bleepsnbreaks
    30
About bleepsnbreaks
  • Birthday 01/01/1
  • Gender
    Not Telling
bleepsnbreaks's Achievements
MIDIbox Newbie
  1. Wooohoooo ! They arrived this morning in New Zealand, which means that pretty much everyone else should have thiers by now too considering NZ is the ass end of the world :) I am no long knob less :) Thanks Goblinz ! :D
  2. Hey, this dude is on the North Shore, so that means this collection is no more than a 15 minute drive from where I work.... now just need to work out where and grab the crowbar from my car and Im away laughing :)
  3. Hiya Goblinz, Was wondering if you had sent out all the Knobs yet? Havent recieved mine but dont want to start panicing if you have just been busy and they havent gone out yet. -Thanks! -Dave.
  4. SKHHDTA010 switch, ALPS, tact, 6mm sq, 13mm high 1,000,000 cycles @ $0.662ea. Hi-Q Electronics Ltd 6C Douglas Alexander Parade Albany Auckland New Zealand Ph 0800-800-293 Int'l +64-9-415-3333 Fax +64-9-415-8686 www.hiq.co.nz
  5. WOOOHOOOOOOO ! I contacted Switches Plus and they forwarded me to thier NZ distributor ! ! ! SKHHDTA010 switch, ALPS, tact, 6mm sq, 13mm high 1,000,000 cycles @ $0.662ea. Hi-Q Electronics Ltd 6C Douglas Alexander Parade Albany Auckland New Zealand Ph 0800-800-293 Int'l +64-9-415-3333 Fax +64-9-415-8686 Just saved myself and absolute fortune! Thanks Wilba !
  6. Yeah, I know you dont NEED spacers but I was thinking about using them anyway. Yep, rotary encoders are another part that is a pain in the a$$ to get, I had to get mine from voti. I dont understand why shipping stuff from the US costs so much more than from the UK, I got my SIDs from the UK and the shipping was 3 pounds 50...... Anyway, I'll check out switches plus, thanks Wilba....
  7. Of the type used on the MB-6582? Shipping from Mouser to NZ is $30nz, which is more than the buttons. Buttons are the only part I am missing to build my CS. After a few hours soldering Im about 3/4 of the way finished with my baseboard and know I'll be itching to get the CS done as soon as Im finished that :) Also, if I wanted to use spacers for my LEDs what length do I need?
  8. If you ever do another run of the panels and PCBs than I would like to grab a set.....
  9. How much are you thinking the PCBs will end up costing on this? I would probably be keen for one aswell as this is pretty much exactly the control device Id like to build....
  10. Thanks dude !
  11. Hey Goblinz, Did you get my PM about the change of address for my order? My GF has changed jobs and the delivery address was her work address. Cheers
  12. The fakes Ive seen had quite bright white lettering, looking "too new".
  13. The new LCD has arrived already ! THey sent it FedEx international prioroity at thier own expense, wow! Thats like $35us just for the shipping. Great service!
  14. I did the exact same thing when I built mine at first. Its because if you go from the image on the contruction guide the dots that indicate where those pins are is in the wrong place, when I counted out the pins I found the right ones and 5v popped on screen.
  15. Hey guys, Just wanted to let you guys know about the experience I had purchasing 3 LCDs from Crystalfontz USA's website. I bought 2 different 4x20s and a 2x20 but when my order arrived there was the 4x20 model of the 2x20 I had ordered. I figured that becuase I had ordered from New Zealand and the shipping cost nearly as much as the 3 LCDs that it wasnt worth trying to sort out the mistake, all the documentation had the order correctly but they just packed the wrong part. This was going to be slightly annoying because it meant I couldnt use the template for the simple control surface without some modification. Anyway, so I wired up the 4x20 but got only backlight, this lead me to believe that I had accidentaly ordered negative contrast LCDs, so I wired up the other 2 4x20s and they worked fine, when I connected up the origional one again I got just the black bars. Took some photos of the 3 lcds, emailed them to crystalfontz and they logged support ticket for me. Got a response the next day advising that they were very very sorry for the mix up and that they would send me out the correct LCD at thier expense! Thats excellent customer service, in my experience when a company is on the other side of the world and you have this kind of problem you are screwed really because you either have to ship back the broken/wrong item which ends up costing more than the cost of the item, they basicly never respond to your communications, or worse, they blatantly tell you to get bent. So even though they did make a mistake in packing my order they were very quick to fix thier mistake and to stand by the quality of thier products by replacing the faulty unit, no questions asked.
