SLP
1,149 -
Everything posted by SLP
Hi, apparently the 12-year younger me thought that this would be a great project to build "some day"... So here's a PCB that's been collecting dust for quite a while. (Actually not that much dust, since i found it at the very bottom of my "Things to build" cardboard box...) The silkscreen is a bit unfortunate contrast-wise. It says "Dual SSM2044 VCF, T. Stoeckl 2008" cheers, Matthias
Hi there, One empty case and three keyboards are looking for a good home. these things have been collecting dust on my shelf way too long. Everything will be shipped together in one packet. No cherry picking here, folks ;)
Hi there, I'd like to get rid of some partially assembled DIN/DOUT PCBs. 5€ / 5,5mBTC per PCB (shipping included) For Free! cheers!
gone! Hi there I'm about to move out of my flat, so I'd like to get rid of some stuff like this GM5x5x5 PCB + GM5-IC. I'm selling both for 25€ or 28mBTC (shipping included).
Salut! je vais etudier au école centrale de septebre à février, et comme je voudrais continuer à faire du musique, je cherche un clavier, synthetesizeur ou un controlleur-midi. J'espère qu'il y a quelq'un dans cette region, qui peut se passer un instrument. Mes instruments sont trop pesants pour l'emporter et je ne veux pas acheter quelque chose pour cette temps courts. -matthias
Hey there! University is a bit tougher than i expected ;) I'm still somewhat active, but I felt that I should show you some kind of sign of life. There was a competition at the university (www.adveisor.ei.tum.de). The challenge was to build a robot that can solve a rubik's cube in less than 150 sec. Well, among the 8 teams, only 2 robots were more or less working. And though our robot had some mechanical issues, my team won the competition! Probably because we had that 'special' feature ;) Unfortunately there wasn't enough time to add MIDI-Support...
Sich ab und zu mal gepflegt die Kante geben ist ja nicht prinzipiell schlecht ;) Und 200€ Warm für ein 12m²-Zimmer in einer WG mit großem Wohnzimmer, Partykeller und Haushälterin/Köchin sind so ziemlich "unschlagbar". Trotzdem wäre mir jede Wohnung im Umkreis von ca 5km um die Uni recht... also,.. falls da irgendwer was weiß...
Burschenschaften sind IMHO eher etwas rechts-konservativ... da würde ich aufpassen. Liberale Verbindungen sind leider selten. Wichtig ist nur, dass man keine "schlagende" Verbindung erwischt... außer man steht auf Fechten :blink: Das mit den billigen Zimmern funktioniert auch nur deshalb, weil du als "Alter Herr" auch nach deinem Studium deinen Jahresbeitrag zahlst... quasi eine Art Generationenvertrag, also nicht unbedingt schlecht.
Nach langer Midibox-Abstinenz nun mal wieder ein Post. Ich hab da nämlich ein Anliegen... :whistle: Dieses Wintersemester fängt mein EI-Studium an der TUM an. Und da ich nun schon seit über zwei Monaten hoffnungslos auf Wohnungs-/WG-Suche bin, wollte ich mal fragen, ob mir denn hier jemand irgendwelche Tipps geben kann, wo denn im Umkreis von ca. 3-4km um die Uni (Stammgelände, nicht Garching) noch Wohnungen oder WG-Plätze frei wären... Ich bin für jeden Hinweis dankbar. Hat eigentlich wer Erfahrungen mit Studentenverbindungen? mfg matthias p.s. dieser Thread darf auch gerne nach 'Misc' verschoben werden.
Hi folks, have a look at the free PCB design tool at http://www.designspark.com/ might be interesting for some of you. mfg matthias
hi folks, I'm about to build a bigger VU-meter using the LM3915. The IC has open collector outputs which can sink 30 mA max. I need 120mA per output. first Idea: 4009 inverting buffers (with pullup reistors) and some ULN2803 (or 2804) driver ICs. But I guess, that's pretty hardcore. second Idea: would a simple PNP-transistor per output work? Any Idea, which type would be suitable for 120mA@5V ? thanks in advance.
You're calling that a resistor? THAT's what I call a resistor!
wouldn't a pot wired up as voltage divider work? I don't know about the linearity between CV and Cutoff Freq. You might end with using a log pot.
Bilder machen. Löten lernen. Dann wird alles gut. :flowers:
Ich weiß nicht ob dir hier jemand helfen kann. Aus dem C64 werden hier meistens nur der SID-chip und manchmal auch das Gehäuse "recycelt". Im englischsprachigen Forum stehen deine Chancen auf jeden Fall besser. Ich weiß nicht mal, von welcher Anleitung du sprichst.
two NE555 (556) and a "AND" gate or something?
can you paste the link?
That. is. so. awesome. must. have.
never give up! :) http://nic-nac-project.org/~rocket/midi/ http://www.ucapps.de/midibox_plus_de.html Thank you, Thorsten ;)
LT-Spice?
yep. J2 is your port of choice. I'd desolder the 7805 anyway. just to be sure. And take care of the polarization!
well, If you don't want to mess with USB power requests, there is a simple workaround. I've bought a USB-Hub at RadioShack some time ago (GM5*4= 20 MIDI I/Os - yeehaw! (I discarded the Idea after I realized that this would be a slight overkill)). The cable that came with the Hub had a mini-USB plug on one side (for the Hub) and two (!) USB plugs for the PC. I've attached a picture, so you know what I mean. I've just checked it with my multimeter, and it seems that the power-lines of the two plugs are connected in parallel. This way, you could increase the max current to 200mA. I don't know if this way of increasing the current really works (there is a jack for an external PSU...). It doesn't seem to do any damage to the Hub it's connected to right now. Perhaps you should search the internet for connecting two USB cables in parallel if you like this workaround.
omg. The MidiboxPlus Page has vanished. TK: WHY?!? ;)
