Here i presents my MBHP SeqV3. It´s not a special only the standart. But I like it nevertheless.
The Power LED is now the MIDI-RX-LED :-) The original C64-Power Switch was used.
2622_IMG_3969_jpg86ff54cc045d7bed2ef97b0
2624_IMG_3982_jpgdef064c56ca496a660e9944
2626_IMG_4012_jpg7b8228cfabca846aab5177a
2628_IMG_4016_jpg897784726aec3d0a238716d
Tommorow i will present my new finished VERO-BOARD Projekt. It is amazing . . . it´s a drug :-)
Pascal, does your girl-friend still talk to you? Just wondering due to the massive lack of gf-time you must be having lately ;)
stryd, it is a Laser Printer Sticker Foil from Pearl what i have printed. Thats great or!? ;-)
@nILS: *lol*
I think it looks bang-on! I don't see any glitches or bubbles or miscolouration or messy edges around holes or anything...
Is that one a water-slide decal or is it a normal adhesive backed paper? Were there any special techniques you used to place it?
No, thats normal sticker foil.
http://www.pearl.de/pd-direct-link.jsp?pdid=PE8352&catid=5619&catidfrom=2010
I have very slowly worked at this. My step´s to it:
1. Design a Frontpanel (with FRontplattendesigner)
2. Print the first Design with placemarks
3. Pick it on the Frontpanel
4. Drill all holes and cuts for the Display
5. Pick up the foil.
6. Print the Frontplattendesigner File as PDF
7. Import it in Photoshop or other good Grafictool
8. Print it out
9. Put the Frontpanel on a Glasstable under this was a Lamp
10. And then very slowly and many more patience
11. First one Side and then from left to right pull the paper from the sticker
12. Cut the borders with a skalpell
13. Use a old dirty Solderiron to cut the holes (DANGER! DON´T MAKE IT IN YOUR LIVING ROOM OR A CLOSED ROOM!)
Ready.
Excellent tutorial, thanks man!
Heh, when it comes to this stuff, "normal" seems to vary depending on where you live :D
Just one example: Here, the word 'foil' implies metal sheeting, like the aluminium you wrap food in....
Ups, sorry. My english . . . I hope all people understand what i mean *lol* To corection: it´s not a metall foil ;-)
