du montant... J'espere que ce resume est assez clair... :-) A+ tout le monde... A+ Xan
Kid Paddle http://kidpaddle.kidcomics.com/ Ho, yeahh... Don't forget to play to the game of the month (Sprotch Snails) http://kidpaddle.kidcomics.com/en/citygame.html# ;D
ok, pas de probleme pour le Paypal...
ok, impeccable... Je vais meme en prendre 100 pour avoir un beau compte rond... :-) En fait, La vrai raison, c'est deux potes a moi qui participent a la commande... ;-) Gilles, comme ca vas commencer a chiffrer, je suppose qui faudra qu'on paye anticipativement, dis juste combien et quand et file ton numero de compte IBAN que je puisse faire le virement... Voila, docn ca fera 100 encodeurs pour moi... A+ a tous Xan
Salut Gilles, Je serais interresse pas 80 encodeurs, mais j'habite en Belgique et j'ai cru comprendre que tu voulais restreindre la commande a la France (pour des raisons logistique, je suppose). Cela dit l'envoi vers la Belgique ne coute pas tant que ca et si tu veux je peux t'envoyer un accompte... Ma commande groupee d'encodeurs avec Pilo s'etait super bien passee donc j'imagine que ca devrait etre le cas avec celle-ci egalement... T'en penses kwa ? A+
Hi Thorsten, Ok, I found the problem... I've checked all connections on the Core... I've checked all connections on the AIN... And what did I forgot to check ?? The cable of course !!!! Pfff...Stupid guy !!! :-) Anyway, I've discover that the type of connectors/cable I've made is poor quality solution... I will definitively go to buy good connectors... Will cause less troubles... Thanks again.... Xan PS: I begin to dig into the programming with MIOS...and my god what a beautiful stuff !!! :D
Hi All, I'm currently debugging my first midibox and need your help, guys... I've build one CORE and one AIN modules. The CORE is ok, I can dowload code into the PIC with no problem all seems to be ok (display correct messages on the LCD). The problems begin to pop-up when trying to access the pots via the AIN module. I already solve the problems of the random value (the classical newbie bug... :-)). The problem is that when I try the ain_example3_v1_3 application, I can turn whatever pots but nothing happens. So I try then the ain_example1_v1_3 with a pot directly connect to RA0 on the PIC and that's working. I've checked my AIN for connections/soldering problems several times and all seems fine. I've also checked that when I move the first pot, the voltage is also moving at the pin5 of the first 4051. I've test different 4051 with no success... I begin to think that the problem come from the 4051 themselves. So, two questions: - Is the HCF4051BE a correct replacment for the CD4051 ? - How can I test that a particular 4051 is working? I would like to adress statically a particular input of the 4051 in the main of the application to test with the multimeter values at input and output of the 4051, but I'm not yet familiar enough with MIOS and PIC ASM to do this... Who can help me on this topic ? Thanks in advance Xan
Dites, RAF et p5ych0, parmis l'incroyable discographie de John Zorn, si vous pouviez me conseiller, par exemple, les dix incontournables que je pourrais me procurer, ca serait cool de votre part... Pour l'instant, du bonhome, je me rappelle juste un album de Naked City que j'avais particulierment bien apprecie je pense que le titre devait ete "radio" ou un truc du genre...
Fan de John Zorn ??... J'avais loue quelques albums de Zorn/Naked City a la mediatheque y a dja un bout de temps c'est assez bien pete comme truc, mais assez excellent... Assez dur a la premiere ecoute, faut un peu s'accrocher... J'ai lu que Naked City avait deja fait de premieres parties pour Napalm Death a une epoque... Paraitrait egalement que Zorn est interdit de sejour en France pasque lors d'un festival de jazz a Paris, il passait des snuff movies pendant son concert... Ca situe assez bien le personnage... Dis Raff, c'est toujours aussi decale comme truc Naked City ?
