phonaut
23 -
Everything posted by phonaut
The red color lcd is a good idea. Maybe i can modify the existing one by changing the led's?
@Sinnsyk The wooden case (mdf) is handmade by myself used a Saw, a Hammer a rasp and sandpaper. At last i varnished it 5 times. As SLP said, the frontpanel is made by Schaeffer. I decide to design a very cost-effective panel, by using black aluminium. So it is not necessary to fill the letters with color. As you can see i use just short words like "Fltr" and lines an letters used the same stylus. So Schaeffer don't need to change the tool. The backpanel is also made by Schaeffer. @audiocommander i like the smooth red colored led's ;) The last parts missing are the mounting-screws for the panels because i cant find allen-screws for the wooden case. My 2 electribes uses such screws but i dont want to cannibalize it from there ;) Regards Phonaut
Ableton Live! :) Sollte evtl. extra aufgeführt werden. Phonaut
Huhu, ich hab am Wochenende das neuen MIOS auf meine MB-SID gespielt. Zum convertieren habe ich das hex2syx perlscript aus dem mios-quellcode 1.9 genommen. Das hat Thorsten hier auch irgendwo im Forum geschrieben. Funktioniert super. perl hex2syx.pl applikation.hex -device_id 0x00 (0x00 für das Master-Modul, 0x01-4 für die Slaves) Gruß Tino
thanks for all the answers, but i don't found the screw. Just in the Size 4.8 mm at http://www.online-schrauben.de/ So i decided to use an ordinary screw with an round head. thanks a lot Tino
Hi, anybody know where i can find such: (inbus)-screws? (in german Inbusschraube) Diameter: 3 mm It is used in the Korg Electribe Series for the frontpanel. I need this screws for the frontpanel of my MB-SID and don't want to buy some electribes to cannibalize it ;) Greetings Phonaut
Huhu, habs grad durch probieren rausgefunden :) für den lfo: midisync an: 1/16 entspricht einer Rate von 67 1/8 entspricht einer Rate von 88 1/4 entspricht einer Rate von 112 ;D Gruß Tino
Huhu, danke für die schnellen Antworten Thorsten, so richtig ist das aber noch nicht was ich suche. ich versuchs noch mal genauer zu erklären (wie in der erkärung hab ichs am wochenende an nem virus a probiert): dort kann ich einstellen, aller wieviel takte die lfo-wellenform einmal komplett duchlaufen wird. also man kann dor 1/8 bzw 1/16 usw als midi-clock-sync für den lfo einstellen. jetz fehlt mir allerdings noch das verständnis wie genau der sync bei der mbsid funktioniert. wie genau wird der lfo zum midiclock gesynct? bedeudet da die rate auch, aller wieviel beats die lfo-wellenform einmal komplett durchlaufen wird ??? Gruß Tino
Hi Thorsten, danke für den Tip, an den Wavetable hab ich noch gar nicht gedacht, damit kann man seinen arp ja auch viel flexibler zusammenbauen. Was meinst du, könnte das auch für den lfo gehen? Wenns relativ einfach ist, würd ich mich mal dran setzen. Gruß Tino
Hallo, so auf die schnelle hab ich zu dem Thema jetz nix gefunden, deswegen ein neuer Thread: Meine Midibox-SID nähert sich langsam aber sicher der Vollendung. Mit jedem Eingabe-Modul was fertig wird, probiere ich erstmal ein Weilchen rum, was es so neues bringt :) Nun zu meiner eigentlichen Frage: Ist es möglich dem Arpeggiator/LFO mit der MIDI-Clock zu syncen, so das man zum Beispiel über den Rate Knopf einen bestimmten Teiler/Multiplikator zum Clocksignal einstellt? Beim LFO ist es ja mit probieren möglich, aber recht aufwendig. Under der Arp ist mir stellenweise ein wenig zu schnell. Wenn ihr mir ein paar Tips geben könntet, wo sich was befindet, schaue ich mal selbst in den Quellcode. viele Grüße Tino
Hallihallo, mal etwas am Thema vorbei, aber heut hat die postfrau einen weiteren C64 vorbeigebracht. da wird dieses wochenende der 2te sid fertiggelötet. Diesmal wird hoffentlcih alles beim ersten mal klappen :) Tino
Hallihallo :D heut ist mein ersteigerter c64 angekommen, da hab ich gleich den sid ausgebaut, in meine midibox eingebaut und, es geht :D und ich bin total überwältigt vom klang, kein brummen und so und ein einzelner sid klingt ja schon unheilmlich fett, wow da kann ich ja schon mal die zweite platine aufbauen, und nächste woche erklingen dann derer zwei *juhu* bis denn Tino
Hallo, ich habe gerade mal den sid direkt am mixer angeschlossen mit einem Kondensator dazwischen, es klingt wie vorher. Somit scheidet der verstärkerteil auch aus. Da ist wohl der sid kaputt :( Wenn der SID drausen ist höhre ich nix, wenn der pin#27 auf masse liegt auch nicht. Aber ich habe gerade die Versandbestätigung für den nächste C64 erhalten. Vielleicht wirds ja diese Woche noch etwas :) bis denne Tino
Hallihallo, erstmal herzlich wilkommen im Forum. Als AU läuft das Programm leider noch nicht, dafür aber erst mal als stand-alone version. Die CC werden schon richtig gesendet. Zur Zeit habe ich aber noch Probleme meinen SID zum funktioniren zu bewegen. Solange wird erst mal ncih weiterprogrammiert. (Und das SDK von Urs Heckmann läuft leider noch nicht bei mir) Sobald die Funktionen besser ausgebaut sind werde ich es hier zur Verfügng stellen.
Hi, ich bekommen diese Woche 2xC64 geschickt (bei ebay ersteigert), anhand derer kann ich dann den sid probieren. Aber vorher werd ich noch mal Thorstens Ratschlag befolgen ud den SID direkt an den Mixer anschliessen. Ich denke dass der SID wahrscheinlich eh kaputt ist, da kanns ja nicht mehr schlimmer werden. 2 neu SID-PCB's und noch ein CORE-PCB's sind ebenfalls bestellt. Die werden dann neu aufgebaut und mit dem C64 Netzteil versorgt. Ich hoffe dass diesmal alles glett geht. Ich glaub ich werd auch alles 3-fach prüfen und den Interconn-Test machen bevor ich dann da nen SID reinbaue. Tino
Huhu, jetz habe ich mal alles andere vom mixer abgemacht, das brummen ist immer noch. ich habe auch mal den quartz rausgebaut und den sid mit dem pic verbunden (sid#6(clk) zu pic#17(RC2)) klinkgt genauso wie vorher. wenn ich den clock trenne, macht er gar nix. d.h. das der quartz erst mal funktioniert. das audoteil nach dem sid habe ich gestern noch mal geprüft, und alle kondesatoren neu eingelötet (bei den beiden elko's c5 und c6 zeigt das plus zum sid), nix. das einzige was mich noch verwirrt ist der transistor. auf thorstens pdf steht bei 12V ein T1, das ist nach der pinbelegung (und dem bild der einbaurichtung auf dem gif) der collector. demzufolge ist das was vom sid kommt die basis und das was zu j3 der emmitter. ist das so richtig? nud auf meinem transistor steht statt bc547c --> cbc547c gruß Tino
Hallo, einen bankstick habe ich nicht dran. zur netzteilkonfog: ich habe ein netzteil, mit dem das core-modul und das sid-modul betrieben wird. das midisignal kommt aus nem midisport 2x2 bzw. aus meiner electribe. bei beiden brummt es. das audiosignal geht in den behringer-mixer rein, an dem auch die electribe und der laptop dran sind. kommt es da zu einer masseschleife durch die ganzen verbindungen? werd ich dann gleich mal probieren (alles andere vom mixer ab) den quartz werd ich dann auch mal rausbauen und den sid direkt takten. ansonsten hab ich mir heut einen weitern c64 ersteigert, diesmal mit netzteil. wenn es ankommt wird die vom thorsten empfohlene schaltung aufgebaut. bis denne Tino
hi fabian, was passiert eigentlich, wenn der transistor verkehrt eingebaut ist, kann das zu solchen brummen kommen? das mit dem quartz werd ich mal versuchen. bei der au-programmierung hab ich erst mal ein stand-alone applikation gebaut, mit der die ganzen midi-controller steuern kann. die drehknöpfe funktionieren aber noch nicht richtig, da sie keinen anschlag haben, wenn das sdk von urs erst mal läuft, dann ist das auch behoben. wenn du willst kann ich dir ja mal die aktuelle appl. schicken. was nutzt du eigentlich für ein programm um denn midi-datenstrom anzuzeigen? midiox gibts auf dem mac ja nicht. ich nehme bis jetzt sysex librarian. Tino
Hallo, jetz hab ich mal den interconnection-test gemacht. es hat alles funktioniert. eine unregelmäßigeit ist mir aufgefallen, wenn ich den modulation-value 14 sende wird cs# = 0 V, D7 bleibt aber bei 5V, somit hat D5 bei 0-12 0V und bei 13-14 5 V. ist das so normal? da kann es ja jetz nur noch am audioteil oder am sid liegen? oder vielleicht der quartz? Tino
Huhu, gibts denn hier im Forum einen Midiboxbastler aus Braunschweig oder Umgebung (Dresen würde am Wochenende auch noch gehen) bei dem ich mal meinen SID testen kann bzw. der sich mal meine module anschaut? Tino
Hi Fabian, danke für die schnelle antwort, den link sid zu core habe ich angepasst, nun kommen wenigstens ein paar mehr töne raus, auch wenn sie noch sehr weit vom sid entfernt sind. Ich habe ein sehr starkes brummen im vergleich zu den samples auf ucapps. kann das an meinem netzteil liegen oder kommt sowas auch von der verbindung sid-core. Ausserdem habe ich kurz nach dem anschalten ein langen pfeifenden ton, bis der pic sysex daten sendet. Wenn ich alles ohnen midiverbindung zum computer betreibe, habe ich ein rythmisches geräusch(aber erst nach 2 sek, bis der pic gebootet ist). ich bin echt am verzweifeln. Tino
Huhu, nachdem ich mir vor 3 Jahren schon mal ne 16er Midibox gebaut habe, war mal wieder was zu basteln dran. Diesmal eine Midibox SID. Das pcb habe ich mir bei mike (vielen dank für die schokoriegel :) ) bestellt. Den C64 bei Ebay. das habe ich nun alles zusammengebaut. Die Spannungen geprüft, alles in Ordnung(core 5 V und sidmodul 9 v). Die Verbindung Core zu SID ist auch i.O, alle Kontakte funktionieren und es gibt keine Kurzschlüsse. Auf den Pic hab ich mios_1.7 draufgespielt. dann noch die SID applikation (erst setup_8580_without_cs.syx und dann main.syx) und zum schluss noch ein paar presets (midibox_sid_presets_8580.syx) wenn ich das ganze anschalte, bekomme ich auch ordentlich sysex daten zurück (kann ich bei bedarf ja mal posten) dann das sidmodul dran und ein paar noten gespielt, nix, ausser ein brummen (wenn man genau hinhört, dann kommen schon irgentwelche töne, wenn eine note gespielt wird, das hat aber nix mit dem originalen sid-sound zu tun) mir ist aufgefallen das der sid-chip ziemlich heiss wird (es ist ein 8580R5) Testen konnte ich ihn vorher leider nicht, da der c64 ohne netzteil war. ich verwende ein steckernetzteil, mit 12V und 500mA. die platinen habe ich genau nach liste bestückt. ach so, die 74hc595 sin von unterschiedlichen firmen, macht das was? an manchen stellen habe ich schon gelesen, das man den einen oder anderen wiederstand weglassen kann, welche sind das genau? oder ist vielleicht der sid kapput ??? oder muss ich nur beim spielen erst mal ne bank anwählen, damit er weis was er zu tun hat? und ich hab mich so auf denn sound gefreut, viele Grüße Phonaut
Huhu, ich bin gerade dabei, mir eine MIDIBox SID zu bauen. :D Da ich mir vorerst die einfachste Version bauen möchte, wollte ich mir ein Audio Unit zusammenbasteln, um die ganze Sache zu steuern. (ich weis, ein Logic Environment würde auch gehen(bzw gibt es ja schon vom Thorsten), aber es soll auch unter Ableton nutzbar sein). Hat jemand Ahnung wie ich damit am besten anfangen kann? bzw. welche Tools von nöten sind. Gibt es sowas wie den vst Progrmmierer nur für nen Mac und AU? Phonaut EDIT: suchen Hilft, ich hab gerade was brauchbares vom Meister him self: Urs Heckmann, und direkt bei apple gefunden. Ich werd euch auf dem laufenden halten.
