Spandex Posted June 27, 2008 Author Posted June 27, 2008 Works fine here, even through work's firewall.... I suspect you're blocking the port on your firewall(s). IIRC it's port 3690, TCP and UDP.Sorry, I've always setup svn over WebDAV/DeltaV before so I don't know much about the svn:// protocol. As far as I can see though, it shouldn't need any special firewall rules. It doesn't do anything crazy like initiate connections back to the originator like FTP does it?Also, if you have authenticated read/write access, you're possibly tunnelling it over SSH anyway?
stryd_one Posted June 27, 2008 Posted June 27, 2008 As far as I can see though, it shouldn't need any special firewall rules.It does need a hole in port 3690 for SVN. It doesn't do anything crazy like initiate connections back to the originator like FTP does it?No, no NATing required.Also, if you have authenticated read/write access, you're possibly tunnelling it over SSH anyway?In which case you need to punch port 22.
Spandex Posted June 27, 2008 Author Posted June 27, 2008 That's not how most firewalls work. OUTBOUND connections are allowed by default anyway. You can't predict the local port so you can't make holes for a particular protocol, nor do you need them. You're talking about INBOUND connections, I believe, or else some other flavour of restrictive firewall that prevents net access to your local users. We don't have anything like that (I know because I'm the network admin here :))See below, I can connect on port 22 (though I have no account) but can't connect via SVN protocol. matt.southall@s15286839:~/tmp$ svn checkout svn://svnmios.midibox.org/mios/playground svn: Can't connect to host 'svnmios.midibox.org': Connection refused matt.southall@s15286839:~/tmp$ telnet svnmios.midibox.org 22 Trying 72.232.76.22... Connected to svnmios.midibox.org. Escape character is '^]'. SSH-1.99-OpenSSH_3.9p1 Protocol mismatch. Connection closed by foreign host. matt.southall@s15286839:~/tmp$ matt.southall@s15286839:~/tmp$ telnet svnmios.midibox.org 3690 Trying 72.232.76.22... telnet: Unable to connect to remote host: Connection refused matt.southall@s15286839:~/tmp$
stryd_one Posted June 27, 2008 Posted June 27, 2008 That's not how most firewalls work. OUTBOUND connections are allowed by defaultActually most firewalls block everything, and mine's one of those. .... Maybe we're used to a different kinda network. A good firewall should block data from escaping your LAN as well as entering it, it's important in case the physical security is breached - bad stuff sometimes comes from inside the building. In fact, a really secure setup will block all traffic even internally, for example to stop a worm from spreading, or to stop users from wasting backplane bandwidth with unwanted traffic.See below, I can connect on port 22 (though I have no account) but can't connect via SVN protocol.Right you are, I'm using SSH... I tried read-only access just now, and it failed in the same manner. Looks like unsecure SVN is down!
Spandex Posted July 18, 2008 Author Posted July 18, 2008 I'm still unable to get in via SVN. Is there somewhere else I can DL this source code? Failing that, is there any chance anyone with SSH+SVN access could zip me up a copy of recent export so that I can start looking at this MAX7221 driver? Please PM me if so. Thanks!
stryd_one Posted July 18, 2008 Posted July 18, 2008 Twin-X / TK can you look at this for spandex? :) (who is very patient!)
Spandex Posted July 18, 2008 Author Posted July 18, 2008 Twin-X / TK can you look at this for spandex? :) (who is very patient!)You're very kind, but really I'm more "busy" than "patient" :)
TK. Posted July 20, 2008 Posted July 20, 2008 I'm sorry, the read-only svn access isn't supported anymore, since it slowed down the server too much.svn access is available again - a special demon has to be started to get it running - this has to be done after each rebootI could give you ssh access to the repository if required.If this is too complicated, just download the latest stribe firmware release package, it contains the driver module as wellBest Regards, Thorsten.
Spandex Posted July 21, 2008 Author Posted July 21, 2008 Ah, thanks. Got it now from the Stribe firmware.
