sarnold
    31
About sarnold
  • Birthday 01/01/1
Contact Methods
  • Website URL
    http://www.sebastian-arnold.net
  • Gender
    Male
  • Location
    Berlin, Germany
sarnold's Achievements
MIDIbox Newbie
  1. Hi Thorsten, thanks, that sounds like an easy solution. Recompiling shouldn't be a problem, I'll try it tomorrow. Best, Sebastian
  2. Hi everybody, finally I found the time to start a project on my new LPC17 core. I want to replace my current MIDI router (PIC-based) with the MIDIbox NG application. I have MIDI devices connected to both IN/OUT ports and a computer via USB. All MIDI channels are used and need to be routed/duplicated to different ports. Here's my problem: MIDIbox NG offers only 16 router nodes, but I need at least 32 to route my channels properly. Is it somehow possible to increase the number of nodes? A different solution would be to offer a range of filtered source channels instead of single ones. E.g. could we somehow group these 5 nodes into a single one (without using "All")? ROUTER n= 1 src_port=IN1 src_chn=5 dst_port=OUT2 dst_chn=17 ROUTER n= 2 src_port=IN1 src_chn=6 dst_port=OUT2 dst_chn=17 ROUTER n= 3 src_port=IN1 src_chn=7 dst_port=OUT2 dst_chn=17 ROUTER n= 4 src_port=IN1 src_chn=8 dst_port=OUT2 dst_chn=17 ROUTER n= 5 src_port=IN1 src_chn=9 dst_port=OUT2 dst_chn=17 That would help me a lot.... Best, Sebastian
  3. update: I just tried version 2.6 and it worked with the original HEX file. thank you!! cheers, Seb
  4. thanks, I tried both 2.6U and 2.8U. both versions show the same error on the original HEX file and freeze when loading a self-compiled HEX file. strange.... Seb
  5. Hi there, I have the same problem using PBrennerNG44 and the MB Pic Burner Module. I tried rebuilding the IIC firmware, but I still get the error "Fehler bei der Bereichsprüfung.". It works well with other files. PICPgm doesn't recognize the burner, is there any other software I could try? Or could someone send me a working hex file of the firmware? cheers, Seb
  6. Great! I'm also in for: 50x 3FTL6 "Quiet" 50x 1S11.16.0 ...if you can ship these to Germany. Cheers, Seb
  7. hier ist alles gut angekommen. vielen dank! cheers, Sebastian
  8. The case is a hammond case: ( http://www.hammondmfg.com/1455V2.htm ) which I got from www.conrad.de The panel was made by Schaeffer Apparatebau. cheers, Sebastian
  9. Hi all, I just finished my compact MIDI Router. I use it for the pad-to-sample routing of my electronic drumset and/or the drumpads at my acoustic set. So I can switch songs and sounds - which neither the drum-to-midi-converter nor the sampler can do. It has 2x IIC MIDI which are connected as follows: drum-to-midi -> IN1 OUT1 -> SP404 sampler midi clock (laptop) -> IN2 OUT2 -> laptop (start/stop) I modified the C software so I can save banks (band or setup) and patches (songs) and start/stop the external laptop or sampler loop via drumpad, as well as synchronize to MIDI clock. The software is, like TK's, really adjusted to my setup, but if you want to take a look at it, I can send it to you or upload it. Because it needs to fit into a small roadcase together with the converter, sampler and monitor/click mixer, I built seperate TAE jacks into it - as you see on the last picture, no MIDI connector will fit in there ;) Some pics: My next project will be a combination box of an alternative edrum-converter, MB64 and MIDI router, because I just bought a Nord Modular G2 and need to go on the road with solo drums feat. G2 synthesizer. It's really fun! You can listen to my music at http://www.myspace.com/sebastianarnold cheers, Sebastian
  10. I'm definately in for two 20x4 (CFAH2004A-YTI-JP or CFAH2004A-YMI-JP). I'm also interested in one 16x2 (CFAH1602B-YTI-JP) and two 40x2 (CFAH4002A-TFH-JP). Thanks! Sebastian
  11. I take 8 motorfaders. I am also interested in 20 Fader Knobs (FK13'25, ribbed soft surface, without flange, black, as shown on the albs page http://www.albs.de/schieb1.htm). Thank you! cheers, Sebastian
  12. hallo hendrik, ich wäre nach wie vor auch bei einer kleinen bestellung dabei. viele grüße, sebastian
  13. took 8 (instead of 18....) Sebastian
  14. ...oder wir bestellen zusammen bei Albs.de - für 10€ bekommen wir die dort zwar nicht, aber sicherlich auch in der Menge relativ günstig. Viele Grüße, Sebastian
  15. Hi Hendrik, ich wäre auch mit 18 Stück dabei. Plane eine LC im Verlauf dieses Jahres, also komm einfach per PM auf mich zurück, wenn die Bestellung greifbar wird. Viele Grüße aus Berlin, Sebastian
