LX
45 -
Everything posted by LX
menu enc problem solved :D I set menu enc to SR#16 and its ok. problem with buttons solved - I didnt know about sysex setup MK_syx ::) there I set all buttons by my way. But I dont still understant how work Patches and Banks :-\ Im right if I think that Bank is complete setup of MK_SYX - midibox64.syx When I want save my MK_syx bank in bankscick I must upload it to core via midi and than copy from core to some place in bankstick by core menu settings. What is mean patch? this is only midi event setting? thanks for reply B.R. LX
HW problem solved :) but I have still problem with setup :( This is my map of SR: SR: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 DINs: o--o--o--o--o--o--o----o----o--o--o--o--o--o--o--o (---- Note 56x -----) (Menu) (----- ENC 30x -------) SR: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 DOUTs: o--o--o--o--o--o--o----o----o--o--o--o--o--o--o--o (---- Note 56x -----) (Menu) (---- LEDRings 30x ----) Here is definition from main.asm ; MIOS Application ; MIDIbox64E ; ; #ifndef SEPERATE_SETUP_FILE ; Hardware related setup: ; ; Number of connected encoders: 1-64 #define DEFAULT_NUMBER_ENCS 30 ; number of connected encoders ; NOTE: the encoders have to be assigned to the DIN pins in mios_tables.inc ; ; Width of a group - normaly matches with the number of connected encoders, but ; the MB64E_LCD_PrintGroupNumber function in mb64e_bank.inc only supports ; group widths which are a power of two (1, 2, 4, 8, 16, 32, 64) #define DEFAULT_ENCODER_GROUP_WIDTH 4 ; Number of connected buttons ; Allowed values: 1-64 #define DEFAULT_NUMBER_BUTTONS 64 ; number of connected buttons ; ; debounce counter (see the function description of MIOS_SRIO_DebounceSet) ; Use 0 for high-quality buttons, use higher values for low-quality buttons ; NOTE: with a value > 0 the ledrings will flicker on every button movement! #define DEFAULT_SRIO_DEBOUNCE_CTR 0 ; ; ; A difficult decition: define here if you want to store many banks or many patches ; in the (optional) BankStick(s). ; - Bank based (PATCHMODE 0): 8 complete configurations are stored in each BankStick ; - Patch based (PATCHMODE 1): 1 configuration bank and 128 patches are stored in each BankStick #define DEFAULT_PATCHMODE 0 ; ; Chip Select Number of BankStick which should be used: ; -1: allows the MIDIbox to address up to 8 BankSticks (-> 64/8 Banks) ; 0: the MIDIbox addresses only the BankStick with CS=0 (-> 8/1 Banks) ; ... ; 7: the MIDIbox addresses only the BankStick with CS=7 (-> 8/1 Banks) ; all others: don't use any BankStick ; ; * -1 is the most prefered choice, also when only one BankStick is connected. ; * specify a CS number 0...7 when you are using different Applications ; with your MIDIbox in order to assign a dedicated EEPROM to it. ; * specifiy any other number to disable BankStick support at all #define DEFAULT_BANKSTICK_CS -1 ; ; Channel which is used to send a program change event on bank changes ; and to listen for bank change requests ; Allowed values: 1-16 #define DEFAULT_BANK_PRG_CHNG_CHANNEL 16 ; ; Channel which is used to send a program change event on patch changes ; and to listen for patch change requests ; Allowed values: 1-16 #define DEFAULT_PATCH_PRG_CHNG_CHANNEL 15 ; ; here you can change the default device ID #define DEFAULT_DEVICE_ID 0x00 ; ; if this option is enabled (1), the DEFAULT_DEVICE_ID won't be used, but ; it will be automatically derived from the MIOS Device ID instead #define DEFAULT_AUTO_DEVICE_ID 1 ; ; For MIDI activity monitor: define the DOUT pins for the Rx and Tx LED #define DEFAULT_MIDI_MONITOR_ENABLED 0 ; if 1, the Tx/Rx LEDs are enabled #define DEFAULT_MIDI_RX_LED 0x40 ; DOUT SR#9, pin D0 #define DEFAULT_MIDI_TX_LED 0x41 ; DOUT SR#9, pin D1 ; ; --> define the DOUT registers which are connected to the LED rings here: ; --> the shift registers are counted from one here - means: 1 for the first, 2 for the second, etc... ; --> please mark unused ledrings with 0 #define LEDRINGS_SR_ENC1_16_CATHODES_1 9 ; first shift register with cathodes of the first 16 LED rings #define LEDRINGS_SR_ENC1_16_CATHODES_2 10 ; second shift register with cathodes of the first 16 LED rings #define LEDRINGS_SR_ENC1_16_ANODES_1 11 ; first shift register with anodes of the first 16 LED rings #define LEDRINGS_SR_ENC1_16_ANODES_2 12 ; second shift register with anodes of the first 16 LED rings #define LEDRINGS_SR_ENC17_32_CATHODES_1 13 ; first shift register with cathodes of the first 16 LED rings #define LEDRINGS_SR_ENC17_32_CATHODES_2 14 ; second shift register with cathodes of the first 16 LED rings #define LEDRINGS_SR_ENC17_32_ANODES_1 15 ; first shift register with anodes of the first 16 LED rings #define LEDRINGS_SR_ENC17_32_ANODES_2 16 ; second shift register with anodes of the first 16 LED rings #define LEDRINGS_SR_ENC33_48_CATHODES_1 0 ; first shift register with cathodes of the first 16 LED rings #define LEDRINGS_SR_ENC33_48_CATHODES_2 0 ; second shift register with cathodes of the first 16 LED rings #define LEDRINGS_SR_ENC33_48_ANODES_1 0 ; first shift register with anodes of the first 16 LED rings #define LEDRINGS_SR_ENC33_48_ANODES_2 0 ; second shift register with anodes of the first 16 LED rings ; #define LEDRINGS_SR_ENC49_64_CATHODES_1 0 ; first shift register with cathodes of the first 16 LED rings #define LEDRINGS_SR_ENC49_64_CATHODES_2 0 ; second register with cathodes of the first 16 LED rings #define LEDRINGS_SR_ENC49_64_ANODES_1 0 ; first shift register with anodes of the first 16 LED rings #define LEDRINGS_SR_ENC49_64_ANODES_2 0 ; second shift register with anodes of the first 16 LED rings ;; see the documentation of MIOS_ENC_SpeedSet for the purpose of these values #define DEFAULT_ENC_SPEED_NORMAL_MODE MIOS_ENC_SPEED_NORMAL #define DEFAULT_ENC_SPEED_NORMAL_DIV 0 #define DEFAULT_ENC_SPEED_SLOW_MODE MIOS_ENC_SPEED_SLOW #define DEFAULT_ENC_SPEED_SLOW_DIV 6 ; (6: increment on every 7th step) #define DEFAULT_ENC_SPEED_FAST_MODE MIOS_ENC_SPEED_FAST #define DEFAULT_ENC_SPEED_FAST_DIV 2 ; (2: divider = 2^(7-2) = 32) ; This DIN map allows you to customize the MB64E application to different hardwares ; The MB64E dump structure allows the use of up to 64 buttons, they are grouped to 8 buttons per shift register ; Define the used shift registers for the buttons here ; the shift registers are counted from one - means: 1 for the first, 2 for the second, etc... ; mark unused button groups with 0 ;; NOTE: by default, the first two DIN shift registers are used for the encoders #define DEFAULT_DIN_SR_PIN_01_08 1 #define DEFAULT_DIN_SR_PIN_09_16 2 #define DEFAULT_DIN_SR_PIN_17_24 3 #define DEFAULT_DIN_SR_PIN_25_32 4 #define DEFAULT_DIN_SR_PIN_33_40 5 #define DEFAULT_DIN_SR_PIN_41_48 6 #define DEFAULT_DIN_SR_PIN_49_56 7 #define DEFAULT_DIN_SR_PIN_57_64 8 ; ; Datawheel for menu navigation/data entry connected or not? ; A datawheel can replace the left/right buttons! ; if 0: datawheel not connected ; if >= 1: encoder number assigned to datawheel function ; don't forget to check the pins of the datawheel in MIOS_ENC_PIN_TABLE (-> mios_tables.inc or setup_*.asm) ; it has to be connected to pin 4 and 5 by default #define DEFAULT_ENC_DATAWHEEL 30 ; ; DIN pin numbers of menu buttons #if DEFAULT_ENC_DATAWHEEL == 0 #define DEFAULT_DIN_MENU_EXEC 1 ; menu exec button assigned to DIN pin #7 #define DEFAULT_DIN_MENU_RIGHT 2 ; menu right button assigned to DIN pin #6 #define DEFAULT_DIN_MENU_LEFT 3 ; menu left button assigned to DIN pin #5 #define DEFAULT_DIN_MENU_SNAPSHOT 4 ; menu snapshot button assigned to DIN pin #4 #else #define DEFAULT_DIN_MENU_EXEC 58 ; menu exec button assigned to DIN pin #7 #define DEFAULT_DIN_MENU_SNAPSHOT 59 ; menu snapshot button assigned to DIN pin #4 #define DEFAULT_DIN_MENU_RIGHT 56 ; NOT USED - overlayed by datawheel #define DEFAULT_DIN_MENU_LEFT 57 ; NOT USED - overlayed by datawheel #endif ; ; This DOUT map allows you to customize the MB64E application to different hardwares ; The MB64E dump structure allows the use of up to 64 LEDs, they are grouped to 8 LEDs per shift register ; Define the used shift registers for the LEDs here ; the shift registers are counted from one - means: 1 for the first, 2 for the second, etc... ; mark unused LED groups with 0 ;; NOTE: by default, the first four DOUT shift registers are used for the encoders #define DEFAULT_DOUT_SR_PIN_01_08 1 #define DEFAULT_DOUT_SR_PIN_09_16 2 #define DEFAULT_DOUT_SR_PIN_17_24 3 #define DEFAULT_DOUT_SR_PIN_25_32 4 #define DEFAULT_DOUT_SR_PIN_33_40 5 #define DEFAULT_DOUT_SR_PIN_41_48 6 #define DEFAULT_DOUT_SR_PIN_49_56 7 #define DEFAULT_DOUT_SR_PIN_57_64 8 ; ; ; Some menus are providing the possibility to use 16 "general purpose" buttons ; for selecting a parameter - e.g. the Bank Select menu allows to directly change the ; Bank with these buttons. So long as you stay in this menu, the normal function of ; these buttons (triggering MIDI or SFB events) is disabled ; Define the two shift registers which are assigned to this function here: ; 0 disables the GP buttons (not recommented!) #define DEFAULT_GP_DIN_SR0 0 ; first GP DIN shift register assigned to SR#2 #define DEFAULT_GP_DIN_SR1 0 ; second GP DIN shift register assigned to SR#3 ; ; above these buttons LEDs should be mounted to visualize the selected parameter ; (e.g. to visualize the bank which corresponds with the buttons below) ; Define the two shift registers which are assigned to this function here: ; 0 disables the GP LEDs (not recommented!) #define DEFAULT_GP_DOUT_SR0 0 ; first GP DOUT shift register assigned to SR#5 #define DEFAULT_GP_DOUT_SR1 0 ; second GP DOUT shift register assigned to SR#6 ; ; with following settings it is possible to center the screen on 2x20 and 2x40 LCDs ; see also the functional description of MIOS_LCD_YAddressSet ; recommented values: ; 2x16 | 2x20 | 4x20 | Comments ; -----+------+------+---------- #define DEFAULT_YOFFSET_LINE0 0x00 ; 0x00 | 0x02 | 0x42 | cursor pos: 0x00-0x0f #define DEFAULT_YOFFSET_LINE1 0x40 ; 0x40 | 0x42 | 0x16 | cursor pos: 0x40-0x4f #define DEFAULT_YOFFSET_LINE2 0x14 ; 0x14 | 0x16 | 0x02 | cursor pos: 0x80-0x8f (not used yet) #define DEFAULT_YOFFSET_LINE3 0x54 ; 0x54 | 0x56 | 0x56 | cursor pos: 0xc0-0xcf (not used yet) ; ; The morphing function uses addresses within the MIOS address range which are ; reserved for the AIN handler. ; NOTE: morphing is automatically disabled if analog pots/faders are connected #define DEFAULT_MORPH_FUNCTION_ENABLED 0 ; ; Although MIDIbox64E has been designed for rotary encoders, it can also handle with ; up to 64 pots/faders or up to 8 motorfaders. ; Pots and faders are mapped to the "encoder" entries 64-128. ; Example: if group width is 16, and group 1 is selected, encoders are using ; entry 1-16, and pots are using entry 64-70 ; NOTE: morphing is automatically disabled if analog pots/faders are connected #define DEFAULT_NUMBER_AIN 0 ; ; you could enable the multiplexers here to test this application ; with a MIDIbox64 based hardware ; if 0: no multiplexers (a *must* when MF module connected) ; if 1: use multiplexers #define DEFAULT_ENABLE_AIN_MUX 0 ; ; motorfaders connected? ; if 0: MF module disabled ; if 1: MF module enabled #define DEFAULT_ENABLE_MOTORDRIVER 0 ; ; The well known motorfader calibration values -- can also be changed "online" in the calibration menu #define DEFAULT_MF_PWM_DUTY_UP 0x01 ; PWM duty cycle for upward moves (see http://www.ucapps.de/mbhp_mf.html) #define DEFAULT_MF_PWM_DUTY_DOWN 0x01 ; PWM duty cycle for downward moves (see http://www.ucapps.de/mbhp_mf.html) #define DEFAULT_MF_PWM_PERIOD 0x03 ; PWM period (see http://www.ucapps.de/mbhp_mf.html) ; ; ; following settings configure the touch sensors ; The DIN shift register to which the 8 touch sensors are connected has to be defined here ; Shift Register 9-16: touch sensor changes won't trigger the MBMF button handler ; no MIDI event will be sent ; Shift Register 1-8: touch sensor changes will trigger the MBMF button handler ; 0: touch sensor disabled #define DEFAULT_TOUCH_SENSOR_SR 0 ; ; Now define one of three behaviours (note: value can be changed "online" in the TS mode menu) ; The TS mode works independent from the MBMF button handler, means: use TOUCH_SENSOR_SR >= 8 ; to suspend the motors w/o allocating a button function ; ; TOUCH_SENSOR_MODE EQU 0: no additional action when touch sensor pressed/depressed ; TOUCH_SENSOR_MODE EQU 1: the motor will be suspended via MIOS when the appr. touch sensor ; is pressed, so that it will not be moved on incoming MIDI events ; TOUCH_SENSOR_MODE EQU 2: like mode 1, additionally no MIDI event will be sent when the ; touch sensor is *not* pressed. ; ; Mode "1" is used by default to avoid circular troubleshooting requests in the MIDIbox forum from people ; who don't read this information before starting the application. ; Mode "2" should be the prefered setting if your touch sensors are working properly #define DEFAULT_TOUCH_SENSOR_MODE 1 ; ; The touch sensor sensitivity (can also be changed "online" in the "Touch Sensor" menu) #define DEFAULT_TOUCH_SENSOR_SENSITIVITY 3 #endif Here is mios_tables.inc MIOS_MPROC_EVENT_TABLE ;; entry 0x00-0x0f MT_ENTRY 0xb1, 0x00 MT_ENTRY 0xb1, 0x01 MT_ENTRY 0xb1, 0x02 MT_ENTRY 0xb1, 0x03 MT_ENTRY 0xb1, 0x04 MT_ENTRY 0xb1, 0x05 MT_ENTRY 0xb1, 0x06 MT_ENTRY 0xb1, 0x07 MT_ENTRY 0xb1, 0x08 MT_ENTRY 0xb1, 0x09 MT_ENTRY 0xb1, 0x0a MT_ENTRY 0xb1, 0x0b MT_ENTRY 0xb1, 0x0c MT_ENTRY 0xb1, 0x0d MT_ENTRY 0xb1, 0x0e MT_ENTRY 0xb1, 0x0f ;; entry 0x10-0x1f MT_ENTRY 0xb1, 0x10 MT_ENTRY 0xb1, 0x11 MT_ENTRY 0xb1, 0x12 MT_ENTRY 0xb1, 0x13 MT_ENTRY 0xb1, 0x14 MT_ENTRY 0xb1, 0x15 MT_ENTRY 0xb1, 0x16 MT_ENTRY 0xb1, 0x17 MT_ENTRY 0xb1, 0x18 MT_ENTRY 0xb1, 0x19 MT_ENTRY 0xb1, 0x1a MT_ENTRY 0xb1, 0x1b MT_ENTRY 0xb1, 0x1c MT_ENTRY 0xb1, 0x1d MT_ENTRY 0xb1, 0x1e MT_ENTRY 0xb1, 0x1f ;; entry 0x20-0x2f MT_ENTRY 0xb1, 0x20 MT_ENTRY 0xb1, 0x21 MT_ENTRY 0xb1, 0x22 MT_ENTRY 0xb1, 0x23 MT_ENTRY 0xb1, 0x24 MT_ENTRY 0xb1, 0x25 MT_ENTRY 0xb1, 0x26 MT_ENTRY 0xb1, 0x27 MT_ENTRY 0xb1, 0x28 MT_ENTRY 0xb1, 0x29 MT_ENTRY 0xb1, 0x2a MT_ENTRY 0xb1, 0x2b MT_ENTRY 0xb1, 0x2c MT_ENTRY 0xb1, 0x2d MT_ENTRY 0xb1, 0x2e MT_ENTRY 0xb1, 0x2f ;; entry 0x30-0x3f MT_ENTRY 0xb1, 0x30 MT_ENTRY 0xb1, 0x31 MT_ENTRY 0xb1, 0x32 MT_ENTRY 0xb1, 0x33 MT_ENTRY 0xb1, 0x34 MT_ENTRY 0xb1, 0x35 MT_ENTRY 0xb1, 0x36 MT_ENTRY 0xb1, 0x37 MT_ENTRY 0xb1, 0x38 MT_ENTRY 0xb1, 0x39 MT_ENTRY 0xb1, 0x3a MT_ENTRY 0xb1, 0x3b MT_ENTRY 0xb1, 0x3c MT_ENTRY 0xb1, 0x3d MT_ENTRY 0xb1, 0x3e MT_ENTRY 0xb1, 0x3f MIOS_ENC_PIN_TABLE ;; encoders 1-16 ;; SR Pin Mode ENC_ENTRY 9, 0, MIOS_ENC_MODE_DETENTED ; V-Pot 1 ENC_ENTRY 9, 2, MIOS_ENC_MODE_DETENTED ; V-Pot 2 ENC_ENTRY 9, 4, MIOS_ENC_MODE_DETENTED ; V-Pot 3 ENC_ENTRY 9, 6, MIOS_ENC_MODE_DETENTED ; V-Pot 4 ENC_ENTRY 10, 0, MIOS_ENC_MODE_DETENTED ; V-Pot 5 ENC_ENTRY 10, 2, MIOS_ENC_MODE_DETENTED ; V-Pot 6 ENC_ENTRY 10, 4, MIOS_ENC_MODE_DETENTED ; V-Pot 7 ENC_ENTRY 10, 6, MIOS_ENC_MODE_DETENTED ; V-Pot 8 ENC_ENTRY 11, 0, MIOS_ENC_MODE_DETENTED ; V-Pot 9 ENC_ENTRY 11, 2, MIOS_ENC_MODE_DETENTED ; V-Pot 10 ENC_ENTRY 11, 4, MIOS_ENC_MODE_DETENTED ; V-Pot 11 ENC_ENTRY 11, 6, MIOS_ENC_MODE_DETENTED ; V-Pot 12 ENC_ENTRY 12, 0, MIOS_ENC_MODE_DETENTED ; V-Pot 13 ENC_ENTRY 12, 2, MIOS_ENC_MODE_DETENTED ; V-Pot 14 ENC_ENTRY 12, 4, MIOS_ENC_MODE_DETENTED ; V-Pot 15 ENC_ENTRY 12, 6, MIOS_ENC_MODE_DETENTED ; V-Pot 16 ;; encoders 17-32 ENC_ENTRY 13, 0, MIOS_ENC_MODE_DETENTED ; V-Pot 17 ENC_ENTRY 13, 2, MIOS_ENC_MODE_DETENTED ; V-Pot 18 ENC_ENTRY 13, 4, MIOS_ENC_MODE_DETENTED ; V-Pot 19 ENC_ENTRY 13, 6, MIOS_ENC_MODE_DETENTED ; V-Pot 20 ENC_ENTRY 14, 0, MIOS_ENC_MODE_DETENTED ; V-Pot 21 ENC_ENTRY 14, 2, MIOS_ENC_MODE_DETENTED ; V-Pot 22 ENC_ENTRY 14, 4, MIOS_ENC_MODE_DETENTED ; V-Pot 23 ENC_ENTRY 14, 6, MIOS_ENC_MODE_DETENTED ; V-Pot 24 ENC_ENTRY 15, 0, MIOS_ENC_MODE_DETENTED ; V-Pot 25 ENC_ENTRY 15, 2, MIOS_ENC_MODE_DETENTED ; V-Pot 26 ENC_ENTRY 15, 4, MIOS_ENC_MODE_DETENTED ; V-Pot 27 ENC_ENTRY 15, 6, MIOS_ENC_MODE_DETENTED ; V-Pot 28 ENC_ENTRY 16, 0, MIOS_ENC_MODE_DETENTED ; V-Pot 29 ENC_ENTRY 8, 0, MIOS_ENC_MODE_DETENTED ; Menu Left/Right ENC_EOT ENC_EOT With this setup is function: DIN pins 1-16 are Note 1-16 its OK, than DINs 17-20 are any direct control menu buttons (like bank select) ???, than DINs 21-32 are Note 5-16 ???, than DINs 33-48 are Note 1-16 ???, than DINs 49-64 are Note 1-16 and menu buttons(DINs 58,59) sending Note :-[ Encoders function is OK to 16 than instead 17 number is 1...and continute to 12 30th ENC sending Note instead controling menu. I dont know how to set :-[ it looks like some groups or something :-\ thanks for some help. I know that will be some foolish mistake ;) LX
Thanks for reply, I find setup witch I didnt saw before... ??? #define DEFAULT_ENC_DATAWHEEL 0 I thought that this setup is only 0 for no ENC and 1 for enable ENC but I can set number of ENC. I'm reading too quikly :-\ So I have same problems with hardware I must find where is mistake... B.R. LX
Yes I'm back ;D
Hi Can I move shift register 1 for menu buttons and ENC left/right to another shift register for example 8? I don't know how to setup in main.asm. There is only setup for pins #define DEFAULT_DIN_MENU_EXEC 7 ; menu exec button assigned to DIN pin #7 #define DEFAULT_DIN_MENU_SNAPSHOT 6 ; menu snapshot button assigned to DIN pin #4 #define DEFAULT_DIN_MENU_RIGHT 5 ; NOT USED - overlayed by datawheel #define DEFAULT_DIN_MENU_LEFT 4 ; NOT USED - overlayed by datawheel but how to set the shift register? I try set pin instead #7 to #56, but dont work. If we understand interval for DIN pins from 0 to 127, but I'm afraid the interval is only from 0 to 7 for 1st shift register. Thanks for some ideas LX
Ja mam tri core a na jednom budu mit origo program MB64e a na tech dvou mam jen kostru ain64_din128_dout128_v1_3 a tam sem si vse doprogramoval podle toho jak to budu chtit. Neumim totiz predelat treba MB64 tak jak chi, rozumim tak 30% programu. S enkoderem kvantizace to byl orisek, musel jsem si naprogramovat rutinu co mi bude, pri otoceni o jeden zoubek, pricitat jednicku a pri opacnem odecitat, v rozmezi 0-14 a pri kazdym skoku mi posle jednu midizpravu. V Livu si priradim kazdou zpravu k jednomu typu kvantizace a pak budu mit jednoduchou a hlavne rychlou cestu k jeji zmene. Mam jeste na tom enkoderu tlacitko a to asi udelam tak ze pri jeho stisku se to nastani na moji preferovanou hodnotu kvantizace, kterou pouzivam nejcastejs. Ty stavis LCko tak to ti budu zavidet ty motorfadery, ja jsem se na to kvuli cene a hlavne kvuli neschopnosti to naprogramovat vysral... :) , kazdopadne husty pekna pracicka, netusil jsem ze to taky nekdo v republice takhle pekne paji ;) Mam jeste otazku ohledne toto plechu. To si si nechal udelat u frontpanelexpress.com ? (to muselo bejt mastny), nebo jak jsi to dal do ty cerny. A co popisky budes delat jeste sitotisk?
akcija: Zdravim co stavis? ja pachtim tohle lx.czweb.org
Hi all I have finished next module. http://lx.vanuatuss.org/index.php?pg=news&lang=en LX
Hi I can't find shop where still they have some PLED/OLED display. Most shops aren't able to say when will be the display available. Like this ... http://www.crystalfontz.com/products/index-pled.html Thanks for reply. LX
MIDIbox of the Week (Wilba's MIDIbox SID V2, aka. MB-6582)
LX replied to TK.'s topic in MIDIbox of the Week
:o This is unbelievable!!! congratulation You are the best board designer!!! respect Wilba LX -
Program for BUTTONS board is finished !!! view video ... http://lx.czweb.org/index.php?pg=news&lang=en LX
mission complete!!! my code is quite complicated ??? I put there steps for easy blinking... 1) timer initialization - I place this to USER_Init (but,you can start or finish timer any time) movlw 31250 & 0xff movwf MIOS_PARAMETER1 movlw 31250 >> 8 movwf MIOS_PARAMETER2 movlw 0x03 call MIOS_TIMER_Init timer jump to USER_Timer every 25ms from now 2) You must write this definition on the top of main.asm (determine count of skips then blinking routine will be perform) #define LX_CLIPS_BLINKING_SPEED 8 ; 6=quickly 8=mediumly 10=slowly 3) USER_Timer ----------- USER_Timer ; This is for erase speed interval... movf LX_BL_Clock, W sublw LX_CLIPS_BLINKING_SPEED skpnz clrf LX_BL_Clock ; if LX_BL_Clock = 0 go to LX_PrePlay_BL routine... movlw 0x01 subwf LX_BL_Clock, W skpc rgoto LX_PrePlay_BL rgoto LX_Timer_End LX_PrePlay_BL IFCLR LX_BL_Enable, 0, rgoto LX_Timer_End IFSET LX_BL_Switch, 0, rgoto LX_LED_PrePlay_On LX_LED_PrePlay_Off ; >> ------------------ LED Off ------------------ movf LX_Blinking_Button, W call MIOS_DOUT_PinSet0 bsf LX_BL_Switch, 0 rgoto LX_Timer_End ; << ------------------ LED Off ------------------ LX_LED_PrePlay_On ; >> ------------------ LED On ------------------ movf LX_Blinking_Button, W call MIOS_DOUT_PinSet1 bcf LX_BL_Switch, 0 ; << ------------------ LED On ------------------ LX_Timer_End incf LX_BL_Clock, F return registers LX_BL_Switch - if bit D0 is 0/1=On/Off LED LX_BL_Enable - if D0 is 0/1=disable/enable blinking LX_Blinking_Button - into save number of button I finish today... :-\ B.R. LX 5.3.2007 - sorry, I must edit this reply today (code was wrong) :-\
Hi I thing that these caps are from www.mec.dk type: 1S11 Best regards LX
in assembler... ;) I must tune this code, becouse i found 3 mistakes at some special combination of switching clips :-\ But it's 1-2 days debugging :) Than I'll make video of this..and share code ;) (but it is quite secial for my Buttons module) -> only for your help :) B.R. LX
Hi ;D !!! success !!! 8) It's functional... I use timer with period about 25ms and filtering every 8th cycle. -> ideal blinking.. :D I have finished flashing clips in Ableton Live and it function like the program. I use incoming 4 mesages 7E, 7F, 01, 00 from clip. When I switching clips on PC, midibox LEDs are same like Live. :) B.R. LX
Hi mikeb No, only modules on the pictures and LTC module. My next board are same (on principle) but bigger, intricacy and I combine DIN, DOUT, AIN to one board. B.R. LX
Thanks you all.. I try to prog with MIOS_TIMER ::) I hope that I'll be successful.. ;) Best regards LX
Hi all I have a question about blinkig LEDs with some interval. I can't find where is place in main.asm for make it this. I thing that mabye is in USER_Timer but I dont know how to do it. Have you any ideas? :'( Thanks for reply Best Regards LX
I never said that I can't solder before my first Midibox project. I was employee of one mobile(phone) firm for 2 month 7 years ago. There I learn solderig like repairman. But I never produce self boards. This I learned for 1 year. :) This is my first tests with universal boars and midibox... 4DIN module 4DOUT module My test board... ;) this was my kitchen... :) In next reply I explain How easy solder SMD...(It wants think up good procedure) ;D B.R. LX
I prepare and study about 1 year...I need to find all possibilites for maximal best :) configuration my machine. I don't know nothing about Eagl, Asembler, TK's core and modules....It was hard work for me to understant whole system. Than some tests and than production...;D and making pfotos. I didn't wont show pictures before finishing layout ;) It am I. Now I haven't complete finish 100% layout as well but it are some cosmetics adjustments. ;) B.R. LX
Sorry :-\ ....fixed :)
In the Layout section in my site uder first pic is "For large image click here" :-) Thanks... LX
Hi midiboxers! I making my MidiBox about 2 years and now I have some pic to show you. I'm not finish with this but you can watch my progress at www.lx.czweb.org LX
Hi Robert Great work!!! I've question about python script. I can't debug python file from Ableton Live. I want write (exactly rewite) their python file (MIDI remote Scripts), because I want better midi feedback from all buttons (and mostly clips) of Ableton Live program. Do you knew how to break this phyton file for editing? Thanks for reply LX
Hi Wilba Tahnks for your answer. I belive that is right. Thanks for averment. BR LX
