ssp
Programmer
    660
    4
Everything posted by ssp
  1. ssp
    multiple Clcd's
    I have been working on my layout for my 3 digit 7 segment displays i have ordered. The values shown by my plugin are not the usual 0-127, what i need are. if you move the pot all the way to the left its max value is -99 if you move the pot to the far right max value is 99 with the centre value being 0, or in this case just the centre line of the mide segment digit 2 this picture hopefully explains it better. I am trying to get to grips with the matrix information, i understand the connection pdf on the dout boards as i have used them before. I am also stuck on this section here: DOUT_MATRIX n=1 rows=8 sr_dout_r1=1 inverted_row=0 mirrored_row=0 sr_dout_sel1=2 inverted_sel=0 DOUT_MATRIX n=2 rows=8 sr_dout_r1=3 inverted_row=0 mirrored_row=0 sr_dout_sel1=4 inverted_sel=0 dout_matrix n=1 (this is the first matrix/sr) rows=8 (are the first 8 pins?), sr_dout_r1=1 (this is shift register 1) the common cathode is on the next section so this is shown is sr_dout_sel1=2 if i am correct. i dont understand the syntax in this though, can someone explain it for me and i can then carry on writing the rest of the code thanks
  2. ssp
    multiple Clcd's
    ok so the first section is as follows: RESET_HW LCD "%CLED Digit Demo" # HW definitions for "Common Cathode" Digits # see also http://www.ucapps.de/midibox_ng/mbng_led_digits_5x7bit.pdf as a reference (I am working on this section) DOUT_MATRIX n=1 rows=8 sr_dout_r1=1 inverted_row=0 mirrored_row=0 sr_dout_sel1=2 inverted_sel=0 DOUT_MATRIX n=2 rows=8 sr_dout_r1=3 inverted_row=0 mirrored_row=0 sr_dout_sel1=4 inverted_sel=0 # for "Common Anode" set inverted_row=1 and inverted_sel=1 # if the segment connections are mirrored, set mirrored_row=1 # the digits are accessible with: Dout 1 # first matrix: LED_MATRIX:1 ... LED_MATRIX:8 # second matrix: LED_MATRIX:17 .. LED_MATRIX:24 Dout 2 # third matrix: LED_MATRIX:25 ..LED_MATRIX:32 # forth matrix: LED_MATRIX:41 ..LED_MATRIX:49 Dout 3 # fifth matrix: LED_MATRIX:58 ..LED_MATRIX:65 # sixth matrix: LED_MATRIX:74 ..LED_MATRIX:81 Dout 4 # seventh matrix LED_MATRIX:90 ..LED_MATRIX:97 # eighth matrix LED_MATRIX:106 ..LED_MATRIX113 Hopefully I got that right as I would be using 4 Dout modules, I can carry on designing a set of pcbs in altium next week and get them made to mount the 7 seg lcds and the potentiometers
  3. ssp
    multiple Clcd's
    bloomin eck... i am even understanding the code in the link: midibox_ng_v1/cfg/tests/leddig1.ngc I am going to write a version of that later and post it up, I am not expecting it to be perfect and it may need correcting i dare say but if I am in the right direction it is a start.
  4. ssp
    multiple Clcd's
    ok question one, im pretty sure i know the answer but here goes.. Q~ the pdf shows 5 x 3 digit displays, for 16 i would only need 4 per dout matrix, so I would link 4 douts with 4 x 3 digit displays to the core/ng and amend the code to reflect this? also mapping an encoder or pot to each display and its value of 0-127 in the code also its event type and id etc?
  5. ssp
    multiple Clcd's
    Aha!! did not know about that.. I am going to have a read up on this, most likely will ask a few questions along the way, but this is the direction i want to go with this one controller. many thanks as always!
  6. ssp
    multiple Clcd's
    this is my initial enquiry to use sixteen 3 digit seven segment displays how would i implement this in the code, or is it even possible, with each one displaying the value for its encoder? I am reading the files, but see nothing that relates to this yet. would really like to learn this for future projects as well.
  7. ssp
    multiple Clcd's
    I read in the lcd hardware section about putting multiple clcds onto the Ng is possible in this link : http://www.ucapps.de/mbhp/mbhp_lcd_6x2x20_mios32.pdf Question: Is it possible to attach 16 X 1 line 3 digit clcd's to the NG and have each one, via code linked to either a rotary pot or encoder in its value state? (would rather go this route) i understand an easier option is to either use oled displays or a single 2x40 with padded values spaced equally however, thi cldcd route is something i really want to try out I want to build a vintage plugin controller and it has 16 3 digit clcds in its on screen display. The other reason for the clcds is that i want the old red segments. the other option i thought of was using one 2x40 clcds and padding them out so there are 4 sets of values per line but each value is padded equally and shows the 0-127 value above each pot/encoder now I understand the use of the padding for a name and the id-value, I just need a poke in the right direction as to which is the better option.
  8. Thorsten i am reading Johns "Known Issues" section on the custom fonts/ Bars section. Any thoughts on this issues he had? see if this is solveable? I can add this to my wiki documentation and reference johns when I am ready. http://www.midibox.org/dokuwiki/doku.php?id=how_to_create_custom_glcd_fonts_icons_bars_for_midibox_ng#known_issues Thanks PS: Happy New year!!
  9. Had a good evening working on this, everything i have run through on first steps has worked. I have a din and dout hooked up led's are lighting up as they should with the set button presses etc. The Oled display is working as it should off to have a read now and figure a few things out. I really like John Finsters mackie setup here:http://www.midibox.org/dokuwiki/doku.php?id=john_e._finster#midibox_ng_mackie_control_clone_-_august_2013 and the custom fonts info here: http://www.midibox.org/dokuwiki/doku.php?id=john_e._finster#how_to_create_custom_glcd_fonts_icons_bars_for_midibox_ng the section on the bars Panorama and Volume, i was hoping to pick johns brains a bit on this, but hes not been back in for a little while. I am reading his wiki page and the info and will have to try it out once i am more familiar with the code and its implementation in applying custom fonts. I also like the use of the mute/solo/record and monitor icons he used.
  10. Yes, took a while but I am making sure that I am grounded in the basics. Looks like I need more practice. I am writing everything down as I go in my notebook. I finally got myself a breadboard today, first one I have ever owned!!! Go figure.
  11. So.... after some food and a break I sorted it. The board was wiped and re programmed. It took then, wierd as It says on the one web page to get into bootloader press the blue button and hold then short press the black on the discovery board, however it wouldn't take that way. However tonight I get to try out some of the code I wrote on the display, really pleased.
  12. Hey Bruno, its ok I have been having a total brain fart again and not checking my notes. I needed to start it up in mios32 bootloader. I have it up now in mios studio as MIOS32 Bootloader in and out. I forgot to hold the blue button down and tap the black to restart in bootloader mode on the discovery board. all sorted now, thanks
  13. having an issue with the bootloader update this morning, it wont accept the set lcd type command --> set lcd_type GLCD_SSD1306 my mb_ng info Operating System: MIOS32 Board: MBHP_CORE_STM32F4 Core Family: STM32F4xx Chip ID: 0x10076413 Serial: #57003D001050484E52353320 Flash Memory Size: 1048576 bytes RAM Size: 196608 bytes MIDIbox NG V1.036 (C) 2018 T.Klose this is what i get back: [ 476.439] set lcd_type clcd [ 477.522] Unknown set parameter: 'lcd_type'! if i try the clcd line it also fails, was ok the other day. if i type "help" in the linie this is the command list, there is no option of set lcd_type [1902.530] Welcome to MIDIbox NG V1.036! [1902.531] Following commands are available: [1902.531] system: print system info [1902.531] memory: print memory allocation info [1902.532] sdcard: print SD Card info [1902.532] sdcard_format: formats the SD Card (you will be asked for confirmation) [1902.532] network: print network info [1902.532] set dhcp <on|off>: enables/disables DHCP [1902.532] set ip <address>: changes IP address [1902.532] set netmask <mask>: changes netmask [1902.532] set gateway <address>: changes gateway address [1902.532] set osc_remote <con> <address>: changes OSC Remote Address [1902.532] set osc_remote_port <con> <port>: changes OSC Remote Port (1024..65535) [1902.532] set osc_local_port <con> <port>: changes OSC Local Port (1024..65535) [1902.532] set osc_mode <con> <mode>: changes OSC Transfer Mode (0..4) [1902.533] set udpmon <0..4>: enables UDP monitor (verbose level: 0) [1902.533] keyboard <1|2> (or kb <1|2>): print current configuration of given keyboard number [1902.533] set kb <1|2> debug <on|off>: enables/disables debug mode (not stored in EEPROM) [1902.533] set kb <1|2> note_offset <0-127>: selects the note offset (transpose) [1902.534] set kb <1|2> rows <0-16>: how many rows should be scanned? (0=off) [1902.534] set kb <1|2> velocity <on|off>: keyboard supports break and make contacts [1902.534] set kb <1|2> release_velocity <on|off>: keyboard supports NoteOff velocity [1902.534] set kb <1|2> optimized <on|off>: make contacts only scanned if break contacts activated [1902.534] set kb <1|2> dout_sr1 <0-32>: selects first DOUT shift register (0=off) [1902.534] set kb <1|2> dout_sr2 <0-32>: selects second DOUT shift register (0=off) [1902.534] set kb <1|2> din_sr1 <0-32>: selects first DIN shift register (0=off) [1902.534] set kb <1|2> din_sr2 <0-32>: selects second DIN shift register (0=off) [1902.534] set kb <1|2> din_key_offset <0-127>: selects the key offset between DIN1 and DIN2 [1902.535] set kb <1|2> din_inverted <on|off>: DINs inverted? [1902.535] set kb <1|2> break_inverted <on|off>: Only break contacts inverted? [1902.535] set kb <1|2> make_debounced <on|off>: Make contacts will be debounced [1902.536] set kb <1|2> break_is_make <on|off>: Break contact will act like Make and trigger a note [1902.536] set kb <1|2> delay_fastest <0-65535>: fastest delay for velocity calculation [1902.536] set kb <1|2> delay_fastest_black_keys <0-65535>: optional fastest delay for black keys [1902.536] set kb <1|2> delay_fastest_release <0-65535>: opt. fastest release delay for velocity calculation [1902.536] set kb <1|2> delay_fastest_release_black_keys <0-65535>: opt.fastest release delay for black keys [1902.537] set kb <1|2> delay_slowest <0-65535>: slowest delay for velocity calculation [1902.537] set kb <1|2> delay_slowest_release <0-65535>: slowest release delay for velocity calculation [1902.537] set kb <1|2> key_calibration <on|off> enables/disables key calibration [1902.537] set kb <1|2> key_calibration clean clears calibration data [1902.537] set kb <1|2> key_calibration_value <key> <delay> directly sets delay value [1902.537] set midimon <on|off>: enables/disables the MIDI monitor [1902.537] set midimon_filter <on|off>: enables/disables MIDI monitor filters [1902.537] set midimon_tempo <on|off>: enables/disables the tempo display [1902.537] router: print MIDI router info [1902.537] set router <node> <in-port> <off|channel|all> <out-port> <off|channel|all>: change router setting [1902.537] set mclk_in <in-port> <on|off>: change MIDI IN Clock setting [1902.537] set mclk_out <out-port> <on|off>: change MIDI OUT Clock setting [1902.537] testaoutpin: type this command to get further informations about this testmode. [1902.538] caliaout: type this command to get further informations about this testmode. [1902.538] testlcdpin: type this command to get further informations about this testmode. [1902.538] set dout <pin> <0|1>: directly sets DOUT (all or 0..255) to given level (1 or 0) [1902.539] show douts: prints the current DOUT patterns [1902.539] set debug <on|off>: enables debug messages (current: on) [1902.539] set autoload <on|off>: enables autoload after filebrowser upload (current: on) [1902.539] save <name>: stores current config on SD Card [1902.539] load <name>: restores config from SD Card [1902.539] show file: shows the current configuration file [1902.539] show pool: shows the items of the event pool [1902.539] show poolbin: shows the event pool in binary format [1902.540] show id <element>:<id> shows informations about the given element id (e.g. BUTTON:1) [1902.540] show hw_id <element>:<hw_id> shows informations about the given element hw_id (e.g. BUTTON:1) [1902.540] show ngr_tokens: shows .NGR token information [1902.540] lcd <string>: directly prints a string on LCD (can be formatted!) [1902.540] run [<section>] [<value>]: executes the .NGR script with the optional section and value [1902.540] ngr_value: value used for 'run' (without parameter) and 'ngr' (is: 0) [1902.540] ngr_section: section used for 'run' (without parameter) and 'ngr' (is: 0) [1902.540] ngr <command>: directly executes a NGR command [1902.540] ngc <command>: directly executes a NGC command [1902.540] msd <on|off>: enables Mass Storage Device driver [1902.541] reset: resets the MIDIbox (!) [1902.541] help: this page [1902.542] exit: (telnet only) exits the terminal
  14. lol again.. it was late and I was tired.. thats my excuse and i am sticking to it!! now its correct
  15. got you, as such. will do later tomorrow, need zzz now, thanks again andy.
  16. i noticed on the link here: http://www.ucapps.de/mbhp/mbhp_lcd_ssd1306_single_mios32.pdf that there is a 1k resistor going from the 3.3v feed to reset and also a 10uF cap going from gnd to reset. will i need to apply this to my oleds as well? mine are 7 pin: 1 gnd, 2 vdd, 3 sck, 4 sda, 5 res, 6 dc, 7 cs
  17. well I have been playing around with the various commands and i seem to be getting to grips with this really quickly. I am going to attach one of my oleds tomorrow and try some of the code i wrote, have tried some tonight and its all worked fine. hooked up a din etc and all is good there, moved syntax around etc and that was all good, this .ngc code is quite logical in how it works. I did try the copy pase command sequence in mios, didnt like it!! so its one at a time. thanks all have a great xmas, catch you onthe flip side.
  18. pleased to report that all is working, one question, rather than input one line at a time eg: set lcd_type clcd then set lcd_num x 1 etc can you just input it all in one go? via copy paste into the mios text input bar? thanks
  19. oh boy... helps if i stuff the two IC's in the sockets as well..... oh dear.. LOL!!!!! welcome to dumbass 101 Thanks andy, have a great xmas, I am off to play with some code now!! catch you all in the new year
  20. ok i have that sent now [11445.498] set lcd_type clcd [11446.590] LCD type set to 0x00 (CLCD) after 'store'! [11462.502] set lcd_num_x 1 [11463.594] LCD num_x set to 1 after 'store'! [11472.272] set lcd_num_y 1 [11473.364] LCD num_y set to 1 after 'store'! [11480.739] set lcd_width 40 [11481.830] LCD width set to 40 after 'store'! [11490.256] set lcd_height 2 [11491.348] LCD height set to 2 after 'store'! [11492.037] store [11493.571] Failed to store new settings - retry #1 [11493.571] New settings stored. [11493.571] Initialize LCD #1
  21. i had the bootloader in etc already so for the fact im seem to have total loss of brain power where do i enter the lcd type etc? mios gives me this Operating System: MIOS32 Board: MBHP_CORE_STM32F4 Core Family: STM32F4xx Chip ID: 0x10076413 Serial: #57003D001050484E52353320 Flash Memory Size: 1048576 bytes RAM Size: 196608 bytes Bootloader 1.018 (C) 2014 T.Klose so its good how where to enter the lcd info? Thanks, and merry xmas to you too!!
  22. right my Board: MBHP_CORE_STM32F4 is working and mios sees it. I have hooked an lcd up to it but im getting no response on the lcd, its lit up and i have trimmed the pots for contrast and backlight. The connection is one to one as per the info I have just checked the data sheet on the lcd (2x40) and it is fine, the ribbon cable is also tested and fine. I just checked the new lcd on a core and thats fine, but all i am getting are lit squares, so I am assuming it is because i have not defined the LCD as below the information says that i need to tell it what lcd it is in the bootloader as per this section. These parameters can be customized from the MIOS Terminal (part of MIOS Studio) by uploading the mios32_bootloader update application What bootloader update application???? i find this example: Example2: two HD44780 based 2x40 character LCDs are connected to your MIDIbox Enter: lcd_type CLCD lcd_num_x 2 lcd_num_y 1 lcd_width 40 lcd_height 2 store So as I am using a single 2x40 i would apply this: Example2: two HD44780 based 2x40 character LCDs are connected to your MIDIbox Enter: lcd_type CLCD lcd_num_x 1 lcd_num_y 1 lcd_width 40 lcd_height 2 store Where and how would I apply this?? the information is really sketchy and I plan on updating things as i go, right now I am MB_NG newbie 101 Thanks
  23. lets put this in anyway as it will be good to learn how to implement this and I would like to see this function in the code. The only way to learn is to do and I really want to get into the ngc code over the winter here. As I get to grips I will share on this thread. Thanks Thorsten
  24. One alternative, Will the mackie control, logic control be ported to use on the stm32f4? My daw supports this so I could go that way instead if needed.
  25. I am just looking at whatever is the most time efficient solution for you if the software needs changing. the ability to have this sysex: F0 00 01 06 16 12 00 00 00 73 74 72 69 6E 67 73 F7 this hex is an example ascii for the track name "strings": 73 74 72 69 6E 67 73 show on the oled is all i am looking for. in an old thread someone asked you about sysex being used for a track name : If there is a solution to the track name then I can work out how to do the level, pan etc in my own time as it is a starting point for me. Many thanks
