474 -
4
Everything posted by Marxon
But i think it isn't worth it. I going to buy me a rack case, then i have enough space for everything ;D greatz bpm
Hi Jidis! Youre core looks very minimal, does it fit in a box of ciggarets? ;D (bad english, i know;) Yes it seems self etching is the best way for building it "wire-free" I also have problems of wires which are to short, to long, broken or bad soldered. dont ask me how many days i worked on my lcd cable :-X So i am going to etch my own pcbs for seq. Time shouldt be the same... greatz bpm
Bankstick gets formatted on every startup
Marxon replied to Marxon's topic in Testing/Troubleshooting
Hi TK! Uff! No. As i said a friend soldered it on a "streifenrasterplatine" with many many bridges. And i allways said to my friend: "dont solder them all, let's check it before" but he: "no, no. it WILL work" ::) But a (real) bankstick pcb seems to be a good idea. Instead of checking and testing wires (and getting wired) i try to make a schematic with eagle and etch me a pcb :P ok thanks for ur help (and all this crazy MidiBox tools) BpM -
Morning! I have worked on my sid the hole night and a friend was helping me... He soldered the bankstick modul again for me bacause he is much better in soldering, but it is still the same when i try to use 1 or more bankstick :-[ The connections are exactly like at your picture TK. bpm -
Hi evrybody, i wonder if its possible to change thy display driver to use it "on the hat" because the pins of my display are on the right side but it doesn't fit in my case. i want to turn it 180 degree to have the pins on the left side. any ideas? thx BpM
solder solder solder...... Power on, Formatting (now starting at patch A), power off, power on AND no formatting anymore! ;D Upload patches.... HURRRAY! Works! To the 8 bankstick problem: I soldered some wires "in Reihe" and not "parallel" to save solder time can this cause problems? thx BpM -
Hi TK! I just edited my post while you where replying it... Yes i run MIOS 1.8. I just finished a Single Bankstick PCB. It is the same problem. thx BpM -
Hi erverybody! I have got a problem with my Bankstick: every time i start my sid it starts formatting my bankstick :( and i can't upload any patch I have connected 8 banksticks. also a test with only one doesn't help. There is one strange thing: it starts formatting always with patch B then C, D ...and patch A at last. Is this normal? edit: do i have to put an chip an every socket? or can i leave some out?
Servus alle zusammen, ja das mit dem Netzteil funktioniert! Es sind nur 4 Pins am Stecker und die Pinbelegung steht oben drauf, konnte eigentlich nix falsch anschließen ;D Der Stecker sitzt bloß irgendwie nich richtig fest, werd´ mal ne andere Buchse versuchen. Jetzt überleg ich, ob es sich nicht evtl. lohnt eine "4xSid-lite" Platine ohne den unbenötigten Teilen zu basteln. mfg
Jaja... die Laufwerke waren nicht gerade langlebig ;D So hab jetzt Zeit zum basteln. Ich versuch das jetzt einfach mal mit dem Netzteil. Wird schon schief gehen... mfg BpM
Morgen raphael! Das hier dürfte dir doch weiter helfen, oder? (Achtung: 16Mb PDF!) http://www.parse.com/~ddunfield/museum/r/c154xsm.pdf mfg BpM
Servus alle zusammen, hab heute ein Netzteil für den C64 und eins für das Floppy Laufwerk bekommen. Das FloppyNetzteil hat 5V und 12V DC Ausgänge :o Wenn ich das verwende kann ich dann alle Spannungsregler und Gleichrichter vom optimierten PSU Schaltplan, SID, und CORE weglassen? Und fall das nicht , könnte mir dann jemand erklären warum das (elektrotechnisch gesehen) nicht funktioniert? Und würde das die Soundqualität nochmal verbessern? mfg BpM
Hi! Leider besitze ich kein C64 Netzteil. Gibt es eine Lösung einen 4 fach SID (2x9V 2x12V) mit einen "normalem" 15AC Netzteil? Macht das dann im Klang viel aus im Vergleich zur optimierten Schaltung mir org. NT? mfg BpM
Servus! @ ilmenator: Mir gehts auch nicht darum die Preise zu drücken als vielmehr den Aufwand gering zu halten. es gibt halt keinen Shop der alles hat was man brauchen könnte. Und wenn man dann 4-5 mal bestellen muss, summieren sich da schon Zeitaufwand und Versandkosten @Sonicwarrior: Ja die Blauen sind schon was feines! Wenn dann wäre ich auch für die! Also Preise wie angegeben. Porto übernehm ich mfg BpM
Servus Leutz! Ich will am Montag paar 8x8 Led Matrizen (ist das die Mehrzahl Matrix???) bestellen Hier ein Link http://www.lc-led.com/Catalog/department/35/category/48 Wer besser kennt,bitte nen Link posten Vieleicht kann Thorsten mal noch einen Blick drauf werfen ob die auch funktionieren würden, für den SID. Wer interesse hat bitte posten. Kann 9 Stück auslegen. Über die Farbe entscheidet die Mehrheit. mfg BpM
Servus, Problem gelöst: Mein Netzteil war scheinbar zu schwach, da ich mein Display über den MAX232 noch mit negativer Kontrstspannung versorgen mussste. Hab jetzt ein stärkeres Netzteil und jetzt funktionierts! Vieleicht hatt ja jemand das gleiche Prob.... also dann frohes Basteln euch allen!
Servus alle zusammen, ich habe folgendes Problem: Sobald ich mein Display anstecke empfang ich eine im MIOS Studio keine Mididaten und die Out LED des LTC Moduls blinkt nicht mehr (Sign of Life). MidiIn LED funzt aber weiterhin. Auf dem Display ist nur ein Balken. Alles Tests des Midi guides sind aber positiv. (Ohne Display) mfg BpM Nachtrag: Wenn ich das Backlight ab klemm geht Midi In wieder. Aber außer dem Balken seh ich nix! MIOS müsste drauf sein da ich einmal die SysEx f0 00 00 7e 40 00 01 f7 empfange
Servus! Pollin... aha! Gleich mal gucken... Vieleicht bestell ich dort auch. Na dann, wünsch ich uns mal viel Erfolg :D mfg BpM
Moin! Könntest du mir bitte mal die Bestellnummer für die Dioden und Piezos geben? Muss bei Reichelt eh noch paar Teile nachbestellen. (einmal angefangen bleibt es halt nicht bei einer MidiBox ;) Soll ich dir gleich welche mit ordern? mfg BpM
Moin! Also wird die ID doch über die Hex-Datei festgelegt! Dabei hatte ich hier im Forum gelesen dass, man die im Burner-Programm einstellen muss und nix mit der Hex zu tun hat. ??? Naja... gleich mal testen....... JAWOLL! FUNZT! ;D THX BpM
Hi erverbody! Couldt anybody explain me how I have to connect my display to the MAX232? I dont understand how... :(
Servus! Da kann man die ID nirgends ändern :(
Servus alle zusammen, ich habe folgendes Problem: Ich möchte die ID des boostraps ändern da aber icprog bei mir immer nur Fehlerneldungen bringt, hab ich es mit der Micrchipsoftware versucht. Klappt soweit auch, nur das die hex-datei jetzt den ganzen Speicher des pic belegt :( Das liegt wiederum daran (vermute ich) weil die ganzen Non-Operation-Befehle mit gespeichert werden. Die hex Datei hat nun ca 90kb. Also hab ich nur den Programmteil ab Adresse 7c00 als hex exportieren lassen da diese als erstes per GOTO Befehl aufgerufen wird. Nun sind auch die Größen der Hex Dateien bis auf paar byte gleich. (Liegt bestimmt daran dass, der erste GOTO Befehl fehlt) Nach dem anschließen: Hurra! Ich kann daten über den ComPort senden und empfangen. Aber leider bekomm ich anstatt der Sysex Meldung jetzt immer eine pitchwheel meldeung im 2 Sekunden Takt.. Weiß jemand Rat oder kann mir jemand mal einen Bootstrap hex für charakter Lcd mit Com funktion und SystemID 0 mailen? Wäre sehr hilfreich! mfg bpm Edit: Wie ich garade las, wird die ID nicht mit der Hex sondern über das BurnerProg selbst bestimmt... Mist! Wo doch IC Prog nicht geht... Weiß jemand die korrekten Hardwareeinstellungen für ICProg in Verbindung mit dem PIC Burner Modul von Thorsten?
Hallo Tk, ist in nächster Zeit mit einer MidiMerger Version für den PIC18... geplant? Habe noch einige übrig.. Wenn nicht muss ich halt noch mal einen PIC16... bestellen. Oder brauch ich da auch nur den 10Mhz gegen nen "20Mhzer" tauschen?   mfg B.p.M.
