Acid303
67 -
Everything posted by Acid303
Oh yes :) Just found it... ok...i did read the whole manual....but there are so many new features :) ...ok, i will study it more intensely ;) Thanks again, best regards, Axel
Thanks for your fast answer...and yes, you are right....sorry ;) The button works now....It was my mistake....I had just to resolder the OSC Waveform on the back of the PCB... I was wondering why it had worked before, but nevertheless now itworks fine again... Go on with your good work ;) Best regards, Axel PS: Before I forget it... will there be a function where you can delete a patch? So you can right start with "nothing" , all parameters "0"?
Hi Thorsten, first of all, thanks for the new firmware :) Very nice indeed ! Now I have a little problem with the OSC Waveform button....it doesn't work ... I have the new PIC18F4685 and the latest BETA...the button is not working...so I uploaded the old firmware again...V1.74685...the same result... Unfortunately I can't try it with the old PIC because of the 4 cut datalines of the LCD (D0-D3) etc. I haven't changed anything ,so my question is, if this is a bug in the firmware? I checked all connections but everythings looks just fine... Thanks for your answers :) Regards Axel
Hi, ok, es waren eindeutig meine tollen Stecker... hab die Kabel direkt angelötet und siehe da, es ging :) Na gut, hab einige Encoder angelötet, ist aber noch ne Menge Arbeit bis zur Midibox SId Step C...aber es wird schon ... Danke trotzdem !! Gruss, Axel
Hi Michael, ja Encoder ist richtig :) OK, werde die Verkabelung nochmals prüfen... Danke mal... Meld mich wenn ichs raus hab ... Gruss, Axel
Hi :) Wollte heut mal die Potis anschliessen und hatte etwas Probleme damit. Vielleicht kann mir von euch jemand auf die Srünge helfen? Momentan hab ich noch Step B , also die 5 Taster, ein Drehregler und ein Display.... Die DIN Module hab ich alle 3 fertig.... die Encoder sind von Voti, detented, hab allerdings 2 non-detented gemacht... Ich hab also die beiden Regler an den den entsprechenden Anschluss am DIN Board angeschlossen (OSC Decay und Sustain). Beide sind an derselben Masse angeschlossen (also ich hab das Massekabel an einem Regeler und von diesem Regler geht ein weiteres Kabel an die MAsse des anderen Reglers...ist doch ok so?) Habe ich nur einen angeschlossen, so funktioniert alles bestens...wenn beide dran sind, hängt sich die Midibox meist auf bzw. der eine Wert zählt von 128 einfach runter wenn ich drehe, ob nach rechts oder nach links.... Habt ihr nen Tip für mich....was mach ich falsch? Danke mal, Gruss, Axel
ALLES KLAR!!! Hab das 6581er Modul umgebaut zum 8580er und es funzt :) Gott sei Dank :) Das sagt mir nur, dass meine Lötfähigkeiten wohl nicht so doll sind... das andere Modul will einfach nicht, vielleicht die Verbindung Core<>Sid, obwohl ich auch da die Interconnection Verbindung getestet hab... Keine Ahnung wie gesagt, jetzt bin ich erst mal froh dass es soweit läuft, werd morgen dann Fotos machen.... Bis dann und Gute Nacht, Gruss, Axel
Hi Thorsten, ja, das hab ich schon beachtet, aber leider funzt nicht.... das Core Modul ist i.O. alles wird bestens angezeigt... nur aus dem 8580 bekomm ich nix raus...wie gesagt, alle Spannungen sind vorhanden... den Audio Out hab ich nochmal nachgelötet, den 8580 Sid hab ich nochmals gecheckt....hab echt keine ahnung mehr Ich hab heute mal alles was ich hab und was funzt (also Core+6581er Modul) in ein Gehäuse eingebaut... Könnte mal Fotos schicken zwecks Midibox Sid of the Week :) Andere Frage: Was würde passieren, wenn ich in das funktionierende 6581er Modul einfach mal den 8580 reinstecke? Würde der abrauchen? Wegen den 3 Volt unterschied? Ansonsten müsst ich nur den 7812 gegen nen 7809 austauchen sowie die beiden Kondensatoren? Wär n Versuch Wert, da ich halt lieber den 8580 benutzen würde :) Danke mal ;)
Hmmm....dann weiss ich echt nicht mehr weiter... Hab alles durchgemessen, alles sieht bis auf den 7809 und die Kondensatoren genau so aus wie beim 6581er Modul....die Messwerte stimmen, der 8580 Chip funktioniert auf der Hardsid Karte....? Anirgendwas muss es ja liegen... Naja, ich geb jetzt mal auf und bau es halt mit dem 6581er fertig, auch wenn der wie bekannt rauscht etc... Danke mal soweit :)
Danke mal für die Antwort :) Ja hab ich drauf geachtet.... ich hab jetzt eine dunkle Vermutung.... kurze Vorgeschichte: Als ich das erste 8580 Modul gebaut hab, hab ich die "alte" Netzteillösung verwendet, also diese hier: http://www.ucapps.de/mbhp/mbhp_sid_c64_psu.pdf DAmit hats auch immer funktioniert...hab dann die "grössere" Variante gebastelt: http://www.ucapps.de/mbhp/mbhp_4xsid_c64_psu_optimized.pdf welche mit dem 6581er Modul sowie Core auch bestens funktioniert... Jetzt hab ich nochmal ganz genau nachgemessen: Am 6581er Modul sind 12,23 Volt zu messen, also genug :) Gleiche Netzteillösung am 8581: Messung ergbt 8.97 Volt, also 0.03 Volt zu wenig....ich vermute dass es daran liegt, weil sonst echt nix anderes in Frage kommt... schliesslich hatte das alte 8580er Modul ja mal funktioniert... OK, vielleicht könntet ihr mir mal eure Volt-Zahlen beim 8580er Modul durchgeben? Liegen die immer über 9 Volt? Oder auch drunter? Falls es das ist, wie komm ich über 9Volt? Was ich nicht kapier ist, wieso es beim 6581er super funzt (der braucht 12V) und beim 8580 funzt nicht...obwohl gleiches Core Modul, gleiche Stromquelle, gleiche Kabel etc.??? An was kanns denn noch liegen? Ausser am 7809? Danke mal.... Gruss Axel PS: Hab grad mal direkt n externes Netzteil an J1 vom Sid angeschlossen...auch wenn ich 12 Volt drauf gebe, kommen 8.97 Volt an...wird ja wohl auch am 7809 liegen...was anderes fällt mir im moment nicht mehr ein.... wie krieg ich denn mal über 9 Volt auf den Sid?
Hi, prinzipiell bin ich Anfänger, hab allerdings schon einige core Module und auch Sid Boards zusammengelötet. Als Netzteil hab ich die Löung mit dem Original Netzteil vom 64er. Die Core Module funtkionieren alle bestens...die 6581 er Module ebenfalls, nur mit den 8580er Modulen hab ich meine Probleme. Ich krieg einfach keinen Ton raus? Die gefordeten Spannungen sind am 8580 Modul vorhanden, ich benutze die selben Steckerverbindungen usw. wie beim 6581er....ich vermute dass ich irgendwas beim 8580er Modul übersehe. Hat vom gefühl her irgendwas mit dem Strom zu tun, aber wie gesagt, die gefordeten Spannungen liegen klar an... Ich hab sogar extra nochmal ganz frisch ein V3 Core Modul sowie ein neues Sid Modul zusammengebaut, aber hier das gleiche bild. Achja, der Chip kanns nicht sein, ich probier die soundchips immer auf meiner Hardsid Karte aus... Kommt hier vielleicht jemand aus der Stuttgarter Region? Oder ich würd letztendlich sogar mal meine 8580er Module an denjenigen verschicken, der sie mal durschchecken kann? Ich könnt mich ja mit dem 6581er Modul zufrieden geben, aber mich wurmt das mit dem 8580er sehr...ausserdem hat der ja den saubereren Klang... Wär super wenn sich jemand melden würde:) Danke mal im voraus... Bis dann, Axel
Hi, i am also interested in buying 2 chips....are there still 2 available? Regards, Axel
Hi, ich habe vor gut einem 3/4 JAhr angefangen, mir eine Midibix SID zu bauen. Ich hab einiges fertig, allerdings bin ich echt kein Profi. Ich hab irgendwelche Wackler oder schlimmeres und bekomme die einfach nicht in den GRiff. Als ich die Platinen das letzte Mal angeschlossen hatte, hat noch alles funktioniert. Jetzt nicht mehr. Mal gehts, dann wieder nicht. Hab keine Lust mehr, die Chips zu schrotten.Also noch mal zum Veständnis: Es hat alles funktioniert, nur irgendwie recht wackelig. Vielleicht gibt es ja Leute aus dem Stuttgarter Raum, die mir weiterhelfen könnten. Wo ich einfach mal für einen nachmittag vorbeikommen könnte und wir die Bugs ausmerzen können. Ich glaub dass es an den Kabeln liegt, eventuell auch an der Stromversorgung. Ich bins leid, da weiter rumzufuschen. Ich brauch da jemand erfahrenes. Ich hab 3 funktionierende Sid-Boards, Display, Core Boards (auch überprüft), Bankstick mit 8 Chips (funzt auch), Drehregler, Taster... Gruss, Axel PS: So, zumindest läufts jetzt mal wieder :) Trotzdem, falls jemand aus dem Raum Stuttgart Lust hat, mit mir ein bisscen zu basteln, würd ich mich freuen...
and you can hear some stuff going on in the background... can anything be done? i have the same problem with one of my 8580. You hear the sound very very quiet in the background. I know that the chip once worked. I had some polarity problems with my modules, and after trying out some things the chip ended quiet. If someone knows how to fix it again.....? Axel
Ja, ich denke ich weiss wie ich die PICs um die Ecke gebracht habe ;) Für euch Fortgeschrittene Elektroniker ist das sicherlich ein Fehler, den ihr nicht so leicht begehen würdet, aber ich bin wie schon öfters gesagt total Anfänger. Deshalb trau ich mich auch und schreib was nach meiner Meinung zum Sterben der PICs geführt hat. Alles lief wunderbar, bis ich daran ging, die C64 Netzteil-Lösung (mbhp_4xsid_c64_psu_optimized.pdf) zu basteln. Ich hab zuvor noch nie etwas gelötet nach einem Schaltplan. Es lief eigentlich auch sehr gut, bis ich alles verkabelt hatte, meiner Meinung nach auch alle Spannungen vorhanden waren, wie sie sein sollten (was ja auch stimmte,dazu später mehr), doch trotzdem kam kein Ton aus meinem Sid... Jetzt im Nachhinein bin ich mir ziemlich sicher, dass ich ein Polaritätsproblem hatte, und zwar gingen vermutlich -5 V an das Sidmodul und +5 V an das Coremodul. Anders kann ich es mir nicht erklären, d.h. vom Netzteil hatte ich einen Anschluss mit 5V und den Mischanschluss mit 14V. Ich habe dann ein Kabel gebastelt , welches aus dem 5V Anschluss einen Kabelstrang an das Core Modul ging und 1 Kabelstrang an das Sidmodul. Dabei waren die Polaritäten wohl genau "seitenverkehrt". Da ich jetzt genau drauf geachtet habe, dass de Polaritäten exakt identisch sind, klappt es und mein Sid funktioniert tadellos. leider hatte ich zuvor zu viel rumexperimentiert mit den Kabeln, so dass mir schlussendlich 2 PICs kaputt gingen. Durch das rumgefummlehat das Core Modul ab und zu neu gebootet, bis es gar nicht mehr ging, und ich MIOS neu aufspielen musste. Das ging auch eine Weile lang so, irgendwann nicht mehr. Ich nahm an, dass ich "lediglich" den Bootloader gekillt hatte. Ob das mit der Polarität tatsächlich zusammenhängt müsst ihr mir jetzt bentworten, aber was anderes kanns einfach nicht gewesen sein, weil mehr als das Kabel hab ich letztendlich nicht geändert. Also, nicht nachmachen und genau auf die Polaritäten achten. Einfach gesagt, alles genau so anschliessen wie es Thorsten auch eingetragen hat. Abschliessend noch grossen Respekt an alle Elektroniker, da man sich echt keine Fehler erlauben kann. Das Wort Exakt hat da eine sehr schwere Bedeutung ;) Nichtsdestotrotz bin ich im Moment wieder sehr happy, es läuft alles so wie es soll, PICs hab ich grad beim Reichelt nachbestellt, und auch sonst gehts jetzt wieder gut weiter mit dem Bauen. Bin grad an der Frontplatte, Encoders sind auch grad von voti eingetroffen. DIN Modul funktionert. Es sieht ehr gut aus. Auch hab ich absolut kein Brummen mehr im Hintergrund noch sonstwas, hatte ja das Problem ganz zu Anfang. Wenn alles fertig ist, gibts natürlich Fotos...Es wird aber ziemlich gleich aussehen, wie die Box auf dem 1.Foto der HP. Also auch eingebaut in ein das "Brotkasten" Gehäuse. Gruss, Axel PS: Leider ist es nicht nur bei den zerstörten PICS geblieben, ein 6581er geht gar nicht mehr, und bei einem anderen funktioniert der Filter nicht mehr. Hab Gott sei Dank noch Reserven ;) Seh ich aber alles als Lehrgeld an....Das Ergebnis entschädigt dafür ....
So, stimmt, PIC ist tot !!!!!!!!!! Habs mit dem JDM Modul letztendlich rausbekommen. Mein "gesunder" PIC liess sich ohne Probleme mit dem Bootloader "bestücken". Alle anderen PICS nicht..... OK, Glück im Unglück, zumindest weiss ich nun, dass sie kaputt sind. Danke trotzdem :)
Hat da jemand einen Rat? Alle Spannungen werden richtig angezeigt, aber wenn ich den PIC einsetze sinkt die Spannung beim Schreiben auf 8.3 V Ausserdem seltsam. Wenn ich "Reading" mache, so liest er schön langsam alles aus dem Chip raus. Mach ich danach "Write" schreibt er brav alles zurück in den Chip, sogar mit Verify Nachricht. Aber den Bootloader mag er nicht, da kommt dann gleich die Fehlermeldung "Programmierung fehlgeschlagenm an Adresse 000000h" ????? Tip?? NACHTRAG: JDM Modul ist in Ordnung, nur meine PICS waren tatsächlich total im A*** ! Hab mich schlussendlich doch noch getraut meinen letzten funktionstüchtigen PIC in das JDM MOdul zu packen und siehe da, 100% brennen des Bootloaders. Also, Glück im Unglück....
Hmmm, kurz das ich es verstehe: Also ich hab gemessen ohne PIC im Sockel. Müssen dann 5V am Pin25 zu messen sein? Oder nur wenn der PIC im Sockel ist? Ah ok, also es müssen 5V zu messen sein, wenn der PIC gesteckt ist, sonst nicht, richtig? Und "tot": Bedeutet das, der PIC ist total kaputt oder er muss nur neu mit dem Bootloader (via JDM) beschrieben werden? NACHTRAG: OK, 5 V sind da an PIN25 wenn der PIC gesockelt ist. Kurz zur Vorgeschichte: Alle meine Core-Platinen (mittlerweile 4 Stück) haben funktioniert. Erst als ich sie mit dem Sid-Modul gekoppelt habe, kamm es ab und zu zu "abstürzen" (vermutlich durch dieses blöde Klemm-Steck Kabel) wonach dann der PIC über Midi nicht mehr geantwortet hat. Ich habe nun noch 1 komplett funktionierendes CoreModul incl. PIC. Ich habe alle anderen 3 PICs auch schon im meinem funktionierenden Core-Modul ausprobiert, aber sie funktioneren nicht. Also keine Mdi Message im MidiOX. Also werde ich nun das JDM Modul basteln und die PICs neu beschreiben. Trotzdem: Ist die Verbindung Core-Sid so heikel? So gefährlich für den PIC? Ich hab mich im Moment noch nicht getraut den letzten funktionierenden PIC in meine "alten" Core-Platinen einzusetzen. Erstmal will ich die 3 PICs wieder neu beschrieben mit dem Bootloader.
Hi, Ich habe bei 3 Core Modulen das gleiche Problem: Anfangs funktionierten alle perfekt. Nachdem ich die Verbindung zum Sid Modul hergestellt hatte, "stürzte" das Core Modul ab. Liegt vermutlich am Kabel. Leider gehen alle Core Module nicht mehr, bzw. der PIC sendet kein Lebenszeichen mehr raus. Nach einigem Messen hab ich nun festgestellt, dass alle Spannungen stimmen bis auf die 5V am TX (PIN25). lt. http://www.ucapps.de/howtodebug/mbhp_core_extract_measuring_vdd.gif sollten 5 V am PIN 25 anliegen. Ist aber nix da. Wo liegt der Fehler? Woher sollten die 5V kommen? Ich hab die optimierte PSU Lösung, aber damit hats ja glaub nix zu tun. Alle anderen Spannungen sind ja da. Bitte helft mir :o Axel
Hi Thorsten, na das gibt doch Hoffnung ;D Auf diesem Wege mal vielen Dank , dass es dieses Projekt überhaupt gibt ;) Hörst Du sicherlich öfters, aber ist wirklich so.... Ich bin Anfänger und muss sagen, dass man durch dieses Projekt so einiges lernen kann. Schönes WE ;) Axel
;D Wenns nur so wäre ;D Dann wärs einfach.....nein, hab die auch nochmal nachgelötet. Ist wirklich seltsam. Aber viel mehr beschäftigt mich immer noch das Brummen, dass ich im Hintergrund habe. Hab da einiges nachgelesen zu dem Thema. Weiss trotzdem nicht so recht weiter. Nur eins: Obwohl überhaupt kein Strom angeschlossen ist, brummt es trotzdem , wenn ich die Kabel anfasse. Also es ändert sich etwas der KLang des Brummens. Ist das die Abschirmung? Also einfach ein besseres, abgeschirmtes Kabel nehmen? Oder ist das dann doch ein Masseproblem insgesamt. Das Einzige was mir dazu momentan einfällt ist, die optimierte Lösung zu bauen: mbhp_4xsid_c64_psu_optimized.pdf. Ich hab momentan diese Lösung: mbhp_sid_c64_psu.pdf Axel
Hi, bei meinem 6581er Modul werden irgendwie keine Filterwerte übertragen. Der Filter reagiert weder manuell (also per EDIT im JSynthLib) noch über LFO. Alles andere "scheint" zu funktionieren (hab noch nicht alle Funktionen geprüft). Der Chip ist 100 % in Ordnung, da ich ihn auf der Hardsid Karte geprüft habe. Filter reagiert einwandfrei (ist übrigens ein 6581 R4). Richtige Software/Applikation hab ich auch reingeladen. Ich habe noch ein 8580er Modul welches einwandfrei läuft. Verwende also dasselbe Core Modul, dieselben Stecker. Alles gleich. Welche Bauteile sind denn für das Filter verantwortlich? Oder welcher Pin am 6581? Danke mal... Axel
Hab ich im 1.Moment auch dran gedacht, aber nein, alles komplett 6581. Allerdings hab ich meine Sid Chips mal komplett über die Hardsid Karte und Sidplay ausprobiert um die Klangunterschiede auszuloten. Zum Test gut geeignet war der Song vom Spiel "Miami Vice" von Martin Galway. Beide 6581er gingen mit dem Filter noch etwas mehr "runter" als der 8580, auch knackte es hier und da. Der 8580 "läuft" da sauberer. Irgendwo hab ich gelesen, dass Thorsten meinte, dass der 8580 der bessere Chip sei. In Bezug auf Synthesizerfähigkeiten sehe ich das genauso. Aber aus Nostalgiegründen lasse ich die "alten" Sidtunes hauptsächlich über den 6581 laufen. Also alle Rob Hubbard und Martin Galway tunes. Für die Midibox Sid hab ich mich auch klar für den 8580 entschieden. Nachtrag: An meinem 6581er Modul muss etwas nicht stimmen. Der Filter geht gar nicht mehr. Alles andere "scheint" zu funktionieren. Am Chip liegts nicht, das hab ich überprüft. Habe bereits ein neues Posting eröffnet.
Ok, das nächste Mal ;) Habs soweit in den Griff bekommen. Was es nun genau war, weiss ich auch nicht genau. Ich hab einfach mal alle Lötpunkte durchgeschaut und zum Teil nachgelötet. Es ist zwar immer noch etwas Brummen im Hintergrund zu hören, aber ich denke, dass das als "normal" zu bezeichnen ist beim Sid. Aber der Filterunterschied vom 6581 zum 8580 ist ja ziemlich gross. Entweder hab ich was an meinem 6581er Modul falsch gemacht, denn der Filter ist bei Aktivierung sehr sehr dicht, also sehr dumpf. Auch wenn er ganz offen ist, ist er lange noch nicht an dem Punkt angelangt, wie er klingen würde, wenn kein Filter aktiviert wäre. Der 8580 reagiert hingegen wahnsinnig klar. Okey, dann mach ich jetzt mal ne Pause und demnächst gehts dann daran die Taster und das DIN4X Board fertig zu machen. Gruss, Axel
Alles klar ;D Klingt ja super. PM hab ich bereits an Raphael geschickt. Vielen Dank ;) Jetzt hab ich noch ein anderes Problem: Ich hab ein starkes Brummen auf meinem Audioausgang des Midisid. Irgendwas überseh ich da. Ist das Massebrummen oder woher kommt das? Auf jeden Fall freu ich mich schonmal auf den Encoder.... Gruss , Axel
