Hi!
I was just wondering when I got up today: Isn't there a shift register like the 74HC165 available that has internal pull-up registers? Would make my life much easier right now.
ALEXander.
  • 3 weeks later...
Rednas: You don't - use SIL resistor packs like smashtv supplies
Both: Built-in resistors would be impractical because the value of the resistors would vary from one design to the next. IE, what works for midibox, might not work for behringer....So, they're not built that way.
Ok, so to narrow down my question: If I have a design which requires the standard 10k Pull-Up resistors that are used in the standard DIN design, is there a shift register with integrated pull-up registors that I could use?
Best, ALEXander.
