Futureman Posted April 26, 2008 Report Posted April 26, 2008 I tried searching for info on this, to no avail.Can someone please point me to where I can find out how to wire up a dedicated LED when i'm viewing steps 17-32, and how to wire up the dedicated button for this (From memory, F4 does this, do I just wire up another switch in parallel?)The DIN / DOUT wiring PDF's for the SEQ 3 mentions this button / LED, but does not seem to tell me where to wire it up etc.Any help is much appreciated.RegardsMike
TK. Posted April 26, 2008 Report Posted April 26, 2008 It's documented in the setup_*.asm fileE.g., setup_mbseq_v3.asm, search for "Step"Note that you are able to change the pin assignments as required.Best Regards, Thorsten.
