91 -
Everything posted by Flying Panther
I don't know what the EUSART MIDI is about, but if you just want to add one or two midi ports to your PC, I can also recommend the midisport 2x2! Worked with one for a couple of years, and it never let me down ;) (upgraded to a midisport 4x4 lately since I needed more in/out) If you search a bit, you could be able to get one second hand quite cheap
Hmm.. I was hoping that if I supplied every core module with a separate 7805 it wouldn't get that hot. So this means I'll have to get the voltage to about 7 or 8 V before feeding it to the Core's? To get an idea of the heat, what kind of temperatures can I expect when I connect 12V to a 7805?
I think you may have missed something here.. The prices from SmashTV are in dollars. When you convert the dollars to euro's you'll see that there is almost no difference between prices from Mike and Smash. About two weeks ago I checked Reichelt for parts, and I found that on most parts they added a couple cents to the price (when compared to the orderlist on ucapss). Also keep in mind that Reichelt has a minimum order of €150 for shipping abroad..
I'm still struggling with the PSU and I thought of a new way to power all components (see the attached scheme). I'm not sure this will work, but I'd like to use a 230V to 2x12V transformer, with 12V out one and 12V out two. Both 12V one and two will go to a circuit that transforms the two 12V AC inputs to a symmetrical 9V DC output for the opamp. The 12V one will also connect to the four Core modules, and the 12V two will connect to the eight SID modules (V2-setup). If this will work, would a 2x1A transformer do the job? Or should I get a 2x1.5A one just to be sure? (SID's will consume about 100mA each, Core's, LED's and LCD also around 800mA total I think?, don't know about the opamp-circuit)
2 pin IDC connectors? etc... I can't find these
Flying Panther replied to Slorrin's topic in MIDIbox SID
I think this it what you're looking for :) http://www.midibox.org/forum/index.php?topic=8498.0 -
Intresse in MEC Multimec switches (evt. met LED)?
Flying Panther replied to Flying Panther's topic in Nederlands
Ik heb inmiddels via een ander lid vernomen dat het ook mogelijk is om zelf een LED in de standaard 3F switches te zetten. Dit is natuurlijk wel wat gepriegel, maar daardoor zou ik met 1 setje van 50 normale klaar zijn :D Heb ik wel een berg kapjes over, maargoed, daar betaal je ook niet de hoofdprijs voor natuurlijk ;) -
This looks really nice! 8) You can see by the results that you put a lot of effort in planning this box. I'm curious how the frontpanel looks when mounted to the PCB with all encoders, leds and buttons in place :)
The stereo volume effects sound great! Too bad it also comes with noise, but I guess we can't have it all ;) Wilba: Thanks for the explanation :) I'll consider the extra V2 features on the layout, don't know yet what to implement and what not, but hey, dual color leds are always a cool feature :D
It seems I have to read in on the Sid V2 options ;) My plan was already to first complete the inside of the box and then, when V2 is (almost) ready to make the casing (and adjust the frontplate if necessary). But.. I thought V2 didn't involve hardware changes (exept for extra 2x Sid per Core and new Core PIC's). Since that thought seems to be wrong, I'm going to read into that again, and check the customizations I might need in the control panel. Just to be sure, If I make my Core and Sid modules now, I can reuse the Core boards (swap the old PIC with the new V2 version), add an extra SID to each core and leave the 'old' Sid modules as they are?
Voor mijn MB SID heb ik bedacht om Multimec switches te gebruiken, om een aantal redenen, 1 omdat ze er netjes uitzien, en 2 kwalitatief ook gewoon goed zijn, en 3 omdat je dezelfde switches met en zonder LED kan krijgen. Aangezien ik nergens deze switches in de winkel kon vinden, heb ik even contact opgenomen met de importeur van deze switches. Het vervelende is dat deze switches en kapjes per 50 stuks verkocht worden. Voor de gewone is dat nog niet zo'n probleem (hou ik er 15-20 over), maar voor de switches met LED erin is dat toch jammer, omdat ik er hier van de 50 maar 8 nodig zou hebben, en ze in verhouding met de gewone redelijk prijzig zijn. Het zou mij gaan om de volgende types: 'normale' Switch, through hole montage (3F T L6): € 0,74 p/s LED-Switch, through hole montage, rode led (3F T L6 80): € 1,48 p/s rechthoekig kapje Zwart (1X 09): € 0,17 p/s rechthoekig kapje Frosted White (1X 16): € 0,17 p/s Op deze switches kunnen ook kapjes in andere kleuren gezet worden, maar ook in andere vormen (alles per 50 stuks). Andere kapjes zullen denk ik niet veel duurder zijn dan de kapjes die ik heb uitgekozen.. :) Linkje naar de catalogus van MEC, met de overige specificaties en verschillende kapjes: http://www.mec.dk/filedownload.php?fileId=374 Als er dus nog andere mensen geinteresseerd zijn in met name de switches met rode LED, dan kunnen we misschien samen iets regelen? 8)
Hallo! :) Ik ben druk bezig met het verzamelen van alle onderdelen voor mijn MidiBox SID, (zie ook hier), en wil graag een rode lcd inbouwen. De enige plek waar ik die tot nu toe gevonden heb is www.crystalfontz.com, maar incl shipping zou ik dan op 65 dollar komen!! Dat vind ik echt te ver gaan voor alleen een lcd, dus misschien hebben jullie nog goede ideeën waar ik zoiets kan vinden? Als er meer mensen zijn die iets van crystalfontz willen bestellen, dan is dat misschien ook nog wel een optie natuurlijk. Voorbeeldje van hoe het totaal eruit moet komen te zien staat hier (edit: dollar en euro is natuurlijk niet hetzelfde ;))
1. Where do i get SID chip(s)? I dont have any old C64's and buying those rare old machines costs a fortune? Is there someone selling SID Chips? As far as I know there aren't stores who sell SID chips, since they have been out of production for a long time. I think you'll have to search on the internet (for example ebay) and buy either the chips or complete C64. Shouldn't be too expensive. You can also check flea-markets for old C64's. 2. What is the difference when you have 1 SID chip and 4 SID chips and how bout 2 and 3? How many should i have? The diffrence is how many diffrent 'parts' the MBox can play at the same time. Also, since the SID chip delivers a mono-sound, you can pair two SID's in order to achieve stereo-sound. How many SID's you want is up to you. 3. Can i have the Complete Control Surface with only 1 SID chip? Yes 4. Internet site in Germany that sells electronic parts Uhm, maybe reichelt.de or conrad.de? Hope this will help you a bit! :)
Ah, I forgot to mention that I will use the 7809. But that might indeed be a bit double, having a DC psu and stuffing the 7809's. Maybe it would make more sense to use a 9v DC psu and leave the 7809's out?
First of all, Twin-X and toneburst, thnx for the reply's and help with the prints :) So it's been a while since I first posted here, but there is some progress in the project! I made a plan on how the final result should look like (it might turn out a little diffrent but hey, plans can change ;)). This is how it should look like when finished (4HE 19"). At the moment I'm collecting all the parts and tools needed to start and complete the project. I got most of the parts, and I found a nice red backlit 2x20 LCD (about $27,-) on www.crystalfontz.com, but using their calculations the shipping will be around $37,50. Since I don't need other parts or anything from crystalfontz, the lcd will cost me about 65 dollar :/. Maybe someone here knows a place in europe where they sell similar LCD's so I can reduce the shippingcosts a bit? Now for the PSU. The main problem is I want to build-in an active mixer which combines the four sid outputs and creates a mono 'mix' output and a headphone out. This means I have to use an op-amp and need a symmetrical power supply. I'm not sure what to do with all the psu's because now I will need a 5v DC for the cores, a 12v AC or DC for the sids (8580 needs only 12v input if i'm right), and a 9-12v symmetrical DC for the mixer. I'm thinking of using a 5v DC and 12V DC PSU from Cincon and this kit (or maybe build a similar schematic myself) with a 2x15VAC transformator for the symmetrical psu. Only problem is that this option uses a lot of space. Are there any options to improve this? I thought of the option of getting a big 15VAC transformator, which can feed the sids and the symmetrical-schematic-thing. But it's stated everywhere you'll need a 2x15VAC transformator for that, so I don't think that will work very well.. ??? All help will be appreciated!! :)
While an old C64 is resting and waiting for someone to rescue it's characteristic sound, I though now would be the time to give the SID a new life. At that point I came across the Mbox SID project, and now there's no turning back :) At this point I'm planning on the functions I should implement and where to buy which parts. I'm quite new to micro-electronics, so I might be going to say some stupid things (according to the Mbox SID-building veterans around here), but I hope you will correct me at those points ;) Project outline: What I'm planning to build is 4 times the SID with a Step C controlsurface plus some minor alterations. I will include an 8x bankstick-board as well as the LTC board for MIDI I/O monitoring and the MIDI Thru port. I also would like to include a mono 'mix-out' and headphone output, both with volume control. I have some rough ideas about this, but no clue if it's possible to (easily) realize this feature. The whole project should be packed in a desktop metal case, with the option to attach rack-ears. The PSU: I saw there are many topics about the PSU, but I couln't really find a satisfying answer to my questions. I have the original C64 PSU, so it should defenatly be possible to use the 'optimized PSU'. But... The C64 PSU hasn't really proven it's stability for me in the past and I really dislike external adapters / transformers. From what I've read, the main issue with using another PSU is the voltage diffrence (5V and 14V) and the signal/noise ratio. For the purpose of testing I could still use the optimised C64 PSU, but in the end I'd prefer something more stable, safe and 'new'. Would it be a good idea to get 2 separated PSU's, like a 14V DC and 5V DC PSU or maybe a 5V DC and 9V AC PSU using the optimized PSU scheme? I couldn't find a real 9V AC PSU, only external adapters or 230-9V transformers. The transformers are quite cheap (€3-10 compared to €30 for a 5V PSU) but I have the feeling it can't be that simple: Putting a transformer on 230V and have 9V without the risks a real PSU will exclude. Also 14V DC PSU's seem to be non-existing or hard to find. The mix and headphone out with volume control: What I had in mind is to route the 4 individual outputs to a volume pot-meter. The resulting (mono) audio will be forwarded to one mono output (mix-out) and also to a stereo output for the headphones. (ofcourse no true-stereo will be achieved here, just the same mono-signal on the left and right channel). My 'only' problem is that I expect the 4 SID outputs to be at line-level and don't know how to combine these four channels and get line-level again. I also must say that I didn't really read myself into this, which mainly is because at this moment this isn't a big issue, but it would be nice if it's possible at a later stage 8) The controlsurface and design: When building, testing and completing the Mbox SID I will use a cheap plastic box; There's need to look beautifull at this stage. This will also give me some space to make adjustments to the layout without making a new metal frontplate. I'd like to change some minor things to the Step C controlsurface. I'm thinking of replacing the detented menu encoder with a pushable one. The knob function will be replacing the menu button. I also like to have knobs with integrated leds for the SID-selection, CC, Link and Edit selection, since those buttons will only trigger one LED. Buttons that will switch multiple leds will still be 'blind' knobs with independent LED's. These adjustments are not essential, but just a nice thing to implement and give the design some 'personal touch'. The parts: I'm planning to get the main parts from www.mikes-elektronikseite.de and the rest from the local electronics shop and www.conrad.nl. Parts to get from Mikes': 1x MIDIbox SID 8580 / 6581 + CS (Kit) 3x MIDIbox SID 8580 / 6581 (Kit) 4x PIC18F452 (Bootloader) 1x LTC_V2 (Kit) 1x Bankstick board 1x Eeprom 24LC512 for banksticks (8x) Other parts to get: - 2x20 LCD - Buttons - Potmeters - LED's - Vectorboards (for the buttons, pots and LED's) - (Ribbon)cables - Cable connectors for prints - Midi port connectors - Jack connectors - Parts for the optimezed PSU, or other solution - Some ugly plastic box ;) I've read in other topics that people ordered PIC's from SmashTV, even when they live in europe. Are there any diffrences between the PIC's Mike offers and the ones from SmashTV, or are there other reasons why the PIC's from SmashTV seem to be preferred? In addition to all this, are there things I spefically should or shouldn't do (like adding or removing / combining features to the controlsurface)? Ofcourse all comments are very much appreciated :)
