456 -
About Phattline
- Birthday 01/01/1
Contact Methods
Website URL
http://www.phatline.at/
Gender
Male
Location
AUSTRIA-ongreenhillsinahouseinastudioohitsgreat
Recent Profile Visitors
Phattline's Achievements
MIDIbox Tweaker (3/4)
what are td sequences? do you want to jam aka simple looping... or more detailed seq programming with parameter automations?
ok forget the light... seqv4 wilba cs then... the light has only 2 tracks.
edit i also have a seq4light here
dimensions: length: 66cm twogether. 76cm with trackposition display. widh seq: 12.5cm width wilba cs sid 16.5cm make picture of that at night...need my cam for time lapse fotos at moment... about money i need some time to calculate hardware costs. about work time and the cost of that: it depends on the finished concept edit... logged in on my cellphone... on the false account... i am the same human ;)
not specially in mb ng... i would write my own mios based code.... i dont want to waste midi io on my core32 is a other connection then midi to the mf module possible? if yes are there any drawbacks? or what are the pros and cons. and what if i have to use more then one mf module is the this solution then cascadeable thx mike
Phattline changed their profile photo
12h we have jamed with our new setup, when my friend went home I jamed alone a 3,5h session - and here we are: the jam is splittet in 4 320Kbs MP3s on my hi-speed server: www.phatline.at/GratefullTEK-20110507-05-20110507-05-phatty.mp3 www.phatline.at/GratefullTEK-20110507-06-20110507-06-phatty.mp3 www.phatline.at/GratefullTEK-20110507-07-20110507-07-phatty.mp3 www.phatline.at/GratefullTEK-20110507-08-20110507-08-phatty.mp3 Style: techno (tekkno), tribal, schrantz, ritscheratsche, ÖSTERREICHISCH "ZUASTAUNDSOUND" Style²: technical limited monotone hypno sound with constant sound morph it is when we only look @ the interface (left behind max msp ableton) a classical drummachine setup, with new elements classical: stepsequencer - new: 16x8 steps overview/access with 3 colour Accents and powerfull editing operations classical: one shot sampler - new: "electribe R-Style" motionsequencer for all drumtracks Classical: one shot sample banks - new 1000ends of them without space problems on ssd-hds classical: total controll (drumcomputers) - userdefied controlls and finetune for that >>> I use Ableton as one powerfull drummachine The Setup consists off: Quadcore 64bit PC (for the jamin itself- no Monitor, mouse, or keyboard is needet) 2x BCR2000 2x LP 1x APC 1x RME Multiface II Ableton 8.2.1 with simply delay, reverb, and EQ8, the rest is: MaxMSP & Max4Live - self programmed devices: LP-Stepsequencer, Oneshotsampleplayer with APC controllsourface and Parametersequencer for all Parameters, midi efx like midiroll, mididelay, velocity kill, and so on - it might be not 100% perfect because i jamed without any cue, monitoring and so on, but for that -other tekknos said- " its very good, and with some uppimp and overwork it would be "saugeil""
ich würd ja mal den funktionierenden sid raustun, und hören ob du noch immer leiser was hörst (nicht das das leise der funktierende ist- um das mal auszuschließen) wenn noch immer leise was da ist, würd ich mal die ausgangsstufe hinterm sid die leiterplatte durchmessen, die paar bauteile auswechseln (viele sinds ja nicht, ein transistor kondensator usw) und sonsten prüfen ob alle spannungen da sind, dazu mal bei der Beschreibung zum Core modul (aubau tutorial) zu rate ziehen und mit voltmeter mal beim PIC-Socket und dem SID-Socket messen ob alles da is.
MB64E, LC(Motorfader), MBBLM werden dann auch auf der Dieser LPC17 laufen?
YESS da tut sich ja ne menge>>> MBHP_CORE_LPC17 >>> OSC, ETH, im handel verfügbares core, RESPEKT!!! THANKZ FOR THAT ONE!
Anyone interested in Alps "N" type motor faders?
Phattline replied to Doug Wellington's topic in Bulk Orders
:sorcerer: They are here -THANKZ!!!!!!!!! -
2 months later... :sad: -
Ok I dont have much time because of a new house... but here is a try: SEQUENCER: max4Live plugin: SQ-BLM-V0.5.amxd.7z max Collective: SQ-BLM-V0.5.mxf.7z max plug: SQ-BLM-V0.5.maxpat.7z CONVERTER: BLM-2-Max-V1.0.maxpat.7z BLM-2-Max-V1.0.maxpat.7z SQ-BLM-V0.5.amxd.7z SQ-BLM-V0.5.maxpat.7z SQ-BLM-V0.5.mxf.7z
no i did not... ...but now yes... WHY? Dou you meen because of: It uses Pages - Vertical and Horizontal? I also use pages... in the Moment I use a APC 40 and a Launchpad - and that show me 8Steps x 13 Rows (in RGB) But with 8 Steps I dont have the oversight of a long Mididrumloop - Pageswitching - Is OK and a Workaround - But the More steps you see, the less you have to memory in your brain, the less you have to memory the easier is the JAM :D >>> as soon I have working beta I post it. -
CONVERTER I have wrote a Midi-OSC "Near" CONVERTER, it supports 2 BLM Emulators - to get to my 32x16 Steps. I have attached a *.zip, that contains the Converter as Max MSP Collectiv(*.mxf no editing)and also the complete Patch (*.maxpat)(for editing) A free MAX-MSP Runtime/or the full 30days DEMO you can download under: http://cycling74.com/ If you want run this Patch you will need 1 or 2 BLMs or: 1 or 2 BLM EMULATOR instances (download under: http://www.ucapps.de/midibox_seq_manual_blm.html) If you drive the Virtual BLMs instead of Reals, and your OS is WIN7 you will need a "Virtual Midicable" - install and reboot > MIDIYOKE: http://www.midiox.com/ Notice: you need 4 Midiyoke ports, if you dont have 4 you must setup midiyoke in win7 systempreferncys... If you have all that, now start the attached MAXPAT.... I have documented the patch in the patch (follow the blue texts) Also a example Patch is includet which reacts to button pressings of virtual BLMs (i dont have a real @ this time...) But also pressings on the Virtual MAX MSP Matrix will light your BLM Emulation. So that is the first step - converter > done! And Adaption was no problem... Next step is to build a Max Drumsequencer for that BLM Emulation, if that work good and right, i will build like TK said 2x 2x16 Matrixes with seperatet cores. If the drumsequencer is ready or in working beta status, i will post and attache it here. have a nice weekend! BLM-2-MAX-Converter.zip
THANKZ THANKZ THANKZ - that is enough Info to get it started. lg mike
