titan
83 -
Everything posted by titan
Thanks,i will wait for that before letting drill my CS in order to build all in one case! I m impatient ;)
Do you already know if the DOUT will receive a dedicated MATRIX on the CS? Any news about the additional knobs for 303 emulation? Best Regards Titan
...&Force [Rollercoaster @ Phantasialand] :P
Look on ebay, i know that few years ago steinberg sold midi interfaces for serial link. For example: http://cgi.ebay.nl/ws/eBayISAPI.dll?ViewItem&category=171&item=5112606649&rd=1&ssPageName=WD2V you have mac or pc?
With 5V and 10V its strictly impossible to have 18 V . Maybe the Ground of the voltage regulator isnt connect correctly or something like that? ??? :o
Because servo tracks are controlled by an electronic (pulsewidth) For controlling servos you must permanently send every 20ms a signal PWM. But i m not expert with that, maybe im wrong...
Take a look on: http://catchpole.net/sidrack.html There you can read this : " You could leave the chip inside a Commodore 64, but that introduces a host of problems. The data bus the chip sits on is quite noisy. This contributes to overall signal noise. The 64 and its power supply are not so robust or portable. You would also need to write some kind of C64 cartridge or ROM, attach a Midi Interface and then hope your vintage C64 doesn't fail. It's usualy better to just find a different controller, especialy if you want to use 2 or more SIDs" Its easier to make a little core and sid module (PCB available finished)
You surely will find some time to build a core and a sid module. Hey thats the occasion for having experience. Thats why this forum exists. The explanations on the Site are very good and here are a lot of persons who can help you troubleshooting. Good Luck TiTaN
An der Schaltung mag es wirklich nicht liegen.Wenn du den Schleifer berührst geht es?? Da muss ich ne Nacht drüber schlafen ??? :o ;)
Das kann an vielem Liegen aber bei Konrad gibts Kaltgeräte Buchsen mit Entstördrosseln , oder halt ne externe Entstördrossel dranpacken. Sonst könnte auch sein dass eine Abschirmung wunder wirkt. d.h. Isolierte Alufolie die auf Masse liegt (Isoliert da sont Kurzschlussgefahr)zB
Hallo Hmm hast du es schonmal mit einem größeren Poti versucht? 100 k oder so? Ich kann mir das im Moment echt nicht erklären warum das rumspinnen soll?! Ich habe das leider nur in Verbindung mit anderen Mikrocontrollern getestet aber das Prinzip des Analogen Eingangs ändert sich ja nicht... Versuch sonst auch mal einen relativ kleinen (100ohm) widerstand noch zwischen schleifer und taster zu schalten...Dürfte nix ändern aber man weiss ja nie... Denn wenn du den Schleifer auf 5 V legst ist es ja das selbe als ob du den Schleifer auf 100 Prozent hast . ??? Ich bin etwas ratlos, sorry
Not on POTX/POTY on the sid module?????
Très bizarre. Tu as fais le loop back avec un sysex? Et tu recois autant de bytes que tu as envoyé ? [Fais attention au reglages midi dans midi ox] Le message n'est pas normal en tt cas..Essaye de modifier les réglages dans midi ox du sysex [delay etc..]
Ab wann genau? wenn du den Taster loslässt? Schaltungtechnisch ist das absolut richtig.hmm funzt es denn richtig wenn der Fader auf 98-99% war? versuch das mal.. Bis bald ;)
Beim selbstcompeilen steht in der Erklärung was von MSDOS EINgabefenster. Prinzipiell brauchst du zum draufspielen der software kein msdos. XP läuft also auch (Beim IC PROG bitte patch installieren!!) BEi konkreten Fragen einfach fragen! ;D ;)
If you take a look on the data sheet of the 6581 you will see that on PIN 23 and pin 24 you can connect potentiometers. On the sid module these PIN'S[POTX/POTY] are left free. I don't know exactly which parameter you can change with that.
Non , de tt facon ca sert à rien si to midi in ne marche pas. Enlève un peu le PIC et essaye de faire un loop back. Il y des instructions dans "troubleshooting" http://www.ucapps.de/howtodebug/mbhp_core_extract_io_loopback.gif Ainsi tu envoyes des données de l'ordi et celui ci recois les mêmes données(RX E TX connectés ensembles) Ainsi tu peux savoir si c'est pas :ton ordi ou ta connexion midi qui foire. Ah oui et enlève la led midi in / out aussi, essaye de connecter un minimum, et regarde si le core envoye tt les 2 socondes un message sysex? Essaye dejà ca...
Le mieux c'est de raccorder uniquement un écran LCD car oui à mon avis le MIOS n'est pas dessus :o
Ich habe XP und das läuft... ;)
