Update: Checked and working!- Ready made PCB for a 4-Chip Bankstick
I´ve designed this little PCB for a Bankstick of four Atmel EEPROMs "24C256".
I´d like to check this with the people in the forum before I continue. And, if it´s correct, I hope someone finds it useful.
Thanx,
Pablo P
Update: I removed this version because it had some little bugs. See below.
i can send you the design for 8 bankstick if you like. it fits on a very small board and works (i use it in the seq) and can be opened with the free eagle soft.
I thank you, that'd be nice.
Thing is what I found are 24C256 from atmel, which have only two pins for chip select, thus giving a max of 4.
I checked and double-checked the board, and seems to be fine. But since it's the first one I design I wanted to check it out.
The PCB is OK and working. It's useful if you have Atmel's eeproms. They will allow just 4 ICs to be used together. So this PCB is for a bankstick made of four chips. I'm adding a slightly updated design for those who could find it handy. There are two differences:
First one is that it makes clear where the two bridges should be placed.
Second, and maybe more important, there was a confusion regarding the labels of the pins in J1. sc should have been sd and viceversa.
Cya
bankstick4p.rar
bankstick4p.rar
