wicked-E
    40
About wicked-E
  • Birthday 07/16/1983
  • Gender
    Male
  • Location
    Wood-wicked-e
wicked-E's Achievements
MIDIbox Newbie
  1. count me in for 100 as well :)
  2. Works fine now, after "understanding" what code line works for what everything´s so mutch easier. Current Setup: LCD, BS, 24 Encoder, 12 Buttons. As u know it´s really easy to build additional modules if u got a "ground-setup" working so maybe my next post will show the (momentary) end-result if u r interessted ;D
  3. Take some modifications to the mb64 code and it works. Not 100% like I want it yet, (SR 3 + 4 doesn´t do what I "say" *smile*), but the rest works fine! Got a minimal mb with LCD, 4 buttons and 6 encoders working, the rest seems to be only change the mb-code at a few points. I´ve learnt so much about "programming" a mb since the last days , thanks a lot ...I´ll keep u updated ;D
  4. Got it since 5min, thanks a lot(!) Same here, but nothing to worry about ;D
  5. Hi Folks If most of you out there realy can´t live with the result I can maybe help. I work in a silk-screen-factory and I think I´m able to do a reprint by myself for us when a generally intrest exist. Don´t know about the costs yet, but seems like 5 - 10 € per Panel + s&h (maybe cheaper, must check it). I know that´s not the best deal at all and first we have to check what the "original-seller" have to say but if anyone interested let me know an I´ll see what I can do ;)
  6. Yes, and it works, the encoder-speed-test also passed. ...think I´m getin´ closer to full access -write on the ap at the moment. Some special hints?!? :)
  7. There must be done some manually changes to the originial design if the orig. was in perfect condition ´cause normaly u got the hole picture, "expose" it to film, than expose the silk and then print every color, (here only one), get a heading and then the next one. For perfect condition of "lighter" color on dark ground I prefer high-pigmented-colors, but normally you got what you got and so an aceptable way is to print a second time after inter-dry off the print. It seems that they don´t do this to our panels, as well as don´t check and clean the silk every few prints from dust or st like that "in" the picture so some people get "holes" in their screenings. My own panel looks okay, little colourless at a few tiny locations, but quite aceptable at all so I thing only a few of all looks realy bad. Maybe other "owners" can explain how their panels looks like!?
  8. Connect a LCD Display in the meantime -works fine and i love the "blue" ;D Hope that I´m able to find some more specific details when upload but get no further than "Mios V 1.9f TK..." than... Int.1 [][][][][][][][] 1|CC# 7 [127] [] Got no incoming midi-messages by any encoder. I connect the din-board for testing to J9 of the core, and realy -one encoder of the 16 works fine so I space out a wiring error. Can me somebody get a hint what to do please!?....
  9. It seems that nothing will be send, means no incomming midi events. After "reset" of the mb appear this messages: TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT 00004579 Del -- F0 Buffer: 8 Bytes System Exclusive 0000477F Del -- F0 Buffer: 8 Bytes System Exclusive 00004EE6 Del -- D0 1A -- 1 --- Channel Aft after that, nothing else, what ever I do. So i think my problem must a fault or inclomplete code-upload. Can somewhere found a prog for testing if everything right installed!?
  10. Hiho In the last days i´ve build a small midi-controller based on a core-modul with pic 18xx, and a din-modul with 16 rotary-encoder (from voti). Connectect J1 of the din to J6 of the core (...like explained at the mb 16e din description) Everything works fine, Vss and ground are aviable as they should be, (checked with a multimeter like anounced at ucapps), and i´m well able to upload something by mios. But here are my end of the "easy going" :'( I´m not able to assume wich hex files I should upload, tryed the main.asf und the mb16e.asf found in a zip-file called "midibox64(e)". Works, but I´m unfortunately unable to use the mb examply in reason to controll the Potis and so on ´cause midi-learn doesn´t take any effect. Can somebody explain or show me a link where i can find what I have finally to do so that my mb will work?!? Kind regards...
  11. Got it, thanks man! :)
  12. Recieved a paypal-message today that my panel are shipped -GREAT ;D
  13. Think so, look here at the stock-list, but it´s exclusive any tax or s&h that´s why i´m asking. :)
  14. Is there maybe an error in your price-calculation, ´cause you´ll get the two PCBs for a total amount of 60USD (=ca. 42€) from adafruit-industries directly, or include your price tax and s&h to germany as well!?
