alexglvr Posted April 2, 2008 Posted April 2, 2008 Hello,i am starting a project in which i need 36 pushbutton to command a software by midi.I was thinking using the MIDI io 128 program.Could you please confirm the hardware i need please? :-\- 1 core- 2x DINx4 (64 digitals inputs for 36 used)This midibox will be added in a midi chain. Do i need other things?Thank you for your help,Regars,Alex
nILS Posted April 2, 2008 Posted April 2, 2008 I was thinking using the MIDI io 128 program.Use whichever you please :-)- 1 core- 2x DINx4 (64 digitals inputs for 36 used)Correct. (Although you could just perfboard the second DINx4 as it really only needs to be a DINx1)This midibox will be added in a midi chain. Do i need other things?That's really up to you isn't it? Possibly a MIDI Through? Definitely some buttons and a case ;D
alexglvr Posted April 4, 2008 Author Posted April 4, 2008 Hello,thank you for your answer...A last question please. According to my configuration, i will use 18 Switch on the first Dinx4 and 18 switch on the second DINx4.Is it a problem?Sincerely,Alex
Screaming_Rabbit Posted April 4, 2008 Posted April 4, 2008 No, it's no problem. You can connect your switches on whatever DINput you want, you don't have to fill up the "gaps".But... why would you want that? Is my guess correct, that you want to devide the switches into two different physical areas?If yes, please be aware that the cable lenght is not unlimited. Search the forum for "cable lenght".Greets, Roger
alexglvr Posted April 5, 2008 Author Posted April 5, 2008 thank you for your answer!I seached but didn't find any information on the cable lenght... I need 2m or so... Is it allright?Alex
Screaming_Rabbit Posted April 5, 2008 Posted April 5, 2008 ... sorry for the typo: lengthhttp://www.midibox.org/forum/index.php/topic,4099.0.htmlGreets, Roger
alexglvr Posted April 5, 2008 Author Posted April 5, 2008 Coool..1m should be enough... Thank you again for your help. I will send pictures once finished...Regards,Alex
