tokyomatik
82 -
Everything posted by tokyomatik
i will try to be more clear if it's possible i have a vectorboard with a couple of eproms mounted on it one is supposed to be bankstick A, the other maybe one day will become the bankstick B to upload the presets i'm using the midibox patchmanager with the 8580 presets i don't have problem, the presets are already uploaded in bankstick A, the other bankstick is like invisible when both are mounted. i did a kind of experiment, i removed bankstick A and i tryed to upload the second presetsbank on my "i wanna be" bankstick B this presetbank is read by the midibox patchmanager as bank C so bank C is the source and bank B should be the destination(my second bankstick) but when i start the upload the MBPM says the C & B are not available so it's like to say that the id of the second bankstick is "wrong" if i upload the C as source and A as destination looks like working but when both banksticks are mounted is a bit messy to read the name of the presets it's like a conflict beetween two bankstickA if i try to select a bankstick from the CFG submenu from my midibox sidsynth only A is available even if both banksticks are mounted the connections on the bankstick board are ok, because if i move the eproms from one socket to the other, the sid is able anyway to read them but only when only one eprom is mounted what i need is to find a way to "change the id" of the second bankstick or stuff like that... how can i do this? is my explanation more clear now?
i tryed with everything now i'm using the tl's patch manager but i'm not able to access to the second bankstick i uploaded the 8580 bank in the first bankstick without problems then i opened the second patchbank and patch manager read this as bank C(?) so when i try to upload the patches, first says the C is not available and then says that B is not available.... also the midibox is not able to read the bankstick B just says <no bankstick> i'm sure that is not a problem with connections, but i don't know how to solve the problem....
nobody answer..... it's because my explanation was not clear?
i guys i tryed to upload the second patch bank in the second bankstick but the patch manager says that is not available so i tryed to change the order of the roms on the board and everything is ok i mean the connection, because the core is able to read both if for example i try to re-upload the bank n1 i have both roms with the same bank(?) how can i fix this?
i tryed to re-upload mios but nothing... and now the problem is double because i was needing a slave core so i tryed to change the id to another pic but during the upload i got a strange message and now i have the display that flash alternating "mios 1.9......" and some numbers like "700...." i don't know what happened... today it's not my lucky day....
thanx i'll try to re-upload mios and i'll let u know in the while i fixed that thing with mplab, but i don't know how... i deleted so many files that at the end is hard to say wich one was the cause of the conflict peace
...the pic was slow loading mios and also the initial drop tunes was slow and playing notes the pitch was wrong or strange
ok, i'll try later and i'll let u know
the corew is ok because i tryed it with other pics and it works... i get that message when i try to upload every kind of application
i guys i haqver also this problem i was working with this pic that sudenly becamed sloooowww as hell the core module is ok so i tryed to upload mios again but i get always this message 00000000372599 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372599 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120 00000000372599 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372599 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372599 ms | [F8] Timing clock 00000000372599 ms | [F8] Timing clock 00000000372599 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372628 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120 00000000372628 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372628 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372628 ms | [F8] Timing clock 00000000372628 ms | [F8] Timing clock 00000000372628 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372628 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120 00000000372628 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372628 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372628 ms | [F8] Timing clock 00000000372628 ms | [F8] Timing clock 00000000372628 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372628 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120 00000000372631 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372633 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372634 ms | [F8] Timing clock 00000000372635 ms | [F8] Timing clock 00000000372635 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372640 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120 00000000372645 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372645 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372648 ms | [F8] Timing clock 00000000372648 ms | [F8] Timing clock 00000000372649 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372654 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120 00000000372657 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372657 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372660 ms | [F8] Timing clock 00000000372662 ms | [F8] Timing clock 00000000372662 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372666 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120 00000000372670 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372672 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372673 ms | [F8] Timing clock 00000000372673 ms | [F8] Timing clock 00000000372674 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372679 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120 00000000372683 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372685 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372686 ms | [F8] Timing clock 00000000372686 ms | [F8] Timing clock 00000000372688 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372692 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120 00000000372695 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372696 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372698 ms | [F8] Timing clock 00000000372699 ms | [F8] Timing clock 00000000372701 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372705 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120 00000000372707 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372709 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372712 ms | [F8] Timing clock 00000000372712 ms | [F8] Timing clock 00000000372713 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372717 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120 00000000372722 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372722 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372725 ms | [F8] Timing clock 00000000372725 ms | [F8] Timing clock 00000000372725 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372731 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120 00000000372734 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372735 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372737 ms | [F8] Timing clock 00000000372738 ms | [F8] Timing clock 00000000372738 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372743 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120 00000000372747 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372749 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372750 ms | [F8] Timing clock 00000000372750 ms | [F8] Timing clock 00000000372752 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372756 ms | [80 78 78] Channel 1: Note Off C9 velocity: 120 00000000372759 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372762 ms | [80 00 00] Channel 1: Note Off C-1 velocity: 0 00000000372763 ms | [F8] Timing clock 00000000372763 ms | [F8] Timing clock did i fried my pic?
hi guys i'm re- trying to customize the setting for my lcd 2 x 16 using mplab so i create a new project and i copied all the sources files from the directory sid_v1_7303b i did my change to asm file and i pressed f10 but i got this error message how can i solve this? what's wrong? Make: The target "C:\sid_v1_7303\main.o" is out of date. Executing: "C:\Programmi\Microchip\MPASM Suite\MPAsmWin.exe" /q /p18F452 "main.asm" /l"main.lst" /e"main.err" /o"main.o" Error[151] C:\SID_V1_7303\SID_FRQ_TABLE.INC 20 : Operand contains unresolvable labels or is too complex Error[151] C:\SID_V1_7303\SID_FRQ_TABLE.INC 23 : Operand contains unresolvable labels or is too complex Error[151] C:\SID_V1_7303\SID_SIN_TABLE.INC 26 : Operand contains unresolvable labels or is too complex Error[151] C:\SID_V1_7303\SID_SIN_TABLE.INC 29 : Operand contains unresolvable labels or is too complex Error[151] C:\SID_V1_7303\CS_MENU_MS.INC 438 : Operand contains unresolvable labels or is too complex Error[151] C:\SID_V1_7303\SID_LCD.INC 89 : Operand contains unresolvable labels or is too complex Error[151] C:\SID_V1_7303\SID_PATCH.INC 65 : Operand contains unresolvable labels or is too complex Error[151] C:\SID_V1_7303\SID_SW.INC 1731 : Operand contains unresolvable labels or is too complex Error[151] C:\SID_V1_7303\SID_SW.INC 1734 : Operand contains unresolvable labels or is too complex Error[151] C:\SID_V1_7303\SID_SYSEX.INC 665 : Operand contains unresolvable labels or is too complex Error[151] C:\SID_V1_7303\SID_CC_TABLE.INC 41 : Operand contains unresolvable labels or is too complex Error[151] C:\SID_V1_7303\SID_CC_TABLE.INC 44 : Operand contains unresolvable labels or is too complex Error[151] C:\SID_V1_7303\SID_SYSEX_TABLE.INC 20 : Operand contains unresolvable labels or is too complex Error[151] C:\SID_V1_7303\SID_SYSEX_TABLE.INC 23 : Operand contains unresolvable labels or is too complex Error[151] C:\SID_V1_7303\SID_ENV_TABLE.INC 21 : Operand contains unresolvable labels or is too complex Error[151] C:\SID_V1_7303\SID_ENV_TABLE.INC 24 : Operand contains unresolvable labels or is too complex Error[151] C:\SID_V1_7303\SID_LFO_TABLE.INC 21 : Operand contains unresolvable labels or is too complex Error[151] C:\SID_V1_7303\SID_LFO_TABLE.INC 24 : Operand contains unresolvable labels or is too complex Error[151] C:\SID_V1_7303\SID_NOTE_TABLE.INC 40 : Operand contains unresolvable labels or is too complex Error[151] C:\SID_V1_7303\SID_NOTE_TABLE.INC 43 : Operand contains unresolvable labels or is too complex Halting build on first failure as requested. BUILD FAILED: Fri Mar 23 01:10:34 2007
ok, i removed the regulator and i replaced it with a bridge, now i power my core from j2 like on schematics but what about the rectifier? on my core v2 i have the rectifier and the voltage is 5,33v on r4d i checked the pins on ic1 and ic2 sockets and now i have 4,22v i need at least 1volt more... are u shure that i also have to remove that rectifier? i have to replace it with something or i have just to remove it? thanx guys 4 the help...
so i have to replace the regulator with a bridge and use j2....perfect... but from that schematic i also see that now the connection from core to sid j10 is 1:1, on the previous version was different if i'm not wrong but at the time i was using a v2 core and sid i can do that using an r4d core and a v2 sid?
my idea is to use this new core as a master for a sid synth when i tryed to measure the voltage on the connections for ic1 and ic2 i got 1.70v so basicly if i use the regulator(on v2 i replaced it with a bridge) i have to use j2...right or if i use j1 i have to remove rectifier and regulator? just to know if i understood...
so these are the results from my psu i i have 5,33 v i arrive to the rectifier and after that my voltage is 4,20v so is already 1 volt less after the rectifier i go to the regulator with 4.20v and after the voltage is 1.70v!!! what happened to my 5,33v???
so about the components mounted on my board i just followed the map printed on it, so...if the print is right i did it right and also the live map that is on the smashtv's site is pretty clear i also tryed to check the voltage on another core module bought from mike and the voltage is 5v so it's not a problem with my power supply (i use the original c64 transformer) i'll try to measure the after the rectifier and the regulator in the while thanx
i finished today to assemble my new core kit bought from smashtv but when i tryed to check the voltage instead of 5v i got 1,66!!! i tryed to check all the connections but looks allright what can i do to solve the problem?
hi guys i bought i new core module from smashtv it's an R4d and to me looks really differnt from the v.2 that i bought from mike i have a question about the pcb in the v.2 i was supposed to start soldering 4 or 5 bridges but here i have a kind of map printed on the board with all the parts names and doesn't says anything about those bridges are they obsolete on this pcb? thanx
i checked more or less everything and it looks ok, i'll double check everything from the beginning (it takes a lot for me to answer here because i don't have internet at home so all the times: go home, check and bla bla bla) the doubt is that with all that changing id to the cores and tryng to upload the mios again, both cores are giving me the same results with both lcds and going back to the problem with that 1k pullup resistor even if i changed it with a new one i still have that problem(my sid is slow) even if the display doesnt show anything, i can ear after a while the drop tune(really slow) and something that sound like formatting the bankstick(?) let me know thanx there is the possibility that messing with the mios and the change id app.the two cores, i did the disaster i also got a black out but not during the upload to be shure that i don't have short in the pcb wich connection should i check exactly? i checked the connection of the pic and the optocoupler ic1 pin 1 pin 12 ic1 pin 11 pin 12 ic1 pin 31 pin 32 ic 2 pin 5 pin 8 and on both cores i got 5v so what else should i check?
MOOG PRODIGY With AUDIO IN & nifty 'FM' feature FOR SALE...
tokyomatik replied to Artesia's topic in Fleamarket
how much for that sexy machine? -
2 SID KITS WITH 6581 / 8581 CHIPS AND 2 CORES AND P.SUPPLY FOR SALE !
tokyomatik replied to dcreatorx's topic in Fleamarket
i offer a couple of tshirts and 2 trucker hats - really cool design trust me!!! in italy they cost 25 euros each... if u want i can make u a surprise or i can send u pictures -
mmmhhh....a short.... how can i fix it?
another thing if i try to upload the new mios( i tryed allthe 3 types) using mios studio i get something like hex contains code in mios range forcing reboot!! or it start to upload the first line and then nothing....i wait wait wait...
ok guys as usual i have some problems my last post was a problem (apparently) with the 1k pull up r2 i removed the old one with a brand new one but now i don't know what... the lcd instead of the usual start up shows strange simbols or lines and nothing else i tryed with another lcd but i got the same results basicly all the problems started a while ago when i decided to upgrade my mono sid type c with a new module (i bought both kits at mike's pcb shops) so i updated one of the core with the new firmware, application changed the id to the other one, firmware, application removed the optocoupler but together they never worked!! (i also never solved the problem with mplab for my 16x2 lcd ???) then suddenly the problem with some midi out messages(1k pull up??) and now i got this with the lcd if i use mios studio i don't get any request of upload should i buy the jdm module and reburn the bootloader inside the pic and reprogram everything from the beginning or is something easier? let me know
i started my sid with a bankstick connected and it takes alot to load the mios and the sid app, then, the drop tune is slow and if i try to play some notes the volume goes up & down and the pitch change the same happens if the bankstick is disconnected then i got other stuff... i tried to reconnect the bankstick and the sid tries to reformat it and the best of all is that it tries to do it even without the bankstick!!! so if nobody was able to answer to my problems with MPLAB i can imagine what will happen with this......no answers so i gotta keep it like that?? let me know thanx
