Thorsten: I believe I found a "bug" or oversight in SID V2 RC30 involving the saving of ensemble data to the internal EEPROM. Simply, it is not possible to save changes to ensembles to the internal EEPROM when using the "SAV" function. When saving, it only gives one address: "E001". The message, "SAVE ENSEMBLE" appears as if the settings were written. Upon changing ensembles by hitting the "page up" button, the settings are lost. Some background: I have one bankstick, mouser pn# 579-24LC256-I/P. It is ID# 0 and patch saving works fine. In order to troubleshoot the problem, I checked over all my connections (they were correct) and uploaded both the latest MIOS firmware and SID applications using MIOS Studio 7 (beta 5), with the suggested settings (smart mode--MIDI IN and OUT connected). Also, I tried setting "DEFAULT_ENS_BS_CS" to "-1" in the .asm. None of these things solved the problem. On a whim, I decided to fire up the V2 Editor and see if I could write the data that way. Well, I changed some filter settings, saved, and uploaded the ensemble to memory. What do you know? The settings are retained! To me, this means there is probably something at fault with the mechanism that saves the ensemble to the internal memory, within the SID software. What do you think?
