BankStick copying, cloning and imaging
Guest Macwreck
1. I want to setup BankStick Bank 1 how I like and then 'copy' Bank 1 to Bank 2 to use it as a template to make some alterations to ... then copy Bank 1 to Bank 3 and tweak that etc ... is this possible?
2. If I have a BankStick how can I make a backup of it - a complete clone?
3. When using the BankStick how can I get the button/fader settings etc into the MBox so that when I pull the BankStick out the controller stays with the 'image' of the Bank I was just using?
Pete
Hi Peter,
you could make a backup of the data of a bank by saving the data to sysex file with vsysexbox.
A feature to dowload all banks with one mouseclick is planned but not yet available.
Regards,
Serge
Guest Macwreck
I knew that we could do a SYSEX as a way to solve #2 - but I still need to;
1. 'copy' from Bank to Bank
3. have the 'image' of the bank being used stay with the MBox when I remove the Bankstick
... all while I have it running standalone ....
Pete
Since I also need this possibility sometimes, when I want to duplicate the stored pot setups, it's on the ToDo List now.
