pilo Posted June 18, 2003 Report Share Posted June 18, 2003 I own a KS0103/KS0104 LCD display... I've got the datasheet for them... but I can't use them... I look at the datasheet of the KS0107/KS0108 (which work with MIOS, don't they?) and they seems to be "brother"... Do you think I will be able to use my LCD with MIOS?www.eio.com/ks0103.pdfI can't find the link to the KS0104 datasheet but I've go it... Quote Link to comment Share on other sites More sharing options...
TK. Posted June 18, 2003 Report Share Posted June 18, 2003 Hi Pilo,Jack sent me a KS0104 based display some time ago, but I wasn't able to write a driver because of a incomplete spec. Later I realized that such kind of displays will eat so much performance, that they cannot be used with a single chip. A second PIC will be required with a tricky firmware which emulates a KS0108 protocol or something similar. Too much effort for me (yet), so: forget this display :-/Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
pilo Posted June 26, 2003 Author Report Share Posted June 26, 2003 Well... sorry to bother you again with this Thorsten... But, I have a look at schematic, get the wiring of my display (which require a controller). I think I can try to make something with this, my only problem is that I don't really know how I can wire this to ths PIC. Using another pic is not a problem! I've got some programming skill and I think if I know how to display one pixel on the display, I will be able to make everything with it (I've already work with PC vga card, in asm... a long time ago!). So if you can give me a little help (I think with KS0103 and KS0104 pdf it will be easy) I would continued alone, and see if I can do something with it or not...Thanks! ;) Quote Link to comment Share on other sites More sharing options...
TK. Posted June 29, 2003 Report Share Posted June 29, 2003 Hi Pilo,do you have a link to the pin description?Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Shadyman Posted February 19, 2008 Report Share Posted February 19, 2008 Hi Pilo,do you have a link to the pin description?Best Regards, Thorsten.Hi TK,I'll send you one :)--Shady Quote Link to comment Share on other sites More sharing options...
