sonofdirt Posted March 25, 2008 Posted March 25, 2008 http://en.wikipedia.org/wiki/Software_Automatic_Mouthpossible to do with MIDIbox SID? :D discuss...
Ashiman Posted March 25, 2008 Posted March 25, 2008 bump, great find ,way too cool to let the topic down ;D
t_xen Posted March 25, 2008 Posted March 25, 2008 There's an insane 248bpm chiptune by Dispyze of "TrebelDeathSystem" that sounds like it could be the S.A.M. used at the beginning.you can find the track here at the bottom of the page on the player....http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=143090168
DragonMaster Posted March 25, 2008 Posted March 25, 2008 Modify a C64 emulator to send MIDI to the MBSID rather than using software emulation?
TK. Posted March 25, 2008 Posted March 25, 2008 http://www.midibox.org/dokuwiki/midibox_speakjetBest Regards, Thorsten.
nebula Posted April 21, 2008 Posted April 21, 2008 I used S.A.M. for a few of my own projects back in the 1980's. I had a lot of fun with it. Usually I'd sample S.A.M. and play the phrases back via MIDI. Back then I also had a 4-track cassette deck and a tape sync box, and I did one track where I wanted a lot of S.A.M. speech (way more than my S-330 could accomodate), so I did drop records to tape live from the C64.I believe SAM worked by toggling the SID output off and on fast enough to produce audio. I don't think it would be possible to emulate S.A.M. or most other real-time SID applications over MIDI, because MIDI is too slow.It might be possible to implement some SAM features right on the PIC. But in some very wise yet unattributed words of wisdom previously stated on this forum, if you're wondering how hard that would be, the answer is most probably "too hard for you".
DragonMaster Posted April 21, 2008 Posted April 21, 2008 I believe SAM worked by toggling the SID output off and on fast enough to produce audio.That's the only known way to use samples on a SID, I even think I read only 6581s can do this.because MIDI is too slow.When's OSC coming to the MIDIbox?
stryd_one Posted April 22, 2008 Posted April 22, 2008 don't think it would be possible to emulate S.A.M. or most other real-time SID applications over MIDI, because MIDI is too slow.What? You don't have to stream the on/off to the sid, you just send the pic a sysex command and it does the rest :)Course.. PIC's don't pack a lot of sample ram. ;) Sure you could look at SRAM but... uhm... speakjet?
