Hey guys, first post, woo. Okay, I've done a small amount of electrical work in the past but never anything like a midibox...but I like a challenge :) Im looking around at prices atm to get a rough idea of how much I need to budget to make this... First off, are these pots suitable for use? http://www.futurlec.com.au/Potentiometers/POT10K.jsp they are 10k linear taper, which is the same as the pots on the avishowtech site, just a fair bit cheaper :) Also, am I going to run into any problems using those (knurled shaft) with knobs that have a tightening screw fixation? and, next question :) will these sliding pots be suitable? couldnt see any on the avishowtech site, but I figured as they work in the same way as the rotary pots, 10k would be the right thing to be looking at? http://www.futurlec.com.au/Potentiometers/POT10KBSLIDE.jsp 7.3cm travel should be fairly decent control over im guessing? I mean, hell, the novation I used to use only had something like 4 - 5 cm sliders..... thanks for the help guys :) awesome site this is...cant wait to start mucking around with all this! oh, ALSO, i was wondering is it possible to have the faders hooked up to an on/off switch and led as well to switch them off if you have automation already set up in the sequencer you are using and you dont want them to be functioning? or can you not interupt their signal? not exactly sure how to explain what I mean...but do they consantly need a singal flowing to the CORE module? And, how do you get pots to click at 135 degrees like on mixing desks with EQ pots? I want to run several pots for panning in channel strips, but I'd like to obviously have them click in the centre instead of manually having to ensure each one is exactly centred.... thanks guys
