swindus
    70
About swindus
  • Birthday 03/09/1969
  • Gender
    Male
swindus's Achievements
MIDIbox Newbie
  1. Got my displays. Thanks for this bulk order!
  2. Thanks for the info! :)
  3. Hi all, as the topics say I have a problem with saving pattern A1. When I save the pattern A1 of any bankstick it will overwrite all other A1 pattern on all other banksticks. I'm using 3.4e right now but the problem also occurs with 3.4c. Any hint or idea? Thanks.
  4. I don't like this function. I have the same 'problems' like Futureman.
  5. Ich hatte mit MIOSStudio Beta7 ähnliche Probleme beim Upload von Anwendungen. Der Smart Mode hat einfach nicht funktioniert bzw hat die Daten zu schnell geschickt. Probier mal den Manual Mode mit einem großen Delay, bei mir hat es ab ca. 950ms funktioniert. Dauert zwar dann ein wenig, aber zumindest kann man was uploaden. Mit MIOSStudio Beta8 geht bei mir auch der Smart Mode ohne Probleme.
  6. It will be a nice weekend! Thanks a lot!!! :)
  7. http://www.possecrewensemble.com/as606/ :o ;)
  8. Great! If it is possible it would be great to use the group buttons as well or better as alternative to the track buttons. Edit: @TK: No need to list them ..... :)
  9. I noticed this too. I would also like a way to select the B layer button as default when switching to song mode especially when in phrase mode. Any hint where to edit the source code?
  10. Changed the source, compiled and uploaded v3.4 to my sequencer. All things in song/phrase mode are now working as expected. Thanks!
  11. Great! :D
  12. It happens only for G4. No way to select a bank or pattern regardless of using an encoder or the gp buttuns to select a bank or pattern. Sorry, no hint for you. :P ;)
  13. There is still a problem with the bank/pattern selection in song/phrase mode. The value for group 4 jumps always back to bank 1 for me when switching the bank/pattern value or selecting another group. While searching in the source code for the according lines in cs_m_menu.inc I found this: ;; toggle pat/bnk sel CS_M_SONG_GP_Callback_Sel ;; btg CS_STAT, CS_STAT_SONG_EDIT_BNK ;; disable - somehow makes no sense here (UI not consistent - time to ask the community, which approach they would prefer) ;; rgoto CS_M_SONG_GP_Callback_Cont I don't think that this is related to the problem though. Any hint on which line I can try to fix it? I'm a long time pascal and c++ programmer but the assembler stuff is killing me. ;)
  14. No, not really! ;) Thanks!
  15. Is this bug fixed in v3.4?
