florian
100 -
Everything posted by florian
Help needed....can i upload with only one midi cable...
florian replied to florian's topic in MIDIbox SID
ok i have found a better psu. when i swith on the smmich it say" tk, mios 1,99, and after, ready. Problem: i have only one midi cable... Can i upload the sammixh firmwire with only one midi cable???? thanks! hope yes! -
i just test this "12V" PSU : it in fact a 19 volt psu.......... can i run the sammich on it in order to try it or not recommended??? other thing wilba send me a red on black screen, it it high or low consumption??? thanks! -
ok...finally all is soldered.....My antex c15 died, it run when it want, so i finish all the build except the leds with a big 45w iron.... .. I am now at the voltage test step on the base pcb.... ALL 5v, -5v, 9v are fine... But the 12c orange point are at 16, 6 v...... I have read on the build guide that it may change with the psu, but i think it's a bit too many no???? i am using my echo soundcard psu this a photo...in the wrong way sorry i have not the toolo now to do a mirror.... it's not normal i think??? -
pfuuuu thanks!!! i just have great difficulties to solder the rectifier lead: the semms to be in an other metal of other component, and my solder don't fix on it...strange -
on another post i see wilba said "It's probably nothing to worry about. 5K is not a short. 5 Ohms is a short. " so that's the case here??? in my mind any power must be between 5v and gnd, but i am a real noob to electronic so.... thanks! -
looking more and more at the soldering i can't see anything wrong.... shit -
hello at all... i am building my sammich kit. I am following the build guide, and i am at the step before the regulator on the baseboard. in the manual it is say to check short betwenn gnd and 5v at this moment so i do. when my multimeter is set on 200 ohm: no short 2000 ohm: no short 20K : Short: 8,86K 200K short:8?86k ..... so i think i can stop my build.... not normal exact??? shit.....
ok thanks! did you need 2 midi cables to upload the firmwire or only one is good? if only one needed, i wiil start building it in the next minutes!!!
Hello at all. I just receive my sammichSID kit. I want specials leds on it, that i don't have now. If i build the sammich without them, will it run?? and, how can i check the screen color before solder it??? thanks!!!! Bye!
pm re-sent! :ahappy:
thanks for your answer!
ok pm sent!
ok i will pass my turn sorry! pretty sure it will be easy to sell ! thanks and sorry!
hello can anyone provide me the svg files for the case??? many thanks...by the way if you do an clear transparent acrylic case, can you put screen and lcds under the case, without doing holes for them??? have you enough space???? thanks! problem ended thanks....
hello i am very interested... what are the color of the case, screen ands leds??? thanks!flo
hello! iam am no more interested in your kit, due to financial and time cause, i more learning toward a sammich.... So please, please, can you sell me two of your 6582 sid chip???? it would be wonderful for me as i need two for the sammich, thanks flo (france)
hello at all... I hope one day have a sammichSID kit.... I dream it arctic ice with blue screen and blue leds. Many people told me that using blue leds is not good because it damage eyes, they are too powerful.... So could you advice me on good blue less for the sammich, witch provide a comfortable use, and a screen white on blue compatible with the sammich, or should i just stick with the red ones provided with the kits???? thanks!
I dream and hope..
Put me in the third position if yovr sell didn't succeed with the previous people flo france..
check your mail!
and yes: what are the sids in it??? thanks (some photos???)
hi i am possibly in for it!!! Is the sammich completely fonctionnal???? what are the clor of leds ands lcd??? i write you a mail too. i am in france thanks!!!
read most of the manual, i would stick for the samuch for instant, mainly for financial and time reasons, and to not go in the hell of sourcing thanks!!!
thanks! i just download the manual, will read it before all in order to try to understand how these box are editable, and which is the better for my setup....want the control from one side, the cheap thing on the other.... first rtfm, and see what would be my choice!!! thanks, i surely come here in one or two day after reading it! bye
