Hi It seems that the "problem" rise when the unit is "hot" / after an hour or so. Typica symptom is: When in song mode, the led above (pattern) flashes in a high frequency, the led above pattern again flashes too, but not as bright as pattern led, same thing with track 1-4 and layer a-c. The steps leds is quite the same manner as above, the led next to the selected step, flashes. It is not in sync with the beat. One other thing.... when the flashing happens (after some hours in use), the buttons for step 9-16 stops to work, I have to power down/up the unit, to get them operational again. Same thing happens with the encoders. When the unit is cold (from powering on) it all works ok. But pressing and holding ie the song button, creates the same flashin as described above. I'm powering the unit with an external power adapter with the spec: 9VDC / 600mA Can this be caused by too little poweradapter in combination with overheating of the 7805 ? I've adjusted the pots for the brightness @ the lcd's down to keep the heat of 7805 down... I have not mounted the buttons / leds on any pcb, but hard wired them directly to the multiwires (scsi-hard-disk-type), the ground is a common wire that run in line with the leds/buttons. The common ground is not connected between other units, but ie 8 step leds connected, 16 step buttons connected together etc... same with encoders. Hope this is helps Best regards Ole P
