URBatORB
27 -
About URBatORB
- Birthday 10/28/1979
Contact Methods
Website URL
http://www.myspace.com/urbiwan
Gender
Male
Location
Southern Germany
URBatORB's Achievements
Only 1,62 V at the 5 V output of the improved PSU
URBatORB replied to URBatORB's topic in MIDIbox SID
Hello, Hello, second measuring directly at the C64 PSU: At the 5 V DC = 8,9 V At the 9 V AC = 10,2 V At the 5 V improved PSU 2,3 V At the 14 V improved PSU 17,6 V I think I found the failure. It is a short circuit / loose connection between 5 V + and - at the original DIN Connector from the C64. The circuit indicator peeps sometimes if i connect it between the + and the - PIN-connection (the C64 PSU is not connectet during the test). Or is it due to the unloading of the capacitor(s)? Nevetheless, the C64 PSU is damaged :'( -
Hello, that's very curious. When I test the voltage directly at the C64 psu plug, I get 10 V. I had the 5 V before I connected the improved PSU to the Core Module. But I can't find an error at the Core Module (as recommended the 7805 is not stuffed and I have shortened the input/output line at the board and connected the psu to the J2). Mhmmm, I'll test the Core Module again later. I'll stuff the 7805 and test the Core Module with a cheaper wallwart, maybe there is still an error. But another question, can I destroy the C64 Plug by an error at the Core Module? -
Hello, I get only 1,62 V at the 5 V output of the improved 4xSID PSU. If I measuren the 14 V output I get 14,19 V - that seems to be OK. But what is wrong with the 5 V output? Can anybody help? /Daniel
Yes stryd_one, agreed, crashes are a risk with every software. But I never had one with Live at a session. Just keep your System clean from any unneeded software, disable wireless lan, bluetooth and so on and of course use premium hardware. Then everything will be fine. ;) For the beginning without any outboard a software will be alright. But consider, that you possibly need some additional (VST-)softsynths (Reason for example is full equipped and you can't expand it with 3rd Party Products). Live has only the Simpler and the Impulse. But it's expandable with al lot of 3rd Party Plugs. /Daniel
Hello, Cubase and Logic are more for Recording purposes. Both programms are like a virtual multitrackrecorder - and therfore not really good for live purposes. I worked for Years with Cubase until I got Ableton Live. Ableton Live is good for recording, remixing and of course for live performances + DJ Sets. Ableton Live is very intuitive and flexible, like a mixture of a multitrackrecorder and a MPC (Did you ever worked with a Akai MPC???) with a lot of integrated effects. There is too much to say. Get the the demo from www.ableton.com, watch the videos which are showing Live's functions and trust me you'll be amazed.
Die Shop-Cookies sind bei SLP auf der Platte, daher die Fehlermeldung. Conrad hat neuerdings eine TÜV garantierte Preisstabilität. Hehe, das wundert mich nicht wirklich.... ;D Reichelt hat seit kurzem ALPS Fader. Guckst Du hier: High End 100 mm ALPS http://www.reichelt.de/?SID=26X3sXxKwQARoAACpD7g8aef55fac2ebe136a1a3f0185a79ea058;ACTION=3;LA=2;GROUP=B28;GROUPID=3713;ARTICLE=73879;START=16;SORT=artnr;OFFSET=16 Preis/Leistung 100 mm ALPS (Stereo) http://www.reichelt.de/?SID=26X3sXxKwQARoAACpD7g8aef55fac2ebe136a1a3f0185a79ea058;ACTION=3;LA=2;GROUP=B28;GROUPID=3713;ARTICLE=73873;START=16;SORT=artnr;OFFSET=16
Difference between rectifier B40C800 and B40C1000
URBatORB replied to URBatORB's topic in Parts Questions
OK, I wasn't 100% sure. ;D Thanks -
Thanks for the fast reply. I ordered a B40C800 and got a B40C1000. Now I think the B40C800 were simply out of stock. I have a square DIP Version. I looks like that one: ~ IIII - ~ IIII + Do you know were I have to connect the 9V AC and the conduction from the Powerswitch? I can't find information according to that rectifier version. Daniel -
Hello, what's the difference between rectifier B40C800 and B40C1000. Or better for understanding; what does the indentification say? B = ? 40 = 40 volts C = ? 1000 or 800 ? Can I use a B40C1000 instead a B40C800 for the improved SID PSU? Thanks, Daniel
Lets go shopping :) ... your input wanted
URBatORB replied to thestruggler's topic in Parts Questions
Hello, I'm very satisfied with the Alpha Pots. I have these: http://www.banzaieffects.com/Alpha-16mm-split-shaft-10k-lin-pr-17257.html I think my pots are nearly the same as yours, but with a shorter metal-split-shaft /Daniel -
Ja, danke für die Info - ich hatte die ganze Zeit schon den Eindruck etwas übersehen bzw. überlesen zu haben. dh. 'nen "Single-Sid-Synth" könnte ich mit dem PIC18F4260 machen, zum späteren Kaskadieren benötige ich jedoch den PIC18F4685, den ich, weil das Board kompatibel, ist einfach austauschen kann. Die Slavemodule kann ich dann kaskadieren indem ich die ID der Slave-Pics entspechend ändere. So nun hab ichs wohl auch kapiert. Danke ;), Daniel
Hallo, so, da bin ich wieder, nach dem chronischen Freizeitmangel der letzten Monate möchte ich endlich noch das Frontpanel meiner Midibox64 fertigstellen und parallel den Sid-Synth beginnen. Nun habe ich mal so ein paar "Feststellungen" unten aufgelistet (die mir der ein oder andere hoffentlich bestätigt) um sicher zu gehen, dass ich hier keinen Fehler mache: -> SID Synth V2 benötigt den PIC18F4620 -> Auf dem PIC18F4620 läuft auch V1.7 mit dem angepasstem MIOS und Bootloader -> Für eine Kaskadierung von 2 Sids (oder mehr) benötige ich zusätzlich zum Core Module noch das MBHP_IIC_MIDI -> Die aktuellen Core-Platinen sowie SID-Platinen können für die V2 verwendet werden. -> Bis auf die Änderungen des CC- (neu Page up), Edit- (neu Page down), Link- (neu Shift) Buttons ändert sich nichts am Panel von TK -> Auf der Wishlist steht noch was von von der Verwendung des PIC18F4685 (wegen des ECAN Interfaces) - den kann ich doch später bei Bedarf austauschen?? ggf. das ges- amte Modul??? Grüßle, Daniel
Hello guys, Im finally back again. I had to do a lot the last few month in my company (part project leader in introducing a new business software for the investment management....) since I began my Midibox 64 project. So the spare time wasn't enough for all my hobbies. The panel is still in development (the very beta is at the gallery) but the parts for my next project, the SID Synth, are ordered ;D. In my opinion the first post should be a link to my myspace account where you can listen to my latest tracks. Enjoy it - an feel free to post your (honest) comments. http://www.myspace.com/urbiwan Regards
The Joysticks from my Thrustmaster Joypad are working with my Midibox too. From one I had removed the spring - it still works fine. :D /Daniel
... so das Problem mit den doppelten IDs bei den Tastern wäre gelöst. Nach näherer Betrachtung (und ausgedrucktem Schaltplan!!!) fiel mir auf, dass ich die Taster an J6 von D1 bis Vs angeschlossen hatte anstelle von D0 bis D3 (peinlich). Tja, manchmal muss man(n) einfach nochmal darüber schlafen. ;)
