sineSurfer Posted February 26, 2008 Report Posted February 26, 2008 Hi, just when I thought everything was ok:After building all the cables for my mbSID and plugging everything together turned on the box just to hear a big fast pulse noise, something like a furious bee :) coming out along with the sids regular sounds.After a panic attack :-[ and some tests plugging one cable at a time, found the source of the noise to be the MIDI OUT cable, the noise is only present when the cable is plugged, without the MIDI cable the noise goes away.I disconnected all the CS cables to see if there was the fault, leaving the box basically as the last time I tested it without troubles, nothing wrong it seems.what should I look for to fix this? a broken wire form the core could do this?i'll replace that cable from the core to the DIN tomorrow just in case.thanks!
nILS Posted February 26, 2008 Report Posted February 26, 2008 This effect sounds like wrong wiring to me. A data line on ground might affect the audio out and lead to weird noises. Is the CS working (except for the buttons and encoders not doing what they're supposed to ;))?
TK. Posted February 26, 2008 Report Posted February 26, 2008 It's probably related to the MIDI In port of your MIDI interface (of PC or whatever platform you are using). If the middle pin isn't disconnected at the MIDI In side, there is a potential risk for a ground loop, which can result into a 50 (or 60) Hz buzz.In order to solve this, you could disconnect the ground connection to the middle pin of the MBHP_CORE MIDI OUT port. It doesn't really hurtBest Regards, Thorsten.
sineSurfer Posted February 26, 2008 Author Report Posted February 26, 2008 thanks TK! i'll remove the ground connection, Lucem told me the same on the chat so hopefully that will solve the buzz ;D
sineSurfer Posted February 27, 2008 Author Report Posted February 27, 2008 oh, this is sooo embarrassing but i'll confess anyway, it turns out I was plugging the wrong cable, a midi out from my ms2000 kb instead of the midi in to the midi interface :-[
nILS Posted February 27, 2008 Report Posted February 27, 2008 [ nILS ] 2:31 am: Did you check the cable and if it's connected correctly?hihi :D Glad to hear it's working now!
