I've fried a variable psu. there was short in one cable during test.
It's fired just 1 of the 2 resistors inside, the biggest one. It was connected after the rectifier at the positive pins of 2 big caps 1000µf 25v. The other resistor it's a 560ohm.
It's completely fired than it's impossible to know the value.
2462_psu1_jpg779d5b2935b40bfa52da08ca517
2464_psu2_jpg0176b10414863466590cb46a61e
2466_psu3_jpg5894ba15016dae567767732040e
The resistor in question forms part of a low pass filtger, in conjunction with the two electrolytic capacitors below it.
Most likely what has happened here is that when you shorted the supply, you exceeded the power rating (wattage :P) for the resistor. As this resistor is in series between the rectifier and the output, it took a whack.
Do like the rabbit says. Feed us more info.
okokok! i will post more info and a circuit schematic to help, thankyou :)
for now:
AC - DC Adaptor
Model: AL1000/10
Input: 230 ~50Hz
Power: 18W
Output: 1.5-3-4.5-6-7.5-9-12 V=== (the upper line it's continuous, obviously).
Current: 1000mA 12VAmax.
8)
What would help the most, would be a model number for the transformer.
From this, we can determine the voltage  :P taps, from them, knowing the 560R parallel value, we can determine the current limiting/low pass filtering R(x) value.
Once we have done this, we (I) will suggest that you put in a higher power resistor, or do all your shorting out after a 78xx series regulator, as they have thermal cutout.... ::)
