nILS Posted February 20, 2008 Posted February 20, 2008 I'm trying to add a page to the men structure. That page is supposed to have 5 entries. Filter Cutoff, Filter Resonance, NOP, LFO Rate, LFO Depth. Therefore I created this table:; ==========================================================================; The combined FIL/LFO menu; ==========================================================================CS_MENU_TABLE_L_FL db (CS_MENU_TABLE_L_FL_End-CS_MENU_TABLE_L_FL)/CS_MENU_ENTRY_LEN, 0x00 ;; Register (00=dummy) |<->| max print ix exec ix parameter transfer CS_MENU_ENTRY SID_Ix_L_Fx_CUTOFF_L, "Cut", 0xfff, PRINT_Fx_CUTOFF, EXEC_SELPAR, R2PP2R_Fx_CUTOFF CS_MENU_ENTRY SID_Ix_L_Fx_RESONANCE, "Res", 0x0ff, PRINT_Fx_RESON, EXEC_SELPAR, R2PP2R_Fx_RESON CS_MENU_ENTRY 0x00, " | ", 0x000, PRINT_NOP, EXEC_NOP, R2PP2R_NOP CS_MENU_ENTRY SID_Ix_LFOx_RATE, "Rte", 0x0ff, PRINT_LFOx_RATE, EXEC_SELPAR, R2PP2R_NOP CS_MENU_ENTRY SID_Ix_LFOx_DEPTH, "Dep", 0x0ff, PRINT_LFOx_PMDEC8,EXEC_SELPAR, R2PP2R_LFOxCS_MENU_TABLE_L_FL_End[/code] Added the entry to the CS_MENU_TABLES_L: [code]CS_MENU_TABLES_L ;; pointer to table par. button pressed exec button pressed page nam var max print function ;; ... CS_MENU_T_ENTRY CS_MENU_TABLE_L_FL, CS_MENU_Page_Parameters, CS_MENU_EXEC_GoToRoot, "F/L", 0, 0x00, PRINT_NOP ;; ... Gave it an ID: CS_MENU_L_FL EQU 0x0f Added it to the ID list: CS_MENU_TABLES_IDS ;; lead bassline drum multi ;; ... db CS_MENU_L_FL, CS_MENU_ROOT, CS_MENU_ROOT, CS_MENU_ROOT[/code]So far so good. It shows up in the main menu. I can't really select it though and it completely screws up all the other menus (menu buttons select the item to their left...).Any ideas?
TK. Posted February 20, 2008 Posted February 20, 2008 It's strange that it shows up in the main menu without an entry in CS_MENU_TABLE_L_ROOT - or did you forget to mention this?Maybe the ID values are not matching with the order in CS_MENU_TABLES_L anymore?Best Regards, Thorsten.
nILS Posted February 20, 2008 Author Posted February 20, 2008 It's strange that it shows up in the main menu without an entry in CS_MENU_TABLE_L_ROOT - or did you forget to mention this?No, it was not in there yet :-\I added it to the list and that fixed the problem. CS_MENU_T_ENTRY CS_MENU_TABLE_L_FL, CS_MENU_Page_Parameters, CS_MENU_EXEC_GoToRoot, "F/L", 0, 0x00, PRINT_NOPThanks, TK!
