rvlt
    164
    3
Everything posted by rvlt
  1. rvlt
    MB Mellotron 2
    From the album: rvlt's MB stuff
  2. rvlt
    MB Mellotron 1
  3. That works! I was almost there (run a script with a button), but was using trigger instead of send... Thanks!! btw, will timed events be supported sometime in the future? Not that it's super important, just curious... Lars
  4. Hello, I’m thinking about a solution for the following scenario: I have an encoder with an integrated switch. With this encoder I want to send program change commands, but in the following way: - when I move the encoder I scroll through a list of programs (via NGL-file) which are displayed on a LCD, but the encoder actually DOES NOT send the prog-change command yet - when I found the right program in the list I press the switch and the prog-change command gets send out Is that possible with MB NG? I’ve read through the manual but couldn’t find a proper solution yet, but maybe I’m just too dumb… Icing on the cake would be if I scroll through the list but don’t press the switch, the value on the display jumps back to the current value after a few seconds. Cheers Lars
  5. Ah, ok, I see. Not a problem, a have a few 74HC165 in the drawer anyway.. Cheers Lars
  6. Just wanna confirm that these 3M sockets work really well... Thanks again sneak-thief
  7. Hi, is it possible to connect encoders directly to a STM32F4-CORE board running MB-NG without the need for an additional DINX? I know the SCS uses port J10A, so it would be nice if we could either re-configure that port for "normal" encoders/buttons (non-SCS), or if we could use J10B for that purpose. Lars
  8. And what's even more awesome: me and sneakthief just discovered we live in the same street and are almost neighbors since eight years... :D :D
  9. You guys are awesome!!!!!! Thank you! sneakthief, that'll be perfect, I'm in Friedrichshain, too! I'll send you a PM now...
  10. Hey, I got my STM32F4 core pcb from smash and almost finished it except the sd card socket. In are pictures of two different sockets. I think I found the 3M one at mouser (mouser-no. 517-SD-RSMT-2-MQ). - does anyone know what brand the other one is? - does anyone know where to get either one of those in germany (or europe) apart from mouser? their shipping cost is 20 euros… - can I still connect a sd card socket via J16 if I don’t use the „internal“ one? Cheers Lars
  11. Works perfectly on my side here. Thanks Norbim!!!!!!
  12. Thanks Thorsten. I connected my TDA1543 board (built one according to mbhp_i2s_tda1543.pdf) like this: STM32DISCOVERY -> TDA1543 PA4 (LRCK) -> Pin#2 (WS) PB9 (SDA) -> Pin#3 (DAT) PC10 (SCLK) -> Pin#1 (SCK) ...and 5V, GND and audio outputs of course. but I couldn't get any sound out of it. Don't know if this is supposed to work like that. I mean connecting a second DAC in parallel..
  13. Thanks for your feedback, guys! Yep, a mellotron sample ;) You're right, it is definitely a usable signal, for sure (though I have to say when you play/change chords it's much more obvious than in my example). I just wanted to make sure that there's nothing wrong with my setup, and I still wonder why it's only in the release phase while the rest of the sample plays back fine.. It's just a wild guess but maybe we hear some kind of bit-crushing when the sample fades out (saying: volume gets turned down digitally and the bit-resolution gets lower). I remember the audio-output from my macbook makes all kinds of weird noises when set to a low volume. However I know It's not high-end DAC but I find it quite ok, and it comes for free with the STM32, so I won't complain :shifty: BTW does anybody know if we are still able to connect an external DAC to the STM32F4? On the new MBHP_CORE_STM32F4 the pins should be at J10B but I have no idea how to active that.
  14. Here's a small sample I did with two different release times. You can hear the distorted tail of the samples. Anybody else having that problem with the SD Card Player? sdcardsampler_dist.wav
  15. It's working now! But I noticed a strange behavior with the release phase of a sample: I always get a crispy/crackling sound when I release a key, no matter what I set the release parameter to. With no release phase (value 0) I just get a short klick (which I think is normal), but with longer release times (say up to 1000) the whole release phase of a sample is distorted/crackling. When I press a key till the sample ends everything is fine btw. I already tried different samples and different volumes, but the problem remains. I tried a LPC17 core with the sample player app a few months ago, and as far as I can remember there wasn't such a problem, but I'm not 100% sure. Could that be STM32F4-related? I could try my external DAC (TDA1543 based) that I used with the LPC17 if there is a way to connect that to the STM32F4.
  16. Hey, I have a problem getting the Sample Player to work with the new STM32F4. I uploaded the project.hex and connected my sdcard with some samples, and they seem to load fine, BUT I can't hear anything?! When I connect my headphones I can hear a bit of white noise after the application is loaded, so that tells me that the audio out is (somehow?) initialized. My hardware config: - just the STM32F4-Discovery (no MBHP_CORE_STM32F4) with the additional jumper cable for 5V and an sdcard-reader directly connected - I tried two different sdcards, one 4gb with FAT32 (I know I should use FAT16) and one 4GB with 2x2GB FAT16 partitions - I know that these samples worked with a LPC17 based core - I tried uploading MB_NG and it also seems to work fine, also with the sdcard file browser - I connected the Audio-Out to headphones and to a mixer line-input as well, still nothing - according to MIOS Studio terminal output, everything is configured and loads up fine (see screenshots) What I am doing wrong? (If anybody wants to try my sdcard-files, they are here)
