jerd
    11
Everything posted by jerd
  1. Cool, I think i could use 2.
  2. Thanks for this fx, very nice. I have one question, should the robotizer values be saved when the session is saved? I cant seem to save the parameters with the session.
  3. jerd
    metronome page
    There it is, Thanks!
  4. I cant seem to find the metronome page. I can toggle it off/on, but i cant find the page to change the ports/notes. The manual says it's in the main menu...? Thanks! (I'm using version 42)
  5. I wish i read this long ago. I admit my sidbox is fully built with blue leds. I really like it anyway.(shes my baby after all) I suppose i'll go blind soon.(That should have happened long ago, along with growing hair on my palms ;) Maybe i'll have to use polarized sunglasses when operating it, or a welding mask? It looks great in a dark room. I tried sanding them to make them less bright-It worked a bit. I applied glow in the dark paint to one as a test-It looks yellowish green now --mehh--- less bright tho. I may experiment with other paints later.
  6. just missed my sammich from the post office...Nooo!
  7. Got it. It ended up working fine using win7 64. Of all the ways i tried and retried it i dont know how,,, MiosStudio2.1 with port 1 in and port 2 out somehow worked. Pilot error i'm sure. Thanks everyone for your input. I think it originally flashed bad because it did so while in the looped mode. *It's reassuring to know i haven't been able to screw it up yet, this sidbox wont give up!
  8. I still couldn't figure it out with WinXP. I could only see the Bootloader status if it was in that looped mode. Otherwise, it wasn't seen. Whenever i would try to upload a file it gives me the same midi error again. I've tried a few different usb midi interfaces with no luck. Any other ideas, I must be forgetting something?
  9. Thanks for the quick replies. Im using a tascam 1884 and win7 64bit. I think i originally used XP to install the hex. I will see if i can try again on XP.
  10. I decided to update my sidbox to the latest r37 version. I used Mios studio 2.1 to upload the hex file. Everything seemed ok when it flashed, but froze up "rebooting" on the lcd. When Mios2.1 finished, it said there were 20ish errors, but it said it was "ok". When i rebooted the sidbox it first read - Mios v1.9g - as usual, next it freezes on the screen that reads ...firmware version(34) with "Loading CS". When i set my midi ports the same (port 1 in and port 1 out) mios will show "Core Family: PIC18F ......Bootloader is up & running!" But the strange thing is the midi in port shoots out a continuous string of data. When i try to upload hex, it will give me the error "Midi in overun" *Edited to make more sense
  11. Thanks! Finally figured it out, Dos Equis time!
  12. Wilba, could i have a schematic for the matrix wiring too? Thanks.
