WingMa
    61
Everything posted by WingMa
  1. Hello, Can I use this two pot with your panel, and I have two panel on one I need to use all two together https://www.conrad.com/ce/en/product/442094/Motorised-fader-----5-k---------02-W-----linear-----ALPS/?ref=home&rt=home&rb=1 https://www.conrad.com/ce/en/product/442081/Motorised-fader-----10-k---------05-W-----linear-----ALPS/?ref=home&rt=home&rb=1 I need a correct answer because I would like to buy the pots Thanks and Regards: Bela
  2. Thank you Thorsten, now I'm going to smashTV :D
  3. Hello Tk, First of all, happy new year for all ;-) I intresting about your motorfader modul but I would like to use with ALPS 60mm long fader: http://www.conrad.com/ce/en/product/442094/ALPS-401626-Motor-Fader?ref=list It is possible? Thank you Regards: Bela Hungary
  4. Thank you Lorcan again! I think I connrct any ground point into the core after the Capacitor 2200 uF instead of the DIN and DOUT J1 ground point (I think these are the same). It's right???
  5. Thank you Lorcan I thought that too! Some quick Questions again: -Can I connect the ground of buttons and leds directly to the power supply? I will the every take the ready made panel's to a factory but I would like to have simle sided panel's done! -Which Elemnt's should be clerad from the original plan's? I think The Layer Nr1.: Top And what Else???
  6. Hy! The based on the descrition this 10k too. Part number RS60N11M9A05 Number of resistor elements Single-unit Direction of lever Vertical Travel 60mm Type Motor N fader Lever types 9-T (T-Bar) Length of lever 8.2mm Total resistance 10k? Resistance taper 1B Terminal style Lead Touch sense track With Theoretically can it be a problem?
  7. Anybody about the motorfader???
  8. Thank you for your answer! You have misunderstood me. I don't need it for Monday I want to START it on monday. I know that this program know a lot and many pepole worked on it. And I respect it. But I can't take a part in it. I have a Professional Light Control software and it has MIDI Control Interface. I need for that an individual Midi Controller, to work on my profession like you on yours. Hopefully I don't hurt any kind of "midibox rule" with this. Such easy answers are enough for building my hardwer: There are good tutorials on ucapps.de page, but you are the only who know such little experiences.
  9. Thank you kris, but unfortunateli it doesn't help for me :( I read through more than a thousend posts but I couldn't find the concret answer. I want to start it monday and I don't think that 10 hours would be enought to read the rest forty-thousand posts... Unfortunately I can read all the information but I won't be a proffessional electrotechnican so I need some concret help. Regard Bela
  10. Hy! I think it is not as easy to find the appropriate person, so I start to build it. But I need some information: -Which Core (Pic based or STM32) should be used for folowing funkcions: Mergering and link to use only one lcd??? -Can use 60mm MotorFader instead of 100mm??? I must know this before I buy the parts. Thanks!!
  11. Dear Programers, I have spent so many days surfing on the internet, searching for midi controller, but unfortunately I keep finding problems. One of my idea I buy two Behringer Bcf2000 and another control for buttons, and cut off the panels. This would be the best for me, but it is to problematik. I was glad I found this website but unfortunately I cannot find apropriate tool within the ready-made projects. So I would like to ask for some help if it is possible. I can do all the hardwares, but I am not as good in programing. If it is possible somebody please help me consturating in the following configuration: 13 motorfader 20 Encoder min 90 Pushbutton min 12 Led Rings min 64 Button's Led I thought that two Midibox Lc-s would be built and I would add plus two more encoders. (as it can be seen in the picture) Thoose parts are not used (MotorFaders, Buttons) should be switched off from the menu, and I would not conected. But later on I may use it. (see in the attachment) The extra encoders don't really need special function, if it is hard to make.It does not need to appear on LCD, and I do not need Led ring. The only thing I need is to calibrate the midi values. (Min/max) I would like to change the faders lenght. I found on the page pf ALPS 60 mm pots, I would like to involve them. Does it requires and change? http://www.alps.com/WebObjects/catalog.woa/E/HTML/Potentiometer/Audio/RSN1M/RS60N11M9A05.html Other Change on Lcd. Honestly I dont realy need the lcd's respons or just one on what the most required information appears like Behringer BCF2000. A read about the link function. That would be the best for me in the easiest lcd. http://www.ucapps.de/midibox_link/tunnel4.gif I need a person how can help me finishing a projekt from the begining till the end. I can do everything if therse a concret instruction. Please help me. I can offer you something for that. Best regards:
