groovereiter
18 -
Everything posted by groovereiter
Anyone interested in buying parts from my unfinished project? 1x core v3 module with PIC 1x ain module (both from mike) 2x DINx4 1x DINx2 (made on breadboard/Lochraster, 10mm thin, pin connectors w/ plugs, working stable) 50x button, black, "Digitast" (Reichelt DT 6 SW) 2x button, white, "Digitast" (Reichelt DT 6 WS) 26x Alps pot, 10k, vertical, 6mm (Reichelt RK09K113-LIN10K) <- those are great 2x Alps slider, 10k, 60mm travel (Reichelt RS60112-LIN10K) <- those are great too ;) 2x Alps encoder, 24/24 - removed detention, w/o button, 6x11mm (Reichelt STEC12E07) 1x Alps encoder, 24/24 with detention, horizontal, w/o button, 6x11mm (Reichelt STEC12E05) No caps for the pots & encs included (except some unique mousewheel & jogs for the encs ;)) All controls are soldered on breadbord, you'll have to desolder them by your own but it's done quite easily. Every PCB has pin connectors with the fitting plugs for easy disconnecting/connecting. If you need photos I can take some, but it should be quite self explanatory I guess. Soooooo, awaiting your bids...
LC (Mackie mode) not working in Cubase
groovereiter replied to groovereiter's topic in Testing/Troubleshooting
It seems the to-com option causes the problem. I uploaded the lc application to my mb64e wich is connected via the gameport and everything works fine. Now I have to wait for my MIDI-to-USB cable to see if it works with that. -
Hi, my LC runs fine in Mackie mode (Reason, Ableton) but Cubase doesn't get any midi from the LC, midi to LC works fine. When I change to Logic Control mode the controls & leds work, but the displays don't :( Has anybody got a solution for this? Thanks groovereiter
Anyone interested in Alps "N" type motor faders?
groovereiter replied to Doug Wellington's topic in Bulk Orders
Has the second batch already been ordered? I would love to get mine with this too -
Where do I start?
Ok, I will use a second core. Any hints for making the first four buttons send a midi event?
Where do I have to connect the second SR chain to make this work? And wich changes do I have to do to the code? I didn' work on the box for some months so I'm completely out of it and I don't have much time for it in the next year. Since the Hardware part is already done any help is appreciated.
Hi, I built a box with 32 AINs and 80 DINs and the 64e application only handles 64 of them. How can I make them usable? I tried changing the F in "incf TMP2, F" under MB64E_BUTTON_Map_Loop in mb64e_buttins.inc but it didn't work. And how can I make the first four pins of the first shift register send a midi event? I know the ain64_din128_dout128_v2_0 application handles all buttons but not my 3 encoders. Maybe I can add the encoder to this? Thanks for all hints
Mhh, I think if the parallel wiring doesn't work I'll go for two monitor cables then. Thanks a lot
Thanks for your answer. The reason is quite simple, I would need 16 extra wires for the buttons and leds in the cable between the two units. Together with all the power/ground, SR lines and the wires for the assignment display this would be a quite fat cable. I fear this would also heavily increase the latency because the DIN registers are read periodically. Currently I'm using an old monitor cable (18 wires).
Hi, after two years I'm close to finish my LC now. It consists of two units with one core. One Unit is the mixer and assignment part and the other is a small one with the right hand side of the LC with the MTC display, jogwheel, transport- and function buttons. My problem is, that I want some buttons to be present on both units. But since my LC is fully loaded there are not enough shift registers left to define them twice. I guess it isn't possible anyway to define two pins to the same function in the lc_io_table.inc. Now the question: is it possible to wire the serial chain line parallel to two SR's so that they both are handled as SR number 6 and if I push the play button on SR6a both play-LEDs on SR6a and SR6b light up? I'm REALLY hardly trying to avoid building another core for the second unit, at first I'm trying to save money (for the MFs & the upcoming MB64E built into my M-Audio Keystation 8)) and second, what is much more important, there is no space for a core in the small unit and the cases including panels are handworked out of metal. I definitively don't want to build such a case again. Never ever. No way. :P Thanks in advance
How to connect non-motorized faders to MB LC?
groovereiter replied to groovereiter's topic in MIDIbox HUIs
Thanks for your answer. I'm happy to hear that the AIN can be used, I thought it wasn't supperted by the LC app. Is it possible to get the 9th fader (master) with the AIN? With the motorfaders you only get 8 (if I understood right) -
Hi, I read in the wiki that you can use standard faders instead of motorfaders for the LC application. But how do I connect them? Do I still need the MF Module or is there any way to use my AIN? I just couldn't find this answer (unlike every other I was looking for - great documentation/forum). Finally I'm getting the rest of the needed parts (after 1 1/2 years) and this is the only big thing I need to know to make my box complete. So pleeease help me. Thanks in advance, groovereiter
