So I want to make a thing to stick on top of my head that is covered with LEDs that I can control via MIDI...the obvious choice for this seems to be the MIDIO128.  Do I need any DIN boards or just 1 DOUT board for every 24 LEDs I want on my head?  Can the DOUTs be configured easily so I can turn on the LEDs with note events?  I'd like to sequence the lights with midi note on/offs, it seems like this would be easiest to implement and debug. ;D
yes you can do it with 1 core and 1 dout (up to 32 leds). U can use midio128. midi note on 0 (C-2 i guess) will light on led0, note off will light off, note on 1 (C#-2) light up led1 and so on ....
the hardest will be to do the helmet.
have fun Daft Punk !
if you use MIOS.. there is a simple example for doing exactly what you want..
Controlling 128 LEDs via MIDI
We want to set/clear LEDs, which are connected to one or more DOUTX4 modules, with Note Events over MIDI Channel #1
Copy the SDCC skeleton into a new directory, open the main.c file and enhance the hooks like described below. Thereafter type "make" in the command shell, and upload the new project.hex file to the core.
Within the Init() function, you have to specify, how many shift registers are connected to the core:
// This function is called by MIOS after startup to initialize the
// application
void Init(void) __wparam
  // set shift register update frequency
  MIOS_SRIO_UpdateFrqSet(1); // ms
  // Up to 4 DOUTX4 modules (=16 shift registers = 128 digital outputs) can be connected
  // set the maximum number here - it doesn't really hurt!
  MIOS_SRIO_NumberSet(16);
//  This function is called by MIOS when a complete MIDI event has been received
void MPROC_NotifyReceivedEvnt(
  unsigned char evnt0, unsigned char evnt1, unsigned char evnt2) __wparam
  // a note event provides 128 different note values (0..127)
  // in this simple example, each note sets an individual pin
  // for DOUT pin numbers, see also this documentation:
  // http://www.ucapps.de/mios/mios_pin_list.txt
  if( evnt0 == 0x80 || evnt0 == 0x90 ) {
    // 90 xx 00 is the same like a note off event!
    // (-> http://www.borg.com/~jglatt/tech/midispec.htm)
    if( evnt0 == 0x80 || evnt2 == 0x00 ) {
      // Note Off
      MIOS_DOUT_PinSet(pin, 0);
    } else {
      // Note On
      MIOS_DOUT_PinSet(pin, 1);
